Go Back   ADVrider > Riding > Regional forums > West – California, the desert southwest and whatever is left
Old 04-15-2013, 06:34 PM   #901
azredline
Wobbly Adventurer
azredline's Avatar
Oddometer: 504
Julio,
Cool video, the young'un looks to be tearin' it up already. Well done!
Steve in AZ...
Time is the greatest teacher...but it kills all the students!
azredline is offline   Reply With Quote
Old 04-15-2013, 06:57 PM   #902
fanatic291
Desert Tortoise
fanatic291's Avatar
Oddometer: 749
Thanks Bill-
I can't wait to get comfortable on the bike, so I can go see some of your more scenic rides.
fanatic291 is offline   Reply With Quote
Old 04-15-2013, 09:04 PM   #903
750Volts! OP
India or bust!
750Volts!'s Avatar
Oddometer: 446
Just don't ask Bill to take you to Mount Lemon on your maiden off road voyage. He has a bad track record.
-Paul
Julio, Congrats on being a good Dad and putting your priorities where they belong dude. Just as my Amigo said...
750Volts! is offline   Reply With Quote
Old 04-16-2013, 11:07 AM   #904
fanatic291
Desert Tortoise
fanatic291's Avatar
Oddometer: 749
My buddy bailed on me for this Saturday. Does anyone want to Put Put up 4 peaks road? I want to go in the morning and do an out and back along the fire road.
I will ride slow (Never been there and a new rider)
I will start my ride at the Walgreens at Power and Thomas at 7:00 if someone else is interested in riding.
fanatic
Old 04-16-2013, 11:19 AM   #905
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 601
fanatic291
If you don't have any takers feel free to join us on this ride:
http://advrider.com/forums/showthread.php?t=878235
It will be very easy and is also a great ride.
IBRiding is online now   Reply With Quote
Old 04-16-2013, 12:50 PM   #906
fanatic291
Desert Tortoise
fanatic291's Avatar
Oddometer: 749
Thanks for the heads up.
I will try to make your ride. I am brand new to adventure riding. I did 90 miles up in prescott national forest with some friends and loved it.
Hopefully I will see you guys on Saturday.
Old 04-16-2013, 03:21 PM   #907
bent forks
bent forks's Avatar
Oddometer: 380
New riders
Here is something for new dirt riders that I got from a friend that is helping a dirt newbe
1. In order to go fast, you must first learn to go slow.
Go into a paved parking lot. Do slow (1'st gear) figure 8's. (big turn 8's) Do it sitting down. Comfortable?...well good. That's the last time you sit down for the rest of this exercise.
Now do it standing up (all the way through the figure 8)
Try it with your knees gripping the tank and moving the bike through the turn using only "body English" and transfer of weight. Don't steer the bike through the turn, MAKE it turn with weight transfer.
Be "loose" on the bike...You should have a snug-to-firm grip on the handgrips, with your elbows and shoulders loose.
Now do it WITHOUT your knees gripping the tank and just transferring your weight through the footpegs.
You will notice that the throttle becomes your friend. As the bike wants to fall to the inside of the turn, a little more throttle will save you and stand the bike up automatically. Notice this. Feel it. The throttle is your friend.
Take notice of how the bike reacts between all of the above.. sitting down...steering through the turn...standing up..."guiding" the bike with weight transfer ... standing up-gripping the bike with your knees.. Standing and not gripping- "guiding" through weight transfer on the pegs.
Do a hundred reps of the above exercise.
When you get comfortable with it....tighten up the turns.
Still comfortable?...put some chalk marks on the pavement on the exit of the turn and pass your front wheel over the chalk mark EVERY time.
Do a hundred of these (many).
Every time you go for a ride find an empty parking lot and practice this.
Comfortable?
Now move the whole exercise to dirt.
Find a field and repeat. Use a couple of twigs to simulate chalk marks.
Do a hundred reps.
Comfortable?
Move the whole exercise to looser dirt (less traction)
Things to learn...
Notice how weight transfer affects the bike differently depending on whether its being fed into the bike through the handlebars vs the tank (knee grip on the tank) vs the footpegs.
Learn that the throttle is your friend...a quick burst of power can bail your ass out of trouble (on dirt...most of the time.)
Brakes.
Don't be afraid of the front brake. Learn it. The front brake, for beginners on the dirt is like having a pet Bengal tiger. It can bite you, maul you, and hurt you real bad....but if you treat it correctly, and learn its habits it can save your butt.
You must learn to feather the front brake.
Do this exercise sitting down at first...its easier...and slide your weight forward on the seat to set up for the turn.
At your practice field (dirt) get going in a straight line, get the bike up into 2nd or 3rd gear (a comfortable speed), start slowing down to make a turn (use the brakes) feather the front brake...pull gently in on it...easy. NEVER lock it up.
Imagine there is an egg between your fingers and the brake lever...you must squeeze as hard as you dare with out breaking it..
As you progressively lean into the turn you should progressively let off on the brake.
NEVER pull the brake on hard while leaned over...it will bite you.
Learn to be gentle on the lever (at first) even if you are only putting the brake on 1%.
Practice right and left turns while doing this. Do more on the side you are least comfortable...so right and left become second nature.
When you are comfortable with that...increase your speed where you will require more braking to set up for the turn.
Now use more brakes. Always both brakes.
Use the front 2% then 5%....then 20% etc.
Learn to vary the proportion of front brake vs back brake.
Do most of your braking while the bike is vertical.. progressively letting off the brakes in proportion to the lean angle of the bike as you enter the turn.(You can...and should...practice this on normal road curves).
Do a hundred reps.
Comfortable?
Now practice it standing up ...and only upon turn entry should you plonk onto the seat, move your weight forward, lean the bike over while progressively letting off the brakes. This is all done in an eyeblink.
Practice.
...and then practice some more.
Any empty parking lot is an opportunity to practice.
THINK.
Feel the bike. Think and feel what the bike is doing as you shift your weight from one footpeg to another.
Think and feel what happens to the bike as you progressively squeeze the front brake harder. Try this on pavement. Try it standing up in your empty parking lot/practice pad.
...and so on....
an add on would be to practise some figure 8 using the clutch and throttle to control your speed as
slipping the clutch is needed to climb over rocks, trees and stuff
Jack
bent forks is online now   Reply With Quote
Old 04-16-2013, 03:57 PM   #908
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 26,599
too long, didn't read.
Presione dos para español.
cyberdos is offline   Reply With Quote
Old 04-16-2013, 06:09 PM   #909
750Volts! OP
India or bust!
750Volts!'s Avatar
Oddometer: 446
Nice Jack, Thanks
Old 04-16-2013, 06:12 PM   #910
redeye-az
redeye-az's Avatar
Oddometer: 529
ya... and no pictures or cartoons either...!!...
redeye-az is offline   Reply With Quote
Old 04-16-2013, 08:09 PM   #911
DOD
idiot dirt rider
DOD's Avatar
Oddometer: 2,365
Fill your bike with gas. Ride until empty. Repeat.
Jack
Here you go Julio. I summarized it for you.
-dod
This is my only chance to assemble a disreputable past
DOD is offline   Reply With Quote
Old 04-16-2013, 09:56 PM   #912
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 601
-Paul
Paul,
That's is what I get for going way to fast. I think I might have broken 25 MPH on that mountain
Old 04-16-2013, 10:58 PM   #913
750Volts! OP
India or bust!
750Volts!'s Avatar
Oddometer: 446
I hear you brother, but you just can't let a good legend die that easy. Nobody will ever believe the truth, that we were riding nice and easy and someone hit a bump in the road and ended up being twisted and contorted like a pretzel with multiple fractures and contusions. It just sounds better that we were going beyond the limits of man and machine and the noob was a casualty of totally wild and reckless behavior!
Old 04-17-2013, 09:58 AM   #914
fanatic291
Desert Tortoise
fanatic291's Avatar
Oddometer: 749
Comfortable?
Do a hundred reps.
Comfortable?
Things to learn...
Brakes.
Do a hundred reps.
Comfortable?
Practice.
THINK.
...and so on....
Jack
Thanks for that. I have been doing a lot of the parking lot games at my son's elementary school. Figure 8's between the light poles. I am glad that my downhill mountain bike has hydrolic breaks. It is really easy to lock up the front disc on a 25lb bike, so I have learned respect early.
Thanks for all of the advice.
Looks like I won'y be able to make the 7 Springs to Bloody Basin ride. I think it is too much mileage for my skill level. I will try to catch the next one when I am a little more comfortable on the bike.
Thanks Bill for the invite.
fanatic291 screwed with this post 04-18-2013 at 01:08 PM
Old 04-22-2013, 06:36 PM   #915
IBRiding
Forever Grateful
IBRiding's Avatar
Oddometer: 601
Coolidge Dam 4/27/13
All,
Here is a plan for this Saturday for anyone who would like to join Jay and I on a ride to the Coolidge Dam Saturday.
Meet at the Queen Creek Cafe at 8:30 for those wanting breakfast and 9:30 for those that need more sleep time. Head to the Dam via Florence Kelvin Highway to Winkleman then up AZ 77 to Globe.
We will then make a stop in the old town of San Carlos.
On the way back we can add a trip up Pinal Peak time permitting and take the 60 back to town. Maybe stop in Superior for some Mexican food.
This will be the last ride I post for a while as I will be heading to Spain for a couple of weeks of riding.
For anyone that would like to go please feel free to join us.
Bill
Times are GMT -7.   It's 10:01 AM.
