05-11-2012, 05:36 AM
#91 |
Oddometer: 1,116
Just to add another level to the cracked tank saga.
On an outing recently I noticed a large build up of clay on top of the swing arm. It was gradually drying and it had a very definite imprint of the underside of the fuel tank in it. When bottomed out, ie all the shock stroke is used, the swingarm appears to come within approx 20mm of the underside of the fuel cell. So, if the clay dries, and then I bottom.....what happens? If small rocks are present in the clay and I bottom? In my humble experience, if it CAN happen....it eventually will. |
05-11-2012, 07:09 AM
#92 |
Oddometer: 3,442
Just a note... there is a cracked tank poll running HERE:
http://f800riders.org/forum/showthre...s-tank-cracked ... and while not scientific, and likely overloaded with USA-riders it still makes you suspect there is something different about the Canister-equipted bikes, or the environment the operate in that causes cracking................... |
05-11-2012, 07:42 PM
#93 |
Blueback
Oddometer: 30
Augtung
05-11-2012, 08:18 PM
#94 | |
Oddometer: 210
2010 F800GS | 1973 Honda Z50 Mini Trail |
05-12-2012, 08:33 PM
#95 |
Blueback
Oddometer: 30
Cracking gas tank
Getting back to the subject matter, cracked gas tanks, lets look at alternative solutions to warranted replacement like to 2 part epoxy used for plastic bumper repairs--or marine epoxy B52 --or J P Weld --or Bondo -or-or -etc.
Who has tried what and has it help up. Paying $1000 to have the dealer replace the tank is certainly not going to be my first option--how about you? |
05-12-2012, 08:59 PM
#96 | |
Oddometer: 2,841
Erling |
05-14-2012, 02:39 PM
#97 | |
Blueback
Oddometer: 30
Crack
Seriously here, if you have the molding skills and epoxy knowledge to make your own tank you are certainly knowledgeable enough to comment on the best patch/calking epoxy based repair product to use--- Please share you vast knowledge here as there is many of us that don't have your education in plastics. My approach would be to take a die grinder, chuck up a fine tipped steel router and cut a v-notch in the outer shell along the crack outline.-- lets say 1.5 to 2mm deep. Then take some of the fine plastic material routed out and test the epoxy to see if it dissolves the parent material. This should indicate it will bite into the cracked edge and hold up. Now old chap-- please critique this approach with your vast background here. Old Blue |
05-14-2012, 07:59 PM
#98 | |
Oddometer: 2,841
Erling |
05-15-2012, 12:32 PM
#99 | |
Blueback
Oddometer: 30
05-15-2012, 02:07 PM
#100 | |
Oddometer: 2,841
Erling |
05-15-2012, 05:11 PM
#101 | |
Blueback
Oddometer: 30
- my fear is if BMW starts a "good will replacement" will I qualify with a patch job unless it's leaking? Of course nobody can help me with this question except BMW--and they of course will sit in the weeds until a tank fails and kills someone. Their shaft drive issue on BMW's would fill a book and their answer is, 'there are only limited failures of this part"
05-15-2012, 05:23 PM
#102 | |
Oddometer: 2,841
Erling |
05-17-2012, 02:14 PM
#103 | |
Oddometer: 3,442
![]() Anybody know for sure? |
05-17-2012, 04:18 PM
#104 | |
Oddometer: 2,841
Erling |
05-17-2012, 05:42 PM
#105 | |
Oddometer: 3,442
I'll fight the good fight in about another year or so ..............
