Old 10-09-2010, 11:44 AM   #1
wanderind OP
wanderind's Avatar
Oddometer: 296
Airhead Carb and tank cleaning question
For a bike that has been sitting for years and needs both tank and carbs cleaned, how difficult and expensive is the job if I am doing it myself? I am a noob on airheads and any info regarding the procedure and links to good stuff will be appreciated. If the tank needs cleaning, does it mean the fuel pump, filter and lines may also need replacement?
wanderind is offline   Reply With Quote
Old 10-09-2010, 11:56 AM   #2
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Use Google and do a search of the "Olds Cool" archives.
This subject has been the subject of literally dozens of threads.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 10-09-2010, 12:12 PM   #3
fishkens
Further...
Oddometer: 5,149
Year and model would help a bit.
How difficult? That depends a lot on you. I'm no genius but I've rebuilt my carbs multiple times w/out fatal errors.
Parts and a good manual can be purchased here:
http://www.bingcarburetor.com/
http://www.advrider.com/forums/showthread.php?t=602188
Tips
http://w6rec.com/duane/bmw/tuning.htm
http://bmwmotorcycletech.info/bingcv.htm - Read this with caution and if it starts to scare you off take a break - it's not really that complicated. Eventually, you'll want to read most of what he writes but pace yourself - I think I'm going on 10 years now. Unfortunately, it seems that it was written before images could be easily transmitted on the intertoobes.
http://www.advrider.com/forums/showthread.php?t=355137
Zillions of Threads on advrider.com
Enter this in google:
=> rebuilding airhead carbs site:advrider.com
And get this:
http://www.google.com/search?hl=en&s...AAAKoEBU_Qeomp
As for the airhead fuel pump, you'll be pleasantly surprised - it's entirely maintenance free and guaranteed to last a lifetime.
Enjoy.
Forging ahead, down a false trail.
fishkens screwed with this post 10-09-2010 at 12:35 PM
fishkens is offline   Reply With Quote
Old 10-09-2010, 12:23 PM   #4
pjcr12
Stercus accidit
pjcr12's Avatar
Oddometer: 801
Carb'n'tank cleaning
It's not too difficult a job, it's more a question of methodically going through it all. The tanks can suffer from pin-hole leaks around the lower seams, but if you seal it with petseal (or equivalent) after cleaning out any rust flakes or accumulated grot in the tank, you should be ok. The petcocks have gauze filters inside them which can clog, and the fuel lines are best replaced if they've been on the bike for a long time. As for the carbs themselves, take the tops off to check that the diaphragms aren't split or perished. The float bowls will come off by releasing the holding clips, which will give you access to the floats, the float needles and the jets. There may well be a lot of gunge in this area, again if the bike has been stood for a long time. Work on each carb separately, on the bench, and use your Haynes or Clymer book to identify parts as you go, and use a can of carb cleaner. One word of caution; I've found that the brass main jet holder is easily rounded, so be careful. I'm sure other ADV'ers will offer advice, but just take it easy, go slow and don't drop anything!
pjcr12 is offline   Reply With Quote
Old 10-09-2010, 12:38 PM   #5
wanderind OP
wanderind's Avatar
Oddometer: 296
Thanks a ton!....you guys are great. I will go through all this and chip back in if I have more Qs... BTW The bike is a 87 R80
Old 10-09-2010, 12:46 PM   #6
wanderind OP
wanderind's Avatar
Oddometer: 296
How significantly different is carb cleaning vs carb rebuild?
Old 10-09-2010, 12:54 PM   #7
fishkens
Further...
Oddometer: 5,149
In terms of results, about the same difference between washing a car and repainting it. If the wear parts are in great shape a cleaning is fine. If the wear parts are worn no amount of cleaning will put a shine on it.
In terms of time? If you remove the carbs, clean 'em up real nice, reinstall them and find that the motor doesn't idle because all the wear parts are worthless you'll need to remove the carbs and rebuild 'em, i.e. a cleaning and a rebuild may take twice the time as a rebuild alone.
Old 10-09-2010, 12:59 PM   #8
wanderind OP
wanderind's Avatar
Oddometer: 296
Thanks Fishken...your reply implies that rebuild will take the same amount of time and effort except for the new additional parts and o-rings, right?
Old 10-09-2010, 01:17 PM   #9
fishkens
Further...
Oddometer: 5,149
Replacing all the o-rings, enrichener gasket, diaphraghm and possibly the needle will definitely take a bit more time but it's probably necessary if they haven't been attended to in quite sime time.
Have you started it? You could start by flushing the tank and carb bowls, putting in fresh gas and running it to see what you've got.
Depending on your goals you'll probably want to assess the entire bike and put together a plan to bring it to the condition you want.
Here's an example of a methodical approach to the process:
http://www.advrider.com/forums/showthread.php?t=431153
Old 10-09-2010, 01:22 PM   #10
wanderind OP
wanderind's Avatar
Oddometer: 296
havent started it...but thanks for the link and info..will get on it soon and document the thing
Old 10-09-2010, 01:37 PM   #11
fishkens
Further...
Oddometer: 5,149
And here's a photo rich thread on carbs. Very well documented.
http://www.advrider.com/forums/showt...431153&page=15
Enjoy.
Old 10-09-2010, 01:44 PM   #12
wanderind OP
wanderind's Avatar
Oddometer: 296
Enjoy.
Thanks Fishkens...really appreciate it. I was looking at this very thread while you posted it
Old 10-09-2010, 02:25 PM   #13
rufusswan
rufusswan's Avatar
Oddometer: 962
Rebuild means replace replaceable compnents. Other than grung, gaskets, O-rings, diaphrams, the needle and its jet must be replaced as a pair and should be about it unless .... I had to replace the washer/shims on the main. All else might clean up. Dismantle and clean the petcocks, replace the gas lines, clean out the tank.
Ten minutes of research on the inter-stupid will result in divergent tank cleaning methodologies and will result in an 'oil thread' headache of a severe nature. It would be best to take a pic of the tank bottom at the fill opening and then scratch that area to determine how rusty it might be. I did 4 tanks this year with different methods depending on "what" I was attempting to clean out of the tank.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Times are GMT -7.   It's 06:04 PM.
