Old 01-18-2014, 01:57 PM   #17761
john_aero
john_aero's Avatar
Oddometer: 1,173
went out today
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 01-18-2014, 02:24 PM   #17762
xTomKx
xTomKx's Avatar
Oddometer: 195
2012 KTM 990A, 2006 KTM 250 2s, and many other toys
xTomKx is offline   Reply With Quote
Old 01-18-2014, 08:54 PM   #17763
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,255
NSFW
Naked bike
She has 74,000 miles on her so I pulled the valve covers to check out the top end before my next trip only to find the cam chains to be a bit on the stretched side. I wanted to make it to 100,000 miles before a rebuild so I was only going to replace the cam chains then put it back together. Now I am thinking I will go further and do the rings and valves now. The main transmission shaft is showing excessive wear at the clutch basket which could explain the vibrations that I feel.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 01-19-2014, 04:17 AM   #17764
Pyndon
Pyndon's Avatar
Oddometer: 2,555
It is normal for the clutch basket to have play, it sits on roller bearings. I doubt it if the shaft that is warn at all. I replaced my countershaft at 65,000 as it was badly warn where the drive sprocket sits. Other that this, the gearbox was sweet. If you rebuild the motor, be sure to do all the updates inside to help with lubrication and oil pressure. Also check your base gasket faces for corrosion since your bike is older than 05.5 otherwise you'll be into another rebuild in no time. Mine is at 95,000 now....almost there! Problem is now, I have too many other cool bikes to ride like 690RR's that I hardly use the 950 now. You might want to check that steel band on your clutch basket too, in fact, I'd just chuck it and fit one of the later baskets, too much damage if that baby shits the bed! Check my thread, it's all in there.
Pyn
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 01-19-2014, 05:14 AM   #17765
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,255
Thanks, My flywheel & crank are keyed, I already did the spring and sending unit, I'm undecided on the newer balancer. I'll check for more items.
Michael
Old 01-19-2014, 06:13 AM   #17766
Pyndon
Pyndon's Avatar
Oddometer: 2,555
You cannot fit the new balancer shaft without changing the engine casing....so my guess is you do not want that expense?
My KTM 950 Story
Old 01-19-2014, 06:26 AM   #17767
charlie264
charlie264's Avatar
Oddometer: 8,366
Comparing the basket roller bearing at 20k miles, noticeable less play with the new one. I've not found the oil jet to be blocked when I've checked.....
Old 01-19-2014, 06:31 AM   #17768
Pyndon
Pyndon's Avatar
Oddometer: 2,555
Right, but that's not the shaft thats wearing, that was my point. And for what its worth, I've still got the original roller bearing in my motor at 95,000miles. Just saying, from experience.
My KTM 950 Story
Old 01-19-2014, 08:41 AM   #17769
charlie264
charlie264's Avatar
Oddometer: 8,366
I was surprised in the amount of play with the old bearing, and the new had noticeable lass lateral play. On the old bearing, the set of rollers closest to the booster looked more worn. The shaft was fine as was basket, were you running a larger clutch jet? Maybe I've been unlucky, it wasn't a cheap part, bearing shop didn't have in stock so I ordered from stealer.
Old 01-19-2014, 09:26 AM   #17770
KTM Deano
Oddometer: 72
Need to get a few pics up of mine soon.
KTM Deano is offline   Reply With Quote
Old 01-19-2014, 09:27 AM   #17771
stupot
stupot's Avatar
Oddometer: 124
stupot is online now   Reply With Quote
Old 01-19-2014, 11:25 AM   #17772
Miket9876
Oddometer: 21
Originally Posted by JK1 View Post
No that looks like Rades screen.
Correct, Rade's Screen.
Miket9876 is offline   Reply With Quote
Old 01-19-2014, 11:51 AM   #17773
Pyndon
Pyndon's Avatar
Oddometer: 2,555
were you running a larger clutch jet?.
No.
My KTM 950 Story
Old 01-19-2014, 01:53 PM   #17774
charlie264
charlie264's Avatar
Oddometer: 8,366
No.
Unlucky me.
Old 01-19-2014, 02:41 PM   #17775
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,841
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Times are GMT -7.   It's 04:00 AM.
