Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 04-17-2013, 09:58 AM   #841
fanatic291
Desert Tortoise
fanatic291's Avatar
Oddometer: 815
Originally Posted by bent forks View Post
Here is something for new dirt riders that I got from a friend that is helping a dirt newbe
1. In order to go fast, you must first learn to go slow.
Go into a paved parking lot. Do slow (1'st gear) figure 8's. (big turn 8's) Do it sitting down. Comfortable?...well good. That's the last time you sit down for the rest of this exercise.
Now do it standing up (all the way through the figure 8)
Try it with your knees gripping the tank and moving the bike through the turn using only "body English" and transfer of weight. Don't steer the bike through the turn, MAKE it turn with weight transfer.
Be "loose" on the bike...You should have a snug-to-firm grip on the handgrips, with your elbows and shoulders loose.
Now do it WITHOUT your knees gripping the tank and just transferring your weight through the footpegs.
You will notice that the throttle becomes your friend. As the bike wants to fall to the inside of the turn, a little more throttle will save you and stand the bike up automatically. Notice this. Feel it. The throttle is your friend.
Take notice of how the bike reacts between all of the above.. sitting down...steering through the turn...standing up..."guiding" the bike with weight transfer ... standing up-gripping the bike with your knees.. Standing and not gripping- "guiding" through weight transfer on the pegs.
Do a hundred reps of the above exercise.
When you get comfortable with it....tighten up the turns.
Still comfortable?...put some chalk marks on the pavement on the exit of the turn and pass your front wheel over the chalk mark EVERY time.
Do a hundred of these (many).
Every time you go for a ride find an empty parking lot and practice this.
Comfortable?
Now move the whole exercise to dirt.
Find a field and repeat. Use a couple of twigs to simulate chalk marks.
Do a hundred reps.
Comfortable?
Move the whole exercise to looser dirt (less traction)
Things to learn...
Notice how weight transfer affects the bike differently depending on whether its being fed into the bike through the handlebars vs the tank (knee grip on the tank) vs the footpegs.
Learn that the throttle is your friend...a quick burst of power can bail your ass out of trouble (on dirt...most of the time.)
Brakes.
Don't be afraid of the front brake. Learn it. The front brake, for beginners on the dirt is like having a pet Bengal tiger. It can bite you, maul you, and hurt you real bad....but if you treat it correctly, and learn its habits it can save your butt.
You must learn to feather the front brake.
Do this exercise sitting down at first...its easier...and slide your weight forward on the seat to set up for the turn.
At your practice field (dirt) get going in a straight line, get the bike up into 2nd or 3rd gear (a comfortable speed), start slowing down to make a turn (use the brakes) feather the front brake...pull gently in on it...easy. NEVER lock it up.
Imagine there is an egg between your fingers and the brake lever...you must squeeze as hard as you dare with out breaking it..
As you progressively lean into the turn you should progressively let off on the brake.
NEVER pull the brake on hard while leaned over...it will bite you.
Learn to be gentle on the lever (at first) even if you are only putting the brake on 1%.
Practice right and left turns while doing this. Do more on the side you are least comfortable...so right and left become second nature.
When you are comfortable with that...increase your speed where you will require more braking to set up for the turn.
Now use more brakes. Always both brakes.
Use the front 2% then 5%....then 20% etc.
Learn to vary the proportion of front brake vs back brake.
Do most of your braking while the bike is vertical.. progressively letting off the brakes in proportion to the lean angle of the bike as you enter the turn.(You can...and should...practice this on normal road curves).
Do a hundred reps.
Comfortable?
Now practice it standing up ...and only upon turn entry should you plonk onto the seat, move your weight forward, lean the bike over while progressively letting off the brakes. This is all done in an eyeblink.
Practice.
...and then practice some more.
Any empty parking lot is an opportunity to practice.
THINK.
Feel the bike. Think and feel what the bike is doing as you shift your weight from one footpeg to another.
Think and feel what happens to the bike as you progressively squeeze the front brake harder. Try this on pavement. Try it standing up in your empty parking lot/practice pad.
...and so on....
an add on would be to practise some figure 8 using the clutch and throttle to control your speed as
slipping the clutch is needed to climb over rocks, trees and stuff
Jack
Thanks for that. I have been doing a lot of the parking lot games at my son's elementary school. Figure 8's between the light poles. I am glad that my downhill mountain bike has hydrolic breaks. It is really easy to lock up the front disc on a 25lb bike, so I have learned respect early.
Thanks for all of the advice.
Looks like I won'y be able to make the 7 Springs to Bloody Basin ride. I think it is too much mileage for my skill level. I will try to catch the next one when I am a little more comfortable on the bike.
Thanks Bill for the invite.
fanatic291 screwed with this post 04-18-2013 at 01:08 PM
fanatic291 is online now   Reply With Quote
Old 04-22-2013, 06:36 PM   #842
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 602
Coolidge Dam 4/27/13
All,
Here is a plan for this Saturday for anyone who would like to join Jay and I on a ride to the Coolidge Dam Saturday.
Meet at the Queen Creek Cafe at 8:30 for those wanting breakfast and 9:30 for those that need more sleep time. Head to the Dam via Florence Kelvin Highway to Winkleman then up AZ 77 to Globe.
We will then make a stop in the old town of San Carlos.
On the way back we can add a trip up Pinal Peak time permitting and take the 60 back to town. Maybe stop in Superior for some Mexican food.
This will be the last ride I post for a while as I will be heading to Spain for a couple of weeks of riding.
For anyone that would like to go please feel free to join us.
Bill
IBRiding is offline   Reply With Quote
Old 04-22-2013, 08:55 PM   #843
WayFar
Oddometer: 153
That sounds like a good time. Got room for a noob?
"Down, Right, Aft, WHEEEE!!!!!!!'
1973 FL
2006 Uly
WayFar is offline   Reply With Quote
Old 04-22-2013, 09:15 PM   #844
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 602
Wayfar,
Well since I am a noob as well you are more than welcome.
Bill
Old 04-23-2013, 01:58 PM   #845
WayFar
Oddometer: 153
Cool, I'm in.
1973 FL
2006 Uly
Old 04-23-2013, 04:25 PM   #846
WJP4
Oddometer: 177
Hey Bill, If my shoulder that I banged up yesterday feels better I'll meet you guys at Flor. Kelv. Hwy. Let you know later in week. Wade
WJP4 is offline   Reply With Quote
Old 04-23-2013, 08:34 PM   #847
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 602
Wade,
Good to hear from you and sorry about the shoulder. If you decide to go I will PM you my cell number and you can call when you get to Florence.
Bill
Old 04-26-2013, 08:06 AM   #848
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 602
Originally Posted by IBRiding View Post
All,
Bill
Just bumping this up for anyone this is intrested in joing us.
Old 04-26-2013, 10:08 AM   #849
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 27,456
I don't know which way you guys are headed but I've always wanted to try this road out to Coolidge Dam.
Looks like fun.
You guys enjoy the ride.
fingerdoodle
cyberdos is online now   Reply With Quote
Old 04-26-2013, 12:14 PM   #850
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 602
Looks like fun.
Julio,
I was looking at that myself. Do you know if you need any special permits for the reservation and have you any information on how difficult it is?
Bill
Old 04-26-2013, 12:27 PM   #851
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 27,456
If you stay on marked roads there's no permits needed unless you're camping.
I have no idea how difficult that route is but give it a shot and let us know.
if it gets too snotty you could always back track and head towards Globe.
This would make a nice day's loop.
fingerdoodle
Old 04-26-2013, 12:40 PM   #852
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 27,456
hmm...according to this you do need a permit.
http://www.sancarlosapache.com/Permits_Information.htm
You will need a recreation permits for most of the Apache Nations such as the following San Carlos Tribal Government rates: ($10 per day) to camp, picnic, hike, or venture onto back roads unless you have a fishing, hunting, or special-use permit.
The closest one to the route would be the Apache Gold Casino.
I've visited the dam (took Coolidge Dam Rd. all the way) and I didn't have a permit. Maybe I just got lucky.
fingerdoodle
Old 04-26-2013, 01:11 PM   #853
k9bite
Oddometer: 18
Florence-Kelvin Hwy
I road this today and saw the strangest thing. I stopped for a snack right where the dirt meets pavement, on the east end. On the south side of the road, on top of a low saguaro arm, there was a dead coyote pup. I'm guessing a large bird deposited it there maybe. If you guys end up going that way, see if it is still there.
Todd
k9bite is offline   Reply With Quote
Old 04-26-2013, 02:11 PM   #854
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,887
I'm up for a run to the dam but can't do it this weekend...those routes look interesting...
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is online now   Reply With Quote
Old 04-26-2013, 02:12 PM   #855
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 602
They try and make this harder than it needs to be. Their website is very out of date. Apache Gold does not sell permits anymore. The closest I can find in the Circle K in Globe. $10.00 per person.
Times are GMT -7.   It's 01:28 PM.
