Old 11-29-2010, 01:49 PM   #151
dentvet
Oddometer: 1,370
Originally Posted by Wheedle
How does the trans work out? If you gear it to work alright on trails,, does it run out of breath on the street?
i wonder if the 650 shares the clutch with any other model and or if an autoclutch is available
dentvet is offline   Reply With Quote
Old 11-30-2010, 04:44 AM   #152
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
Is a slipper the same as an auto? BRP yoyodyne slipper
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 11-30-2010, 04:47 AM   #153
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
That what's so cool about this bike. Single track one minute, 80 on the hwy the next.
Old 12-03-2010, 02:22 PM   #154
Airman Jack
Faster! Lower! Faster!
Airman Jack's Avatar
Oddometer: 129
I *believe* a slipper clutch is just a uni-directional clutch. Basically, it's a normal engagement when accelerating or maintaining speed, but when downshifting it will allow a certain amount if slip if you're ham-fisted on the clutch or don't rev-match, preventing the rear wheel from locking up on big-displacement twins. http://en.wikipedia.org/wiki/Slipper_clutch
It's kinda like a sprag clutch for helicopters, allows the rotor system to freewheel if the engine stops.
2004 BMW R1150GSA Adventure
Airman Jack is offline   Reply With Quote
Old 12-05-2010, 09:16 AM   #155
tonymorr
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,529
Originally Posted by Zapp22 View Post
love this...
have you guys that have completed mutants put any on a scale?
Yes, 350lbs without gas before I put on the luggage racks.
This is what mine weighed on our shipping scale at work with the fuel tank empty, the bike stripped of the "Ninja garb".
It was just a little more when I was done but I don't remember the exact number.
About power... I started with the stock gearing and never felt a need to change it. The nice thing about this motor is that it makes respectable power right off of idle and gets really fun when you rev it!
I wanted to build what repsolrider has built but lacked the attention span and a place to do it. Very nice job ;-)
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is online now   Reply With Quote
Old 12-05-2010, 10:41 PM   #156
c_m_shooter
Ninja Warrior
Oddometer: 266
It appears to me the biggest weakness of the 650 motor off road is that dangly oil drain. One medium sized rock or miscalculated ledge will really ruin your day. Has anyone come up with a solution? I don't see any way of mounting a bash plate that would take the weight of the bike.
c_m_shooter is offline   Reply With Quote
Old 12-06-2010, 10:42 AM   #157
ktmklx OP
ktmklx's Avatar
Oddometer: 700
I am thinking of building a pair of lower frame tubes. These would be mounted at the front engine mount point and the tube the muffler mount is on. It will take a bit of fabrication and add some unwanted weight. But it is doable.
ktmklx is offline   Reply With Quote
Old 12-06-2010, 01:31 PM   #158
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
I've seen one on a muntant but unsure how he did it. Not sure if the klre addressed this point or not. Ther's a post on here about that problem and itseems like there was some oil channels cast into that lower section
johnwesley is offline   Reply With Quote
Old 12-06-2010, 01:49 PM   #159
LukasM
Oddometer: 5,426
I am the one who cut off the extension of the oil pan where the drain plug sits. There is an additional channel that comes in from the side.
Still, quite a bit of clearance could be gained by modding the oil pan somehow.
Old 12-06-2010, 02:07 PM   #160
repsolrider
repsolrider's Avatar
Oddometer: 128
The oil passage is a drain from the screen bowl to assist in draining oil.
I took the entire thing off and relocated the drain to the low or side stand side .
repsolrider is offline   Reply With Quote
Old 12-06-2010, 02:10 PM   #161
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
Got a pic of it?
Old 12-07-2010, 07:01 AM   #162
LukasM
Oddometer: 5,426
Nice! I didn't find a picture of that in your Smugmug album, would be cool if you could post one. Simply machined the protrusion off and welded up the hole?
Cheers
Old 12-07-2010, 09:26 PM   #163
repsolrider
Oddometer: 128
Cheers
Correct Buddy.
Old 12-08-2010, 05:21 AM   #164
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
sweet, like the idea alot. No drain plug on the bottom to hit
Old 12-08-2010, 06:40 AM   #165
SamM
Jeep Overlander
Oddometer: 1,471
It would be bothersome to have to pull the skidplate for oil changes but it's easy enough to remove. No big deal! The drain is on the kickstand side of the bike, so all the oil flows out. Simple and easy! I like it too!
SamM
SamM is offline   Reply With Quote
Times are GMT -7.   It's 08:21 AM.
