Old 04-15-2012, 02:01 PM   #1
Dorito OP
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,617
Polyurethane Skidplate Isolators?
Does anyone make aftermarket Skidplate isolators out of poly urethane?
Here's the BMW branded info:
02 71 60 8 526 643
SET: MOUNTING PARTS SET
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito screwed with this post 04-15-2012 at 03:18 PM
Dorito is offline   Reply With Quote
Old 04-15-2012, 06:14 PM   #2
epicxcrider
epicxcrider's Avatar
Oddometer: 654
For what reason? Just curious.
epicxcrider is online now   Reply With Quote
Old 04-15-2012, 06:22 PM   #3
Dorito OP
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,617
Just got done tearing off the rubber ones (and yes, still got a hole in the oil pan). Two: most "modern" bushings on cars/jeeps are polyurethane. Three: Some folks report tearing the rubber ones anyhow during routine maintence.
BTW, off to see if these will cross-reference:
http://www.bestrestproducts.com/p-23...-bushings.aspx
BlastOff Adventures
Old 04-16-2012, 03:39 AM   #4
GH41
Oddometer: 822
"Some folks report tearing the rubber ones anyhow during routine maintence"
How do you do that?? GH
GH41 is offline   Reply With Quote
Old 04-16-2012, 03:48 AM   #5
Dorito OP
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,617
Well, I don't make the news, I just read about it:
http://www.advrider.com/forums/showt...ght=skid+plate
I suppose there are other threads too..
BlastOff Adventures
Old 04-24-2012, 12:09 PM   #6
XTrooper
XTrooper's Avatar
Oddometer: 191
If someone made them, I'd buy them.
Steve
NJ State Trooper #3936 (retired 4/1/1991)
2011 BMW F800GS - Alpine White
2009 BMW R1200RT - sapphire black metallic (sold)
XTrooper is offline   Reply With Quote
Old 04-24-2012, 12:41 PM   #7
GH41
Oddometer: 822
If someone tears the factory isolators up doing maintenance the were using the wrong tool or the right tool the wrong way! Polyurethane bushungs are used on performance auto suspentions to better control geometry. They are less compliant than most rubber. That is probably the reason they don't us the to mount a skid plate. The harder the mounts are the more likely you are to break the oil pan. Think of them as four little shock absorbers. They were probably designed to be the weak link. You could just bolt the bash plate on with some aluminum spacers between it and the oil pan and solve your problem untill you hit the next rock! GH
Old 04-24-2012, 01:02 PM   #8
GH41
Oddometer: 822
BTW, http://www.vibrationmounts.com/Store...FQ/VM01029.htm Google is not very hard to use if you know the name of what you are looking for. GH
Old 04-24-2012, 01:05 PM   #9
Dorito OP
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,617
Technically, the isolators are designed for compression forces and not shearing forces. The shearing force for most of them in under 10 lbs. Doesn't really take all that much to rip them off a 400 lb bike traveling at any sort of speed.
Those don't come in metric sizing. Needs a M8.
BlastOff Adventures
Old 04-24-2012, 06:51 PM   #10
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Other then unusual circumstance, the rubber mounts never see sheer UNLESS the skid plate bends or the front through bolt breaks.
I have seen both happen, and when it happens the rubber mounts breaking instead of jacking up the threads or ripping the bosses out of the oil pan is your friend.
What you are trying to do is ride the F800GS in a manner it was not designed for.
I have nothing against this as people trying to ride a 450lb bike like a dirt bike has been great for my yearly income, but I don't think poly mounts by themselves will do anything good for you, though at a 40% markup, breaking more oil pans is good for me
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 04-24-2012, 07:05 PM   #11
epicxcrider
Oddometer: 654
Gotta agree with Joel and also say I'll keep riding it like a dirtbike :)
Old 04-24-2012, 07:42 PM   #12
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Outstanding, would you like my business card
Old 04-24-2012, 10:18 PM   #13
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,269
I think the need comes from some (me included) who have loc-tited their rubber isolators in.
There is no way to free them up once you have.
Intended use...lol
The way these bike are rode by some, bent bolts, bent brackets, shredded isolators and crunched skidplates will (and do) happen.
By the nature of many of us loc-titing everything, these isolators get stuck on.
Maybe thats where some feel a poly mount would be better. Or maybe a hex surface to grab on the isolators.
I do understand the nature of the soft rubber isolator and I agree that it is probably better at absorbing impact.
Myself I learned not to loc-tite the isolators or skidplate bolts.
Kind of a screwy system. But hey, its german.
On my 658 minimal ground clearance bike.
But the result can happen on the 800 too.
Maxacceleration is offline   Reply With Quote
Old 04-25-2012, 03:46 AM   #14
GH41
Oddometer: 822
I guess I have to do everything for you. Here you go, http://www.vibrationmounts.com/Store...=Products1.htm GH
Old 04-25-2012, 04:03 AM   #15
Snowy
Snowy's Avatar
Oddometer: 1,998
I destroyed a set because they had come loose previously and I Locktited them in.
Stupid, stupid, stupid.....so anyway, BMW wanted a Kings ransom for a full set, but one of the salesmen gave me a full set of new ones for free....well, I did spend about $20K there...
Since then, I use Locktite on the engine side, and anti seize on the bash plate side. The nuts come off no problems for service, but they don't come loose from the engine. I routinely use my rattle gun to remove and replace them.
I also destroyed the seat bridge rubber isolation mounts the same way, Locktite on both sides. After 6 weeks and $45 I got a new set and only use anti seize on them now.
Apparently not everything on the BMW likes Locktite.
Snowy is offline   Reply With Quote
Times are GMT -7.   It's 08:40 AM.
