Old 03-12-2013, 03:31 PM   #1921
lousot
lousot's Avatar
Oddometer: 466
nice find Luke
don't you have your own build to keep us entertained with
Originally Posted by Luke View Post
On a metric bike?
That hurts. Especially since I just had to add inch hardware to mine.
BTW, inch or metric, I love these things:
They like to stay aligned, and there's a lot more meat on them so you can really burn into them without messing up the threads. Like anyone needs another excuse to order from mcmaster.
If you dump it in front of me.I promise I wont run you over.dit: And remember, "You can't drink all day if you don't start in the morning".
lousot is offline   Reply With Quote
Old 03-12-2013, 06:38 PM   #1922
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
Originally Posted by lousot View Post
nice find Luke
Luke is offline   Reply With Quote
Old 03-12-2013, 07:12 PM   #1923
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
3/4" angle trimmed up...
...to weld to the main bracket for additional support.
Everything is fully welded. Shaping the tabs will have to wait until tomorrow.
I buy a nice rivet gun after getting a helpful tip from xcflyn. This thing is huge! It didn't look nearly this size in the pics.
I'm hoping to put it to use in the next couple of days!
Pannier racks should be complete tomorrow and I can start on the panniers.
kirkster70 is offline   Reply With Quote
Old 03-12-2013, 08:57 PM   #1924
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 211
Looking great, Kirkster!
Ride4Coffee is offline   Reply With Quote
Old 03-13-2013, 04:00 AM   #1925
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Thanks, J!
Getting ready to make some noise since the kiddos are awake.
Old 03-13-2013, 05:44 AM   #1926
Ride4Coffee
Oddometer: 211
I like the design and attachments. The racks look lower than Jim's. Will the bags be riding higher on the frames, or am I just seeing things?
And Jim's idea of welding the attachments is brilliant!
IBA# 57940
Need the 90mm bolt for your Kaoko?
Old 03-13-2013, 07:12 AM   #1927
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Thanks! Yep, they are lower. The size,shape,height of each set was all determined by the exhaust cut-out of the left pannier.
Jim's had a hard 90, so that made the rack completely different.
Yours will have a 45, so they have to be lower for the same lid height.
Old 03-13-2013, 07:17 AM   #1928
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Tabs finessed with a 60 grit flap wheel.
Step one of many complete. Currently sucking down more high-test.
After sweeping all the grinding dust off the floor, I get to do some clean work! Pannier fab!
kirkster70 screwed with this post 03-13-2013 at 09:37 AM
Old 03-13-2013, 09:04 AM   #1929
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Ummm....are you sure about this? To fit your helmet and still allow for flange and gasket make the R side 12 3/4"...
Holding pattern in progress.
kirkster70 screwed with this post 03-13-2013 at 09:38 AM
Old 03-13-2013, 09:23 AM   #1930
Ride4Coffee
Oddometer: 211
Holy Smokes!! That's a big box! (That's what she said...)
I don't mind wide, given I ride with the Varios expanded all the time. However, I'll put the helmet in the top box, so let's scale the sides back a little bit. How wide are you thinking?
Old 03-13-2013, 09:26 AM   #1931
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
9" is pretty standard. Jim's are 10". These are nearly 3" wider than Jim's.
You tell me.
Old 03-13-2013, 09:26 AM   #1932
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,776
If you discount the angle, and make it 11" wide at the opening, that would likely work. The angle should still allow the helmet to fit, but just not sit flat on the bottom.
Mine were just about an inch too narrow for a helmet.
BTW, that might make a good top box for me, cut down on length, if J desides not to go that wide. I want one that will fit a helmet, about 12X15X15 or so.
Jim
Old 03-13-2013, 09:30 AM   #1933
Ride4Coffee
Oddometer: 211
Jim
Jim - I like your idea, but prefer the angle more than putting the helmet in.
Kirk - Let's go with a wide box (10" or up to 11"). Jim's right about that being a great shell for a top box!
Ride4Coffee screwed with this post 03-13-2013 at 09:34 AM Reason: second thoughts
Old 03-13-2013, 09:32 AM   #1934
JimVonBaden
"Cool" Aid!
Oddometer: 53,776
Kirk - Let's go with a 10" wide box. Jim's right about that being a great shell for a top box!
You can still have the angle! The helmet just won't sit flat on the bottom of the pannier if you narrow it a bit. What did you need for the helmet?
Jim
Old 03-13-2013, 09:32 AM   #1935
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
That is an 11 1/2" opening. I need to allow 1/8" on each side for gasket, which makes the final opening 11 1/4".
a 5/8" flange + material thickness makes it a tad over 12 3/4" O.D.
Times are GMT -7.   It's 12:29 AM.
