10-25-2010, 09:52 AM
#1 |
El cheapo
Oddometer: 4,893
Ducati V8 SS?
This was on display at the Intermot bike show in Colonge Germany this year,
![]() ![]() ![]() ![]() Very interesting connection between 4 cylinder heads into 2 then a single pin crank shaft.
Cat0020 screwed with this post 10-25-2010 at 02:23 PM |
10-25-2010, 10:19 AM
#2 |
Aspiring advrider
Oddometer: 3,345
Cool!
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub "Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer |
10-25-2010, 01:52 PM
#3 |
Nude With Boots
I'm not quite getting how the reciprocating pistons hit TDC in each of the cylinder banks?
10-25-2010, 02:04 PM
#4 |
270 deg crank
Oddometer: 103
Intermot is held in Cologne Germany, not France. Wars have been fought over details like that.
270 deg crank |
10-25-2010, 02:35 PM
#5 |
Oddometer: 5
Looks like the outside pistons pivot on a rocker arm.
10-25-2010, 02:47 PM
#6 | |
Oddometer: 5,917
Steve
Garage Residents: '72 Norton 750 Combat, '74 Honda CT70, '74 Norton 850 Interstate, '81 Laverda Jota '89 Honda RC30, '91 BMW R100GS '08 BMW R1200GS |
10-26-2010, 11:26 AM
#7 |
Looks to me like the outside pistons, when pushed down, work that 'rocker arm' and actually help to push the inside pistons upward.
Ingenious, but I'm not entirely sure of the merit behind it, especially with seeing how two pistons are always at TDC at the same time. Seems to me this is an engineering problem solved much easier with a V4 and no common crank pins.
I think I'll do the Pacific Northwest next time. |
10-26-2010, 01:52 PM
#8 | |
V4 Whore
10-26-2010, 02:31 PM
#9 |
High Plains Drifter
Oddometer: 3,720
Wasn't there a Moto Guzzi V8 concept a few years back? I don't mean the racing bikes of the 50's but a modern day design exercise. Very slick if I recall.
I'd rather be dragging a club than clubbing in drag. 08 Buell XB12XT - 08 Santa Cruz Superlight |
10-26-2010, 02:46 PM
#11 |
High Plains Drifter
Oddometer: 3,720
Looks like it says 868cc on the case there.
10-26-2010, 02:52 PM
#13 |
Oddometer: 4,789
That is really an interesting arrangement.
45* crank-pin, 90* firing order, SOHC cam.....one can only assume that the cams are chain driven via that void between cylinders. Doesn't look like they have worked out exhaust routing yet....I can't blame them, that looks to be quite a bear. I wonder how well it works. |
10-26-2010, 02:55 PM
#14 |
High Plains Drifter
Oddometer: 3,720
Yes, I wonder if the front cylinders would exit via a conventional muffler or mufflers while the rear bank would exit under the seat? There could be some interesting plumbing there. I also note the lack of a Ducati name on the machine itself aside from part of the engine, which would have it if that was the base platform used.
05-09-2011, 07:47 PM
#15 |
Green Cantern
Oddometer: 6,514
New Engine Design
This is the design.
And this is the 4 cylinder prototype. This is one of his projects - Ducati-Elenore 868cc V8 ![]() Here is his website. http://www.wirthwein-motoren.de/
950/990 CRASH BAR BAGS, FENDER BAGS, and more. Made with pride. Pachaug Map '08 KTM 450 xcr-w, '10 KTM 990 Adventure '85 Honda CR500 NETRA #24519 akarob screwed with this post 05-09-2011 at 07:54 PM |
