10-23-2010, 07:55 PM
#1 |
Someday...
Oddometer: 318
Cheap LED visibility lights
So, I decided to replace my H3 halogen driving lights with some LEDs. The halogen were just drawing too much power; 35 watts on each side, + heated grips, GPS, USB BlackBerry charger, head lights etc.
I ordered 4 of these: ![]() from http://www.plasmaled.com/high_power_module.htm So then I was trying to figure out how to mount them. I took the bulbs out of my H3 lights and saw that the hole in the back was about 5/8 of an inch...Lights are close to 1". Hmm. Realizing that if I messed this up I would have NO lights, I broke out the trusty Dremel and hacked a bigger hole in the back of the housing. Some two-sided mounting tape to provide some cushioning and some stick-to-it-iveness and voila! ![]() So that takes care of two of them. I wanted to mount two others higher up on the bike, so I wracked my brain trying to come up with a mounting solution. I finally decided to go low tech and bought a couple of 1" pipe brackets from Home Depot. I decided to mount the two remaining lights on the hand-guards. ![]() Seems brighter... ![]() |
11-04-2010, 10:30 AM
#2 |
Oddometer: 323
nice! Im curious, how well do those LEDs work for you? how many do you think you would need to eliminate a traditional headlight all together? thanks
11-04-2010, 10:10 PM
#3 |
Lupie on a Mission
Oddometer: 390
Not these. I have the 3w ones on my FZ. They do great at night when the lights are on bright to light the void that is left. I don't think I'd use these in lieu of headlights though.
Training to slay theWolf Check out theWolfTamer Chronicles, my blog about my motorcycle life |
