Old 12-21-2004, 08:47 AM   #1
empedrado OP
Oddometer: 240
KTM 640 Adv - Tool box options
I am thinking of purchasing either the KTM or Dual Star toolbox for under the right side panel of my 03 adventure where the charcoal canister once resided. Has anyone else performed this modification? Are these boxes sturdy and waterproof?
empedrado is offline   Reply With Quote
Old 12-21-2004, 08:51 AM   #2
Rad
Just me
Rad's Avatar
Oddometer: 12,130
I think they are the same box. I got mine through Dual Star. It works well and holds the KTM tool bag with a few extras. I'm look'n to add a much larger "home made" one in place of it.
Rad is offline   Reply With Quote
Old 12-21-2004, 08:58 AM   #3
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,839
If you save the brackets from your charcoal canister you might be able to find some PVC pipe that fits it, put on some end caps (the kind that open ) and cut it to a length of choice. Probably around 10 bucks.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 12-21-2004, 09:08 AM   #4
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,287
I found the stock toolbox to be a tight fit for all the tools I got with my adv that I expect are the stockers...I had to grind down one side of the T-handle wrench to get it and everything else jammed in there.
What all tools did y'alls come with?
Your $5 ticket to the buttery goodness that is Smugmug - t7Ut8i5M4CRzY
matey peeps is offline   Reply With Quote
Old 12-21-2004, 09:42 AM   #5
DevDel
DevDel's Avatar
Oddometer: 560
They are not totally waterproof, But it has enough of a seal to keep the grunge out.
Dev
DevDel is offline   Reply With Quote
Old 12-21-2004, 10:32 AM   #6
markjenn
Oddometer: 9,698
I also think the KTM and Dual-Star ones are the same part.
It's a handy spot, but too small for any decent set of tools, and it is annoying that the standard KTM toolkit doesn't quite fit. I may try and grinding trick that someone mentioned.
- Mark
Old 12-21-2004, 10:57 AM   #7
Rad
Just me
Rad's Avatar
Oddometer: 12,130
- Mark
I ground down both ends of my axle nut wrench to make it shorter, kept the spark plug socket, dumped the T-wrench, plyers and most of the other KTM stuff and replaced it with the Moton Pro Metric tool set. Do'n this lets me also carry a spare spark plug, tape, small zip ties and the Motion Pro Jet tool and two jets in the tool box. I carry a Leatherman up in my map case
Old 12-21-2004, 12:00 PM   #8
empedrado OP
Oddometer: 240
Well it seems pretty clear the box is a good idea as long as you get your tool selection "whittled" down appropriately.
Old 12-21-2004, 12:11 PM   #9
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
creeper is offline   Reply With Quote
Old 12-21-2004, 12:23 PM   #10
Jerome
Oddometer: 106
Puke
There is another option. It just depends how many tools/spares etc you wish to take.
I use the Sommer's bashplate/toolbox with two tool boxes and another tube across the front for spokes and tyre levers.
http://www.ktm-sommer.de/Seiten_04/F_zub_adv640_04.html
The weight is as low as possible and the boxes protect the brake and gear levers which are otherwise vulnerable.
Jerome
Life on the Line, my book about my 18 month trip through the America's, is available from http://www.jeremybullard.com/
Jerome screwed with this post 12-21-2004 at 12:33 PM
Jerome is offline   Reply With Quote
Old 12-21-2004, 02:10 PM   #11
markjenn
Oddometer: 9,698
Rad, thanks for the tool-whittling directions. Sounds like a good plan. I'm sticking my registration in a ziplock bag in there now which seems like it is underutilizing the space a tad.
- Mark
Old 12-21-2004, 03:07 PM   #12
GT-STMC
Oddometer: 108
OK...., what about the charcoal canister ??
Isn't it needed ?
www.RGVCycleStuff.com
2001 KTM 640 Adventure, 1997 Kawasaki Ninja (converted to "street fighter" form)
"Sex....., Money......, Horsepower......, too much is never enough"
2004 Mustang Mach1, 1970 Mustang Mach1
GT-STMC is offline   Reply With Quote
Old 12-21-2004, 03:32 PM   #13
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Isn't it needed ?
Nope. Remove it, plug the airbox fitting and reroute the fuel tank vent hose down the hole in the steering neck cap nut, or get one of the tricky 1-way valve kits.
Old 12-21-2004, 03:34 PM   #14
meat popsicle
Ignostic
Oddometer: 13,839
Isn't it needed ?
Well, in the bigger scheme of things yes, controlling all emissions are important. But in comparisons of vehicle to vehicle, just what are the evaporative emissions of my KTM LC4 Adv?
At least that's the way I rationalize removing the under-engineered liability.
Old 12-22-2004, 09:06 AM   #15
GT-STMC
Oddometer: 108
OK, thanks again. You guys help a lot.
I agree, what emissions could the LC4 put out compaired to the 351 Cleveland in my '70 Mach? It gets 7mpg (Hi-way) and has no polution control "gadgets".
Times are GMT -7.   It's 05:39 AM.
