Old 10-24-2010, 02:15 AM   #31
Wildman OP
In my castle
Wildman's Avatar
Oddometer: 18,083
Originally Posted by Motoriley
... so bought the Roc Stompas... and they look good to boot.
Got any pics?
Ridden; GBR CYM DEU FRA ESP AND MCO ITA BEL SCT LUX CHE SMR LIE AUT NLD POL LTU LVA EST SWE FIN NOR DNK CZE SVK HUN ROU BGR GRC MKD SRB ALB MNE BIH HRV SVN MYS IRL BRA MAR PRT ARE USA ISL JPN MLT Planning; AUS TUR MDA UKR MEX BLR MNG RUS KAZ TJK KGZ SEN ZAF ZMB MWI NZL IND CPN
Wildman is offline   Reply With Quote
Old 10-24-2010, 11:09 AM   #32
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,685
RocStompa on the F800GS
Here ya go. You can see when it is folded up it just clears the spring lug for the side stand.
Originally Posted by Wildman
Got any pics?
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 10-24-2010, 11:39 AM   #33
danman
tumbling tumbleweed
Oddometer: 188
++ on Pivot Pegs. One of the first mods I do on my bikes (second is progressive fork springs). Have them on the F800 and the 1200GS. Have used them off road on Colorado passes and in Mexico. I just float along on the rough sections while the bike moves freely below me. Love not having to adjust the shifter angle when switching between street shoes and off road boots, just 'pivot' the peg down and its business as usual. Haven't tried any of the other good aftermarket pegs out there.
danman is offline   Reply With Quote
Old 10-24-2010, 01:13 PM   #34
Wildman OP
In my castle
Wildman's Avatar
Oddometer: 18,083
Here ya go...
Old 10-25-2010, 09:37 AM   #35
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
Pivotpegz for me. I am very happy with them, without them, I can't change gear with my offroad boots, irrespective of whether or no I'm standing on them.
I'm 6'2", doing mostly road riding, but I stand up road riding when the surface is bad.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 10-25-2010, 12:08 PM   #36
Singletrack_mind
Cave Man
Oddometer: 433
adjusting rear brake height
Originally Posted by MCMXCIVRS
I'm not sure if your's is different from my GS, but on mine the only way to change the resting height of the lever would be to bend it up or add a thicker pad on top of it. You can adjust the pushrod to change the free travel in the lever before the brake is applied, but that still leaves the lever lower than the stock foot peg.
What I did to raise my brake pedal's resting height was to remove the pedal from the bike and grind a small amount off the lever at the spot where it hits the stop on the frame. Take it easy, do it in stages so you don't go too far. Not to worry though, if you did grind too much, or someday want to re-locate for different pegs or something, a blob of weld on the contact point will let you start over.
Singletrack_mind is offline   Reply With Quote
Old 10-26-2010, 12:39 PM   #37
Trout
Trout's Avatar
Oddometer: 341
Originally Posted by Bucko
I bought the Fastways. They're reported to knock the kickstand spring peg off if you fall wrong on the left side...so I've always fallen to the right I mounted them in the low position and am very happy with them.
I wanted Roc Stompas, but they were out of stock and out of the country and I needed something wide to give my arches some reprieve on a long trip.
Thought about the PivotPegz, but my Achilles tendons bother me enough as it is, and I figured I didn't need the extra flexion exacerbating an already painful condition.
They did knock the spring peg off on my bike. Thankfully I was only a couple blocks from home. Ground the remaining nub down, drilled and tapped it - put a screw in. Peg now folds without hitting anything. What a pain in the ass if it happened on the trail.
I would recommend avoiding the Fastway pegs.
If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. -Thoreau
Trout is offline   Reply With Quote
Old 10-27-2010, 11:42 AM   #38
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,763
Originally Posted by NVTS
They don't fit. Curiously the 12gs bashplate won't fit either.
Why didn't they fit? the bracket spacing and angle is the same
The fastways that I first put on my bike were 12GS ones, before fastway was even selling them for the 8.
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is offline   Reply With Quote
Old 10-27-2010, 03:53 PM   #39
Motoriley
Motoriley's Avatar
Oddometer: 2,685
Thumbs down Fastway to a broken part
They fit but when the left side folds up it breaks off the the little nub that holds the sidestand spring.
Motoriley screwed with this post 10-28-2010 at 06:27 AM
Old 10-27-2010, 04:37 PM   #40
Mark5PA
Mark5PA's Avatar
Oddometer: 1,758
That's a great idea! Every other bike I've owned had an easily adjustable splined lever. Your idea is golden. You should get a prize or something. Haven't even looked at that contact point sense I've seen this post, but I wonder if a drill & tap with a small locking bolt, for easy adjustment is possible?
Great idea SingleTrack.
Mark
F800GS
Endless Mountains,PA
Mark5PA is offline   Reply With Quote
Old 10-27-2010, 09:24 PM   #41
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,763
They fit but when the right side folds up it breaks off the the little nub that holds the sidestand spring.
left, btw.
Old 10-28-2010, 06:28 AM   #42
Motoriley
Motoriley's Avatar
Oddometer: 2,685
Left and right
If you crash hard enough on the right sometimes the left peg will fold up....
left, btw.
Old 10-29-2010, 05:40 AM   #43
Tor
Native Viking
Tor's Avatar
Oddometer: 805
Got the Pivot Pegz in yesterday (actually my wife gave them to me ), and installed them. Big difference (much better) standing. A note: The right peg feels like it has quite a bit more lateral slack / movement on the original pin after install. The left feels more solid. Is it just me?
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor screwed with this post 10-29-2010 at 05:55 AM
Tor is offline   Reply With Quote
Old 10-29-2010, 07:02 AM   #44
Motowalt
UNSTOPPABLE!
Motowalt's Avatar
Oddometer: 417
++1 on the Pivot Pegz
Ran them on my 1150GS and now on the little 800GS
Worked well for me from Big Bend to Engineer Pass as well as on the road.
If they made em for my SV650 I'd buy em!
AMA
Motowalt is offline   Reply With Quote
Old 11-01-2010, 10:15 PM   #45
AbeFroman
AbeFroman's Avatar
Oddometer: 88
I know it's a BMW, but anybody got a lead on something that might just space these pegs down an inch or two? Like a $10 piece of metal someone's selling for $20? I could use that, but I'll keep dealing with cramped knees short of spending $60 a piece to ease them. Cripes my first dirtbike costed less than these pegs.
AbeFroman is offline   Reply With Quote
Times are GMT -7.   It's 04:30 AM.
