Old 10-13-2010, 03:04 AM   #16
2wheeldreb
2wheeldreb's Avatar
Oddometer: 299
Find a local shop with a stud welder or order one for yourself.
http://www.hsautoshot.com/4500.html
2wheeldreb is offline   Reply With Quote
Old 10-13-2010, 03:15 AM   #17
metropolis2k
metropolis2k's Avatar
Oddometer: 425
Originally Posted by Andy-Gadget
And the oil cooler, above the sprocket, it was a Tenere addition as well
Yep you're right
metropolis2k is offline   Reply With Quote
Old 10-13-2010, 11:16 PM   #18
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
Originally Posted by BIG ED XT FAN
Wow! Wish we could a get a bike like this one!!
If you have been a very bad boy all year. Santa will leave the remnants of a motorcycle on your doorstep
Thank for that. I was thinking along the same lines. My brother is dent puller on cars and uses a form suction cup and slide hammer.
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 CS
Old bikers don't get old by accident.
Just Dan is online now   Reply With Quote
Old 10-13-2010, 11:33 PM   #19
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
Did I mention I hate using paint stripper.
A couple of mates suggested that I should get the frame sand blasted. I thought good idea, but I just have a go myself with some paint stripper and a buff on the end of a drill. To see what happens.
15 mins later. Emptied a cup of bull dust (Sand ) out of the back bone.
2 hrs later, sort of half done. After the frame is finished being stripped. I go over it with some 400 wet and dry to remove the last of the rust.
I thought I apply the same process to the tank. With not much luck. The tank has been painted 3 times in it life and I hope it is not the layers of paint holding the fuel in.
Found out today this Tenere, is a very early one. In that it has a 28 Litre tank instead of a 32 Litre that came out on the 84 model.
Also picked up the engine today. Complete with gear lever weld to the input shaft. Oh joy with a dremel. The engine has been missing a oil filter cover and spark plug for a couple of years
81' BMW R100 CS
Old 10-15-2010, 01:23 AM   #20
metropolis2k
Oddometer: 425
Really? I thought the 34Ls all had the bigger 28L (sometimes quoted as 30L) tank and the only size reduction came with the 1VJ because of the airbox moving under the tank?
Old 10-15-2010, 01:58 AM   #21
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
This is where I need Andy to chime in here. From what I gather. In Aus the 83 came with a 28 Litre tank and the 84 on came with a 32 Litre tank.
81' BMW R100 CS
Old 10-15-2010, 02:08 AM   #22
mb8
mb8's Avatar
Oddometer: 194
Orange L0 650 V-Strom
mb8 is offline   Reply With Quote
Old 10-15-2010, 02:43 AM   #23
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
Spent another couple of hours with the paint stripper this arvo. Just got to do some cleaning up. That will most likely take longer than the stripping part
On the way home from work. Picked up one of these and some grit. Had a bit of a go without much success. Made a lot of mess without much benefit. Should read the instructions. I think was holding the gun too close to the job.
Looks like I will be doing some welding on the week end fixing up broken bits and few cracks I have found.
Do you think I need a new guard?
Where is a good place to order steering head bearings, swing arm bearings & fork seals from?
81' BMW R100 CS
Old 10-15-2010, 08:16 PM   #24
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
Did I mention that I dislike pant stripper. Finished that messy job. Now onto cleaning up and start on welding up some cracks and remove the old steering head cups from the frame.
Am I getting any where? The dints and rust is not as bad as I thought. Also will get some POR15 and line the inside of tank while it is naked.
81' BMW R100 CS
Old 10-15-2010, 08:41 PM   #25
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Those 34L tanks are REALLY thin.
I got one and its been welded on too.
the metal feels 1/2 as thick of the metal used on the XT550.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 10-15-2010, 09:07 PM   #26
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
Yep, they are the thin side. Hopefully I can bend up some steel and poke the inside and try and push the dint out a bit.
81' BMW R100 CS
Old 10-15-2010, 10:22 PM   #27
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
That's it for a Saturday arvo. Welded up the rear indicator mounts, coil mounts and those pesky steering head bearing cups.
Next stage painting the frame...
81' BMW R100 CS
Old 10-16-2010, 05:45 PM   #28
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
Time to brake out the spray guns.
Most of the restoration threads I have read opt for powder coating as their best friend. While powder coating does has some advantages. Like someone else doing the job. Powder coating frames on trail bikes might not be the be best thing. Powder coating is tough, but brittle. Once a stone chip starts, it quickly spreads and starts lifting the rest.
I going for the tried and tested method that was done on frames from the 40's on through the 70's. If you own a airhead you might just reconize the colour of the primer. I have gone for an epoxy based enamel. Not quick drying and takes a good week to cure. When properly dry, it is tough and flexiable.
I suppose 10 years of being a spray painter might be useful and hence my aversion of hating paint stripper. In a previous life. I have painted semis, buses, tractor, motorcycles and a few hundred aircraft. From F111, Macch MB326H, and parts of F-18's. As well as working in a panel shop for motorbikes.
81' BMW R100 CS
Old 10-16-2010, 06:17 PM   #29
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,867
subscribed.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 10-16-2010, 09:36 PM   #30
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,896
Shiny red paint. Just have to let it harden up for a week before putting the new steering head bearings in. Plenty more to get on with.
After painting the frame. Went over to Andy Gadget for a coffee. Might as well take over the lower triple clamps and press the bearing off. Feels like the bearing has been on for at least a million years. Nothing a bit of heat and a 30 ton press cannot handle.
81' BMW R100 CS
Times are GMT -7.   It's 12:58 AM.
