Old 05-07-2011, 04:06 PM   #46
plumbtired
plunging into the farkle
plumbtired's Avatar
Oddometer: 184
Previous thread addressing some of this?
Originally Posted by Geek View Post
cp:
I'm going to have to come up with an inverted one for the skidplate I think.. I've stripped my left front skidplate mount bolt
http://www.advrider.com/forums/showt...=stripped+bolt
Spacer's needed for this mod to take place of shoulder bolts.
RidnChina
If they all worked right I'd be retired
08 990
98 DR
plumbtired is offline   Reply With Quote
Old 07-22-2011, 08:21 PM   #47
blkadvR
Oddometer: 100
Wink
FWIW I purchased 2 M8-1.25 x 40mm stainless set screws and 2 M8 flanged nuts today for $5. I used the existing spacers instead of stacked jam nuts so the plate is easier to remove if necessary. I used hi-temp anti seize in the threaded bores to insure the studs would not suffer from dissimilar metal corrosion and get seized up, JIC they needed to be removed. Using the set screws makes it an easy install or removal since you can use a allen wrench. Easy 5 minute project before installing my new TT crash bars.
blkadvR is offline   Reply With Quote
Old 09-14-2011, 02:05 AM   #48
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,156
OK, i did this mod on mine. Thanks to all you guys.
I also did the stud mod for the sump guard (which already have helicoils) but as i used two nuts jammed on the stud, the sump guard doesn't go up all the way. Now i am realising that i shouldn't have done this as there in no need for the jammed nuts.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 09-14-2011, 05:17 AM   #49
Xanadu
Oddometer: 162
I would not want that gap. Your battery compartment will get trashed with mud and dirt. It's designed to seal up tight. Can't you just have hte stud only and use the nut to tighten it up? Or does the stud nut fit through the rubber washer and it tightens up? Can't really tell from the pic if that is where it will be or if you just have it down to show the stud nut.
Xanadu is offline   Reply With Quote
Old 09-14-2011, 05:34 AM   #50
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,156
I don't want that gap either . I'll have a truck load of sand within an hour of riding...
I have realised that the stud nuts don't need to be there, ie., i will now remove the stud nuts and install the stud only and use the nut to tighten up the sump guard. No the nut doesn't go thru the rubber grommet.
thx
Old 09-14-2011, 07:27 AM   #51
Qwik
Adrenaline Addict
Oddometer: 6,865
Just put some loctite on them and lose the doubled up nuts. End of problem. Looks good though.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 09-15-2011, 09:57 AM   #52
Peanuts
Peanuts's Avatar
Oddometer: 1,672
http://www.ebay.co.uk/itm/M8-x-50mm-...item2a0b103cb0
ideal
Peanuts is offline   Reply With Quote
Old 09-15-2011, 10:22 AM   #53
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,961
Dont the stock bolts have a shoulder on them to prevent you from over torqueing the plate and risk cracking the bottom cover?
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 09-15-2011, 11:41 AM   #54
Peanuts
Peanuts's Avatar
Oddometer: 1,672
The stock sumpguard bolts have a shoulder to avoid squashing the rubber bush. You could make up a tube to put over the stud to do the same job.
Old 11-01-2011, 12:04 AM   #55
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,419
Set screws are the way to go You can even use the existing spacers for a clean install
Just try and get stainless steel
btw, the bottom nut is just for holding the screw up for photo
Great mod!
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 01-24-2012, 08:38 PM   #56
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,246
Can I suggest to anyone thinking of this mod to do it when you get the crashbars and mount them. I've had mine on for a few months. In the meantime I've dropped the bike a few times in fun & games on the crashbars and it is just about impossible to get the bolts back in the holes.
So I'm now doing the stud mod. It would have been easier at the beginning before things became .... used.
FE450.
XT660R
Blakduk is offline   Reply With Quote
Old 01-24-2012, 09:10 PM   #57
Qwik
Adrenaline Addict
Oddometer: 6,865
I found a metal tube/spacer that fits fairly snugly in the rubber bushing. Stays put when I remove the nuts.
Old 06-18-2012, 05:27 PM   #58
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,556
I'm about to undertake this mod (or 'Fix' in my case!)- and I found these online after a shit ton of digging. Thought I'd share-
http://www.fastenal.com/web/products...X2580040A20000
"Everybody loves cunnilingus!" Chacifer
"The road to paradise is paradise" Jacques Yves Cousteau
Jabba is offline   Reply With Quote
Old 06-19-2012, 02:04 PM   #59
620rossco
Full on Yob
620rossco's Avatar
Oddometer: 263
options
For the bolt section i found a lifter stud that was the right dimensions, permanent lock-tight, shimmed to size and used nylock nuts. The advantage of this is that there is no bottom nut, just a permanent stud and spacer that can be replaced.
Rossco
950ADV Ducati ST4s 900S2
kickstart.
620rossco is offline   Reply With Quote
Old 06-22-2012, 11:21 AM   #60
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,473
Big thanks to all...
This is a great mod. And the parts list and also Fastenal lead additionally helpful. Adv is truly a great site with great people.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Times are GMT -7.   It's 06:38 PM.
