06-22-2012, 12:22 PM
#61 |
was Steve Lavigne
Oddometer: 418
Here is the set screws I ordered from Mcmaster a while ago:
http://www.mcmaster.com/#catalog/118/3076/=i3anj9 92015A151 I got the 50 mm studs, but I also drilled and tapped the holes a bit deeper because I stripped the threads on one side. I think I was able to drill and tap an additional 10mm. Can't remember if I used a bottoming tap.
'07 KTM 990 Adventure Long Road to Dug Bar |
06-28-2012, 03:48 PM
#62 |
Oddometer: 306
Wondering if anyone may happen to know how deep the screws thread in?
I'm going to go the stud route, but my threads are already mangled so I'd like to helicoil first. Wondering what size I would need. M8 @ 1.25 pitch, but how long.... If anyone happens to know off the top of their head, that would be awesome. Thanks |
06-28-2012, 07:22 PM
#63 | |
Dans le doute...gaz!
Oddometer: 1,721
The race is long and, in the end, it's only with yourself...
06-28-2012, 07:45 PM
#64 |
Oddometer: 306
Thanks, not that I don't believe you though, but the parts diagram does show that the standard bolt (not that for the guards) is 16mm long. Do they factor the head into these figures? I didn't think so?
Due to the spacers, the ones supplied with the guards must be longer than in the OEM diagram though. Regardless, I'm more interested in the depth of the threads on the mount... how much of the bolt is actually screwing in. I'm guessing it's about 10mm of thread? Leaving 30mm exposed (with the 40mm recommendation) for the cover, spacer, bar, wash and nut. Also wondering where I can find a diagram of all the hardware included for the crash bars. Also looking for a bolt length figure for the lower tank mounts. |
06-28-2012, 07:56 PM
#65 |
Oddometer: 1,721
I have 30mm exposed on the right (facing the bike). And 25 on the left.
Keep in mind that you will not be able to remove the cross race once the studs are in unless you unbolt the header. The shorter stud allows me to loosen up the header bolts without having to remove it and wiggle the brace out.
06-28-2012, 08:03 PM
#66 |
Oddometer: 306
Good to know, thanks.
Not sure I was planing on permanently affixing the studs. Was thinking I would just torque them in with medium loctite. So with 25mm and 30mm exposed, do you remember what the actually length studs you used. 35 and 40mm? I'm beginning to think its 10mm the bolt threads in to the mount. Thinking I'll be going with the M8 x 10 helicoil. |
06-29-2012, 07:24 AM
#67 |
Oddometer: 240
Rule of thumb is you reach max strength on a bolt at 1 and one half times the dia. of the bolt...so it really does not matter how deep the hole is...as long as it is 1 1/2 times deeper that the dia.
'06 950 Adventure '03 400 KLX Phil in K.C. screwed with this post 06-30-2012 at 04:48 PM |
06-29-2012, 08:21 AM
#68 | |
Oddometer: 306
![]() This is invaluable to me. Going to go for 12 mm and call it a day. Thank you both! |
02-25-2013, 11:44 AM
#69 |
Life is a trip
Oddometer: 3,115
I want to underline that stainless steel bolts would stick with aluminum
due to galvanic effect as I saw some people in here mentioned.
There is always a reason!! |
03-16-2013, 03:11 PM
#70 | |
Wile E Coyote SuperGenius
Oddometer: 1,164
Easy-peasy. Yes, I used two nuts.
FakeName screwed with this post 03-16-2013 at 03:32 PM |
04-28-2013, 06:00 AM
#71 |
Original Bastard
Another change that I made is to get rid of the threaded clips for the lower tank mounts. That was the most difficult bolt to get lined up for me. I finally got tired of it and just use a shouldered nut there now. Easy peasy to put the crash bars back on now
Ignorance breeds Fear. Fear breeds Hatred. Hatred breeds Ignorance. Break the chain. cancerSkyclad's Wanderings Bald Eagle Bastard Bullwinkle Death Rider |
05-07-2013, 10:36 AM
#72 |
Oddometer: 221
Went to the local Fastenal and was able to score some M8 studs that are 30mm in length. Do you guys think these will be long enough?
www.moonshineleatherworks.tumblr.com |
05-07-2013, 12:15 PM
#73 |
Oddometer: 38
05-07-2013, 02:10 PM
#74 | |
Oddometer: 1,164
Maybe. Possibly. I wouldn't. The only way to make them work is to reduce the amount of stud in the boss. Given I'm prone to using my crashbars, that's a lot of force. Just order the ones you need from Fastenal. They can bring them in from another store, or you can order them online. |
