Old 10-11-2010, 10:25 AM   #1
Dieselboy OP
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,176
Pissed Another centerstand dead!
Dagnabit!
69,875 miles. Parking in the garage, no bags or cargo....
This is OEM #2. The first one died at 28553 miles (under warranty)
I'm considering the Hepco Becker as a replacement. Any negative comments on that one?
Dieselboy
The Adventure Continues
Dieselboy screwed with this post 11-21-2012 at 06:36 PM
Dieselboy is offline   Reply With Quote
Old 10-11-2010, 10:50 AM   #2
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,805
I have a used stocker. Pay shipping and it's yours.
johngil is offline   Reply With Quote
Old 10-11-2010, 11:20 AM   #3
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
Do tell?
PM sent
Dieselboy
Old 10-11-2010, 12:22 PM   #4
Toadride
Toadride's Avatar
Oddometer: 859
Ya, I can see the tubing material wearing out after that many miles. I may just cut, shape and weld an outer piece at the contact area to prevent that.
Old 10-11-2010, 12:30 PM   #5
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
I don't weld but that is a good idea. I was thinking about sleaving it with rubber but welding is a better idea.
It is just another design flaw. Lasts just long enough but not the life of the bike. I suspect it's another case of shaving material to save weight in the bottom line.
Dieselboy
Old 10-11-2010, 04:12 PM   #6
blender
Just another rider
Oddometer: 727
Originally Posted by Dieselboy
Dagnabit!
Have one on my F8GS, only 15K miles on it so far. The only minor quibble with it is the tang (or whatever it's called) to deploy the stand is a bit fiddly to get my toe in on it.
Steve
Madison, WI
blender is offline   Reply With Quote
Old 10-11-2010, 04:13 PM   #7
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
Are you running any bags? If so, interference?
Dieselboy
Old 10-11-2010, 04:18 PM   #8
CheckerdD
CheckerdD's Avatar
Oddometer: 1,307
The SW Motech would not fail the way yours did. it does not have the curve. See www.twistedthrottle.com By the way, you have almost exactly 10 times the mileage as I do on an 800GS. You got any other tips for us. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 10-11-2010, 04:28 PM   #9
lmclamore
Citation Collector
lmclamore's Avatar
Oddometer: 412
I've got the same problem with the OEM center stand on my 798. Sometimes I can smell the top of my boot getting seared after fishing around for the tang under there.
"An expert is someone who has made every mistake possible within a very narrow field of inquiry"
-Niels Bohr
lmclamore is offline   Reply With Quote
Old 10-11-2010, 04:34 PM   #10
lepoer
Oddometer: 18
With respect to the Hepco & Becker stand, I recently purchased one. Attempted to install myself as it said that you could use simple hand tools to install it. There was no way that I could get the springs to reach. I even tried an old drum brake spring puller to get them to reach. I beat the hell out of the center stand in the process and finally sent info about the spring length, etc to the seller who then forwarded the info on to H&B.
Still awaiting an answer. I am hoping that I was sent the wrong springs. Otherwise, I would expect you need to possess inhuman strength to install. Instructions included were no help with respect to order of installation or tips on how to get the springs connected.
Your results may vary, of course, but thats my $.02.
Bernadette, '09 F800GS. Jesse Odyssey II bags. Givi engine guards. Sargent Touring seat. Twalcom wind deflector. Stebel Nautilus compact horn (Can you hear me now!?). Kaoko throttle lock. PIAA Cross County Auxiliary lights. TT HID Compact 2 Headlamp, Best Rest Headlight protector & Aux light mount. Metal mule radiator guard. Altrider skid plate.
lepoer is offline   Reply With Quote
Old 10-11-2010, 04:54 PM   #11
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
Well SW Motech is moving up the list.
As to tips, no. My technique appears to have no patent and is common for this crowd: ride, repair, repeat.
It ain't perfect and I don't mind (much ) I love riding this thing!
Dieselboy
Old 10-11-2010, 04:58 PM   #12
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
Originally Posted by lepoer
... There was no way that I could get the springs to reach...finally sent info about the spring length, etc to the seller who then forwarded the info on to H&B.
Still awaiting an answer....
Well that's painful. When you get the answer post back. It may influence my purchase.
Dieselboy
Old 10-11-2010, 05:39 PM   #13
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,176
Looking at these two stands, the HB appears to be half the tang and angled compared to the SW Motech. I would think the HB would be easier to lauch.
Hepco Becker
SW Motech
Dieselboy
Old 10-11-2010, 05:41 PM   #14
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,805
I prop my bike up on the SW centerstand barefooted. No shit.
Old 10-11-2010, 05:51 PM   #15
ilvecchio
Oddometer: 233
An old trick is to bend the spring one way and insert a penny into the gap created by the bending. Then bend the spring the other way and insert another penny. Now the spring is a little bit longer. Keep doing this until the spring is long enough to attach to the centerstand when it is up. Then push the stand down and let the pennys fall out.
ilvecchio is offline   Reply With Quote
Times are GMT -7.   It's 08:02 PM.
