Old 03-11-2013, 03:20 PM   #1891
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Originally Posted by 100mpg View Post
nope, just trying to suggest an alternative. you are reeeelly over reacting.
have fun.
You see the smiley faces after my comments, right? I'm picking on you just like you pick on me with all the spraypaint comments.
Please don't be offended.
kirkster70 is offline   Reply With Quote
Old 03-11-2013, 04:44 PM   #1892
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 210
Originally Posted by kirkster70 View Post
Hey - you took your helmet with you!
Sorry! Hard habit to break.It's 15" back to beak, 11" ear to ear, and 12" bottom to top.
Greatl looking rails, btw!
Ride4Coffee is offline   Reply With Quote
Old 03-11-2013, 06:41 PM   #1893
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Thanks! ...and Thanks!
Old 03-11-2013, 06:43 PM   #1894
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I hope it still lines up! Lots of heat went into this...
I finish up with a 60 grit flapwheel and bevel the leading edge.
Old 03-11-2013, 07:17 PM   #1895
Dorzok
Dorzok's Avatar
Oddometer: 1,818
Hey Kirk,
When you gonna do sumpin sumpin like this, hm??
Dorzok is offline   Reply With Quote
Old 03-11-2013, 07:28 PM   #1896
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Wouldn't THAT be cool!!!! Shoot, I'd be happy with a small aluminum rowboat!
I have a couple nice projects I want to try...
This spring - a nice BBQ smoker, and a nice enclosed fire pit. We were looking at a camping trip to Fort Wilderness @ Disney, and the fire pit needs to be covered.
I still want to try my hand at a sidecar for the KLR, and I think I can pull it off with much research.
It all comes down to time and money. I usually have one or the other. Once I have enough of both, I can do something about it.
Old 03-11-2013, 09:27 PM   #1897
H14
I Gotta Go!
H14's Avatar
Oddometer: 4,609
http://www.crazyfoxcoffee.com/ Discount code ADV
"I'm gonna ride till my money runs out"-eddie bolted
H14 and Campcook wandering aimlessly 2-up
2012 Riding the Continental Divide
H14 is offline   Reply With Quote
Old 03-11-2013, 09:44 PM   #1898
xcflyn
xcflyn's Avatar
Oddometer: 1,138
That is SWEET ! Nice work
xcflyn is offline   Reply With Quote
Old 03-12-2013, 12:10 AM   #1899
Dorzok
Dorzok's Avatar
Oddometer: 1,818
yes it is nice work....whoever did it.
Old 03-12-2013, 03:25 AM   #1900
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Looks like they had to use an english wheel on a good bit of it.
Top notch craftsmanship right there!
Coffee's ready...time to get on the next build!
Old 03-12-2013, 05:15 AM   #1901
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,561
Don't you ever sleep?
Couple things I have learned on TIG'ing aluminum, stuff like that thick bar, hit it with a MAPP torch and preheat it. Make the start much easier.
I used to grind my green tungstens and then put a flat on them, and then they would "ball" up upon welding. I forgot where I heard it, but someone suggested DC+, about 80A on regular steel and it makes balling the tungsten stupid easy. And also easy to adjust the size of the ball. It's my new favorite trick. The DC+ thing is what threw me at first, but it works, just feather in the pedal and voila.
And I've also been spending a little more time with the SS brush and acetone wiping everything including filler rods. My Aluminum welding is better than my steel welding at the moment
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 03-12-2013, 05:24 AM   #1902
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,561
I used to work for a custom yacht builder as a designer. One of our customers owned an aluminum supply company and he wanted a gentlemans yacht. He had the entire thing CAD designed, waterjet cut and shipped to the yard on a truck. Every part was also labeled and engraved with slots for matching pieces. It really was like an erector set. Incredible to watch go together.
http://www.lymanmorse.com/boatDetails.php?boatID=26
And the owners "tender"
Nessmuk
Old 03-12-2013, 05:55 AM   #1903
phreakingeek
phreakingeek's Avatar
Oddometer: 423
skidplate
Now that skidplate looks like it'll take a hit without folding like a cheap lawn chair!
It would be a crime to cover those welds with paint...looks like $1000 in dimes laying down in a row.
phreakingeek is offline   Reply With Quote
Old 03-12-2013, 06:22 AM   #1904
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Not when I'm off. 5 hours is "sleeping in" for me.
Yours is an inverter, isn't it? Miller doesn't recommend pure (green) tungsten on their inverter machines. I'm using 2% ceriated.
Also, the "balled" end is used on transformer machines (according to Miller), not their inverters. So, I'm using a pointed tip with a blunt on the end, and it stays sharp unless I crash it. If it balls, I know I have too small a tungsten for the amperage I'm at.
When I was running the air-cooled torch, it took a good 10 seconds with the pedal mashed all the way down to the floor @ 200A to get the puddle started on 3/16" al. With the liquid-cooled torch, I can start in about one second at 3/4 pedal and then back out of it as I move. It truly changed the machine. Plus, I'm using half the argon. So, in theory, the cooler will pay for itself after about 50 fill-ups of Argon. Only about 46 more bottles to go. Shouldn't take long now...
MAPP preheating sounds like a very good idea on air-cooled, but the liquid-cooled torch lights up right now. It's very cool. Plus, when I do crash the tungsten, by time I loosen the back cap, I can pull out the tungsten bare handed. The cooler is awesome. I had to wait 30 seconds or so on the air-cooled torch.
I honestly can't tell when I do cleaning on al. or not. Sometimes I brush, sometimes I don't. Sometimes I scotchbrite the filler, sometimes I don't. I don't see a difference either way, but my filler is new and the aluminum is new as well, so maybe that's why. I also set the cleaning action on the machine so I have a nice little white halo around the toes of the weld. TIG welding is fun isn't it? It's very overwhelming at first, but gets much easier after some good hood time.
Old 03-12-2013, 06:23 AM   #1905
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Awesome work!!!!!!!!!
Times are GMT -7.   It's 01:04 PM.
