Old 10-11-2010, 07:12 PM   #31
sonoran
you already know
sonoran's Avatar
Oddometer: 25,112
Tits. Off to Ace Hardware I go...
sonoran is offline   Reply With Quote
Old 11-11-2010, 07:04 AM   #32
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,057
The other down side I see is if you totally remove the aluminum plate from the bike, the oil can drop straight down when you drain the oil tank. If the plate stays in place, you have to use some sort of trough to divert the oil stream.
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 11-11-2010, 12:50 PM   #33
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,884
Great write up and pictures Geek and fair play for quoting Qwiks' idea
I'll have to do the same as I stripped the thread on one side when I fitted the SW Motech bars yesterday
Well done fellas!
DeeGee is offline   Reply With Quote
Old 11-17-2010, 06:34 PM   #34
Holaday
Man of Leisure
Holaday's Avatar
Oddometer: 598
Thanks Geek
And Quik used your technique for remounting my crash bars today. Worked Great !!
Soon as your born you start dying, so you might as well have a good time!!!
Checkout my Ride Reports:
Baja
http://www.advrider.com/forums/showthread.php?t=405461
Kootenays
http://www.advrider.com/forums/showthread.php?t=614464
Holaday is offline   Reply With Quote
Old 11-17-2010, 06:48 PM   #35
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,186
Thanks Geek.
I've already had to helicoil one of the threads to get the stock bolts to work...
I'm going to do this conversion soon.
One question regarding the parts...
But what if you have big nuts like me?
Can I still counter-lock them together?
Q~
Old 11-17-2010, 08:20 PM   #36
plumbtired
plunging into the farkle
plumbtired's Avatar
Oddometer: 184
Still waitin to hear how the nut change went Geek, OUCH!!
Also helps to elongate the holes in the battery top cover where the bottom crash bar mounts meet the clip nut. Did stud method to the skid plate mounts too. Have to make spacer for that one.
Once you actually measure the bolt threads supplied by KTM and what they attach to kinda makes you wonder who the hell engineered this!
RidnChina
If they all worked right I'd be retired
08 990
98 DR
plumbtired is offline   Reply With Quote
Old 02-21-2011, 04:53 PM   #37
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,363
Dave
I'm about to do this mod as well, seems like a much better idea than ripping threads out each time. Thanks Geek for the detailed write-up.
I wondered if anyone else struggled with the oil thing that StmbtDave mentioned? I was thinking of removing some of the aluminum so it can drop straight through.
HowlingMad is offline   Reply With Quote
Old 02-21-2011, 05:45 PM   #38
DeeGee
DeeGee's Avatar
Oddometer: 1,884
I just cut the bottom off a 500ml bottle of water and use it as a funel, works a treat
Old 02-21-2011, 06:56 PM   #39
mamacone
mamacone's Avatar
Oddometer: 149
I like the studs used in this picture I think they have an internal allen head if you need the stud out for some reason. Not sure how much running around I would do to find them though.
13 500 EXC
04 950 adventure
00 300 exc plated
mamacone is offline   Reply With Quote
Old 05-06-2011, 09:59 PM   #40
derm75
I'm a brother shamus...
Oddometer: 402
Thanks for the write-up on this, I was struggling with the crash bars when I remembered this thread. Made a run to Ace for the parts but also ended up going to Harbor Freight for a tap and die set to clean up the threads before I put the studs in.
It's better to regret something you did, than something you didn't do.
'08 Kawasaki KLR685
'09 Husqvarna TE250
derm75 is offline   Reply With Quote
Old 05-07-2011, 01:03 AM   #41
Qwik
Adrenaline Addict
Oddometer: 6,916
I had not thought of doing the same setup to the front bellypan bolts. Good thinking. My next mod......
Same here. Works a treat.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 05-07-2011, 11:26 AM   #42
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Thanks for the post, Geek. Fab images as usual. Great addition to the HOW. Gonna have to rename it the GHOW
Good time to do a quick change oil valve. Think I'll do both mods next oil change.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 05-07-2011, 12:36 PM   #43
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,862
cp:
I'm going to have to come up with an inverted one for the skidplate I think.. I've stripped my left front skidplate mount bolt
Old 05-07-2011, 12:42 PM   #44
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Any of you folks have a better set-up for the lower tank mount bolts? Has to be something better than those floating "range change" nuts. Could dremel out the holes, I guess. I'll probably do this mod and the tank mounts at the same time....
jamesbrown is offline   Reply With Quote
Old 05-07-2011, 01:32 PM   #45
tomdubz
getting there
tomdubz's Avatar
Oddometer: 544
It's certainly not painless but once you do the crashbar stud mount mod, I've found that those lower tank mounts become a lot easier given the post to use in your wrestling favor. That and clean threads on both have made my life easier.
This is my signature: TD
tomdubz is offline   Reply With Quote
Times are GMT -7.   It's 03:52 AM.
