Old 12-16-2004, 07:28 AM   #1
gybeman OP
gybeman's Avatar
Oddometer: 636
Another tire thread - Best Front offroad tire for 640 Adventure?
I'm running MT21's now which are a very good compromise, but what has everyone found to be the best front for knarly, rutted, muddy offroad? I do not find the front end to feel as planted as my bud's 640 enduro in the woods, but he is running Michelin s-12 (maybe m-12) which I will definitely swap the front for.
Looking at the frame specs there is only a 1/2 degree difference in castor or rake (don't have the specs in front of me), and forks are 1 or 2mm larger on the adventure, with everything else about the same, but his bikes front feels and turns like a DRZ400 by comparison. I've raised the fork tubes up to 10mm with little improvement. (even with a light fuel load)
I'm even considering different triple clamps if the Michelin doesn't help. The idea is to get it to turn better at lower speeds, as I don't have 90mph desert where I live.
gybeman is online now   Reply With Quote
Old 12-16-2004, 03:06 PM   #2
Alchemist
Alchemist's Avatar
Oddometer: 528
[QUOTE=gybeman]I'm running MT21's now which are a very good compromise, but what has everyone found to be the best front for knarly, rutted, muddy offroad? I do not find the front end to feel as planted as my bud's 640 enduro in the woods, but he is running Michelin s-12 (maybe m-12) which I will definitely swap the front for.
[QUOTE]
I swap to an s12 if I am doing purely trail bike riding. They grip very well. No way on earth would I ever use this tyre on hard ground or tar. They are lethal.
I'm trying a T63 on the front and Desert on the rear. But so far no "knarly, rutted, muddy off road. I'll let you know
Alchemist is offline   Reply With Quote
Old 12-16-2004, 05:22 PM   #3
DevDel
DevDel's Avatar
Oddometer: 560
MT 18 or MT 16 will do the trick. The 18 is avaiable with a 3 ply carcass. It's usually listed as a "HD" version.
Dev
DevDel is offline   Reply With Quote
Old 12-17-2004, 07:22 AM   #4
gybeman OP
gybeman's Avatar
Oddometer: 636
Thanks for the replies, I'll have to take another look at the Pirellis... hey Alchemist... a lethal knobbie? I've ridden many miles with real knobbies on pavement, and other than being real bad when they are new and greasy, I don't mind power sliding around a bit. After the knobs start to round off the traction always got much better (except in the wet of course). Is that what you mean, or are we talking front end washout, no warning crashing ? The knobs are spaced very wide, but my bud's somewhat worn m-12 didn't seem too bad... even pulled off a couple low speed stoppies on pavement.
Old 12-17-2004, 01:21 PM   #5
Rootkiller
Rootkiller's Avatar
Oddometer: 372
Michelin's are great for soft muddy stuff but the side knobs chunk pretty easy and the are really easy to pinch flat. There are probably better all around off road tires for a heavier four stroke. I prefer the dunlop 756 since it is not nearly as easy to pinch flat and grips almost as well as an s 12 or m12 in the mud yet I thinl it grips alot better on hardpack. Tire are like Aholes, everyone has there own.
Rootkiller is offline   Reply With Quote
Old 12-17-2004, 01:36 PM   #6
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,745
people who start these threads should be banned
dunlop d606 for me.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 12-17-2004, 03:31 PM   #7
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,249
Taste's Great!!!
no really, good info for the less experienced.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is online now   Reply With Quote
Old 12-17-2004, 03:40 PM   #8
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,076
Less Filling!
I want the perfect tire too.
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 12-17-2004, 04:16 PM   #9
markjenn
Oddometer: 10,483
The Adv carries a ton (well not literally) more weight on the front than the enduro model. The difference in feel could be more this than the tire.
I'd be hesitant to go any more knobby than a MT-21 on the front unless the riding was 100% dirt.
- Mark
Old 12-17-2004, 05:46 PM   #10
DevDel
DevDel's Avatar
Oddometer: 560
- Mark
Mark has a good point. Have you ever wrassled your ADV around a berm...holy shit, it just wants to go straight over the top!
The MT18 HD will support the ADV just fine. BUT, your braking distance on pavement will be scary. It is only for connecting trails, not for commuting to work. They are DOT, with a 103 or 106 MPH rating.
As for the rest of these guys, they actually think the D606 is really an off road tire
Dev
Old 12-17-2004, 06:23 PM   #11
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,752
Whatever you choose, get something wider than OEM. With lots of knobs.
My experience:
My front (full offroad, not DOT approved) has knobs perpindicular to the bikes line of travel. Everytime a row makes contact with pavement there is a small vibration (at highway speed it is ridiculous) Next time I will get a tire with offset knobs, which hopefully will lessen the vibration.
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 12-19-2004, 02:02 PM   #12
Alchemist
Alchemist's Avatar
Oddometer: 528
I did an off road course when I got the Adventure (with the S12's). Stoppies , hill climbs , popping wheelies (almost I just suck), but berms and ruts
It was hilarious. All these motocrossers screaming around and my Adventure bursting through and ruining perfectly good ruts and berms. It was like a tank busting through the enemy lines. Dirt and dust flying everywhere. You get respect by just having a go though. They took bets on heavy my bike was
Old 12-19-2004, 04:01 PM   #13
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Dev
Trying to steer an Adventure with the front wheel... this only results in looking at the apex... while riding straight thru and perpendicular to the outer radius, as if drawn by giant hidden magnets. The end result of which is laughter from anyone within viewing distance... if your lucky.
Any time I've forgotten what I was riding, and tried to steer in the more conventional way... I've gone off at a tangent to the desired direction of travel, the angle of which was determined by the tightness of my sphincter, the number of people watching from behind me (with cameras), and the distance of the drop-off beyond the outside of the corner to the inevitable... bottom.
The only reliable, consistant steering device on an Adventure, at any speed above 10 mph, is the right grip... turned sharply counter-clockwise.
So... how's tricks?
creeper is offline   Reply With Quote
Old 12-23-2004, 02:17 PM   #14
Velocibiker
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
OTOH - I've found weighting the pegs and turning with the shoulders works wonders for getting the land tanker turned quickly. But yeah, it's not nimble in any sense of the word, but it can be done.
A bit OT - but since my wife got her DRZ, I've riding it and my Adv back to back in a couple places just as an experiment. Some notes: DRZ is like a feather compared to the Adv! Power and all around 'planted' feeling are better on the Adv. I won't dare the Adv in some places I've ridden the DRZ. Adv feels better on landings. Adv, runs though ugly rocks better than the DRZ. DRZ is a really fun bike and a perfect choice for my wife. I have yet to test the DRZs road manners, but I sure enjoy the Adv in the twisties.
Currently bikeless.
Velocibiker is offline   Reply With Quote
Old 12-23-2004, 06:51 PM   #15
neduro
Addict
neduro's Avatar
Oddometer: 12,022
The point about sidewall strength is a good one. Softer tires (like the S12) work fine in dirt, but will pinch flat very easily in rocks. A few tires that do have sufficient sidewall for the Adv are:
Dun 606
Dun 739 FAJ (the J is important)
Dun 755 (softer but great in mixed conditions)
I presume the Michelin Baja and Desert are stiff as well but have no direct experience.
The Kenda Millville seems to be stiff enough to work, but I haven't run one yet.
HTH
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Times are GMT -7.   It's 03:26 PM.
