Old 10-11-2010, 12:54 AM   #1
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
Just Dan's go at a major resto on a early model Tenere'
I was just saying to Andy Gadget that I needed a new project. Now I have finished the R100RS.
Andy said have I got the project for you, in the back of his garage. The last couple of owners gave up on the amount of work that needs to be done to the Tenere going again. It was altogether and just running bit a big knock from the clutch basket. The bike had been passed on from backpacker to backpacker before it sold on again. The speedo shows at least 117,000km (75,000 miles)
Absolutely every thing needs to rebuilt, remade or re welded. This will not be a fast restoration job. Since the bike is pieces, it is hard to tell what is missing. The wiring loom is quite trashed and will need replacing. The first step is to get the frame into shape and paint it then onto making it a rolling chassis. Arrrh where to begin
First, I need a workshop manual for the Tenere'
Any links or info getting parts and encouragement will much appreciated. Now on with the photos for viewing pleasure.
Sad, when a Tenere fits inside a small hatchback
A few boxes of bits
The wheels are round, but the spokes are very rusty
The wiring loom is shagged
Classic dented 34L tank
Frame has been broken and bush welded
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 CS
Old bikers don't get old by accident.
Just Dan is offline   Reply With Quote
Old 10-11-2010, 03:17 AM   #2
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 776
Somebody been reading Jeff and Mezo's threads for inspiration?
tattewell is offline   Reply With Quote
Old 10-11-2010, 06:10 AM   #3
metropolis2k
metropolis2k's Avatar
Oddometer: 420
That wiring loom doesn't look any worse than the one that was on my bike. I think they came out of the factory looking like that!
Good luck with it mate - Mez and I have the Clymer manual which looks like it will be your bible so keep a heads up for one of those. I've got a scan of a service manual of sorts but it's in German so probably not much use to you (or me!)
metropolis2k is offline   Reply With Quote
Old 10-11-2010, 07:23 PM   #4
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
Parts of the wiring loom look like a rat being chewing at it. I am sure I can rewire the wrecked bits. Since I know nothing about these singles. I am going to lash out and get a Clymer.
As far as I know this bike has not been started in nearly 10 years
81' BMW R100 CS
Old 10-11-2010, 10:42 PM   #5
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
Having bit of play in the garage today at trying to find the best way to remove the paint from the frame. Looks like I will doing some welding repairs. Does the frame need extra gusseting? To make it stronger as this bike will be used for outback travel.
The steering head bearings are stuffed. Oh the joy of removing cups. Guess, I will weld them too
After cleaning up the frame. Just got to choose which spray gun to use to paint the frame.
81' BMW R100 CS
Old 10-12-2010, 12:23 AM   #6
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,185
I have the XT600 manual you can "borrow" if you like but its not XT600 Tenere specific
Its only the Tank on those old ones(what years is it) that differed
Edit ah i see in the sig line!
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 10-12-2010, 12:41 AM   #7
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
Thanks for the offer of a borrow from the North. I went shopping on Amazon and bought a Clymer while the $A is good. Not to Bad $42Aus delivered
81' BMW R100 CS
Old 10-12-2010, 04:11 AM   #8
theMISSIONARY
Oddometer: 2,185
Make use of that $ before they re-adjust it
I had the 83,84 and 86 Tenere's the early one's had a different(better IMHO) cam spec but not as much power Have fun with it.........i'm watching
Old 10-12-2010, 04:12 AM   #9
metropolis2k
Oddometer: 420
Yeah, the Clymer is just for the standard XT600 too (and TT600) but like you say, there's just the tank that's different.
Old 10-12-2010, 02:24 PM   #10
Andy-Gadget
Any bike can go anywere
Andy-Gadget's Avatar
Oddometer: 1,346
And the oil cooler, above the sprocket, it was a Tenere addition as well
"If a man empties his purse into his head, no man can take it away from him.
An investment in knowledge always pays the best interest"
Benjamin Franklin.
'95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R
Andy-Gadget is offline   Reply With Quote
Old 10-12-2010, 02:40 PM   #11
theMISSIONARY
Oddometer: 2,185
None of mine had oil coolers....your not thinking of the dry sump reservoir that all XT600's had
Old 10-12-2010, 03:35 PM   #12
Andy-Gadget
Oddometer: 1,346
Look under the back of the tank, the tenere that Dan now has, has a cooler in the same position as this photo, with a plastic cover that directs air into it.
Benjamin Franklin.
Old 10-12-2010, 03:41 PM   #13
theMISSIONARY
Oddometer: 2,185
i'll see if i can find some old picture's of mine....have to scan them
Edit to be honest i cant remember if mine did or not
theMISSIONARY screwed with this post 10-12-2010 at 03:51 PM
Old 10-12-2010, 08:56 PM   #14
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,233
A few boxes of bits
Wow! Wish we could a get a bike like this one!!
BIG ED XT FAN is offline   Reply With Quote
Old 10-13-2010, 01:23 AM   #15
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
Too see how bad the tank is. I started to chisel to the filler away from the dents to see just how rusty the tank is. The tank has had a hard life with a welding repair underneath near the back bone.
The good news is. The tank holds petrol without leaking and the rust varies from minor to very rusty, but repairable.
Any suggestions about pulling dents or just fill over them again. I reckon I would lose about 1 litre of fuel with dents in the tank as is.
81' BMW R100 CS
Times are GMT -7.   It's 09:10 AM.
