Old 10-24-2010, 12:33 PM   #1
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
HyperPro 1150GS Steering Damper
HyperPro doesn't make a steering damper [dampener, dampner, stabilizer] for the 1150GS. In fact, the only 1150GS damper I can find is the one by Ralle-Moto which costs around $900USD at today's exchange rates. Too spendy for me!
Here's what I want to know--is there any reason I couldn't buy the HyperPro damper (with mounts) designed for the 1200GS and install it on my 1150GS? Total cost would be around $450.
[Edit: Feb 15 2011--go to post 22 to see my reply to this question.]
Here's are pics of the 1200GS damper as installed by another inmate--
HyperPro sells fork clamps of all different sizes so I won't have a problem connecting the damper arm to the fork. That's a ball-and-socket "helm" joint there at the end of the arm.
For the telelever, the HyperPro mount clamps to the body (tube) of the damper then the mount is bolted to the telelever.
Seems to me that I could simply drill a hole through my 1150 telelever and through-bolt it on. The only tricky part would be deciding where exactly to drill.
Why is this a bad idea?
WUMPA
Sidecardogs.com
DRONE screwed with this post 02-15-2011 at 11:36 PM
DRONE is offline   Reply With Quote
Old 10-24-2010, 12:36 PM   #2
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
Here is a drawing of a clamp similar to the telelever clamp I'm talking about--
WUMPA
Sidecardogs.com
Old 10-24-2010, 01:45 PM   #3
rd1900
Oddometer: 170
I think this is a fine idea, and am planning to do this on my 1150 as well, although I'll probably use an Ohlins damper. Ebay has lots of them, and as far as I can tell they are all the same except for stroke lenght.
I may fab a bracket to mount body to the telelever front ball joint, but I haven't got that far in my planning yet.
rd1900 is offline   Reply With Quote
Old 10-24-2010, 01:47 PM   #4
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,292
Does it require for the Telelever to be pulled for drilling or simply drill the required sized hole underneath using a hand drill? Please elaborate!
Thanks....
Abenteuerfahrer is offline   Reply With Quote
Old 10-24-2010, 02:34 PM   #5
Norsman
...a GSophile
Norsman's Avatar
Oddometer: 2,347
Will this suit you?
Seen at bestrest, made for 1150.
2004 BMW R1150GS ADV
My SmugMug...save $5 on a SmugMug account with this: tKOaEps81O7hN
my2wheels
Norsman is offline   Reply With Quote
Old 10-24-2010, 03:03 PM   #6
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
Originally Posted by Norsman
Will this suit you?
Already commented about that -- 2nd sentence of Post #1.
BTW, BestRest no longer lists it on their website. Not sure why.
WUMPA
Sidecardogs.com
Old 10-24-2010, 03:08 PM   #7
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
Thanks....
I wouldn't think you'd need to pull the telelever. Just jack up the front end then drill from the bottom up. But that's for the 1150. On your rig, I think it's a straight bolt-on deal. I'm sure if you contacted Klaus at EPM he could e-mail you a pdf with the 1200GS installation instructions.
WUMPA
Sidecardogs.com
Old 10-24-2010, 03:15 PM   #8
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
Originally Posted by rd1900
I think this is a fine idea, and am planning to do this on my 1150 as well...I may fab a bracket to mount body to the telelever front ball joint, but I haven't got that far in my planning yet.
Yes!! Sounds great! Fab one for me too. PM me with your PayPal address.
Really, I'm not kidding! In fact, I bet between the Oilhead forum and the Hacks forum we could find 10 guys who'd buy one.
WUMPA
Sidecardogs.com
Old 10-24-2010, 05:29 PM   #9
Norsman
...a GSophile
Norsman's Avatar
Oddometer: 2,347
I just pulled it from their website today... it's available, but to spendy as you mentioned.
my2wheels
Old 10-24-2010, 07:34 PM   #10
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
Your link is to the 1200GS damper. The 1150 damper is gone from the BestRest website though it was there a couple of weeks ago. However the Ralle-Moto 1150 damper can be ordered directly from Ralle-Moto for around $900USD. Link HERE.
WUMPA
Sidecardogs.com
Old 10-24-2010, 09:20 PM   #11
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 630
I'm interested...
Add me to the list!
---'99 BMW R1100GS
---'96 BMW R1100GS Mod Project ???
---'80 Honda CB750 Street Tracker Project
---'09 Vespa GT200 Granturismo
wrysingfeenix is offline   Reply With Quote
Old 10-24-2010, 09:57 PM   #12
PukaWai
PukaWai's Avatar
Oddometer: 677
Sounds like a good creative idea to me too. The only things I'd take a close look at would be 1.) Does the ball and socket joint swivel enough for the full range of motion of the suspension? 2.) The telelever has to handle a fair bit of force - wouldn't want to drill any holes in places where if would compromise its structural integrity.
PukaWai is offline   Reply With Quote
Old 10-24-2010, 10:55 PM   #13
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
1.)The fork tube and the telelever move in unison with each other. The helm joint needs a very small range of motion to handle the suspension movement. The back-and-forth steering movement is the bigger challenge. 2.) True dat. That was really what I was asking about in Post #1. But RD1900's idea of using a bracket secured by the pivot joint would get around that problem.
WUMPA
Sidecardogs.com
Old 10-25-2010, 10:07 AM   #14
rd1900
Oddometer: 170
Looking a bit closer, there is a stud with a washer and nut on top of the telelever arm at the fork joint. Replacing this washer with a bracket for the damper body mount should be easy. A fork tube clamp can mount the damper piston to the fork (standard method).
I think I'll mock up a washer replacement bracket with damper mount that also incorporates a steering stop protector (a la Touratech)
Old 10-25-2010, 11:52 AM   #15
DRONE OP
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,652
Now you're getting fancy!
If you do that, there'll be a bunch of TT hard parts showing up in the Flea Market (including mine!)
WUMPA
Sidecardogs.com
Times are GMT -7.   It's 02:02 AM.
