Old 10-21-2011, 08:01 AM   #331
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 12,931
kawa's are all heavier than they need to be... as are all adv multicylinder steeds that I know of thus far.
a Versys weighs about 455
I would have thought a suzi SV650 Naked would be sub-400, but alas, it comes in at about 440 wet.
Originally Posted by ktmklx View Post
No, 2 are quite the same. It seems that availability of the doner dirt bike makes everyone a little different. I think with all the build threads it is pretty easy to slap one together.
Not sure on the weight of mine. Most guys are estimating closer to 400.
Zapp
"I will not let the White City fall... nor our people fail.” - Aragorn
K4 WEESTROM Stealthfighter Black - Invisible to Radar
'02 DR650SE SOLD
'97 DR650SE My Fave
Zapp22 is offline   Reply With Quote
Old 10-24-2011, 03:17 PM   #332
pjm204
Oddometer: 1,256
I've narrowed my front end down to a CRF450 or YZ450...I'll be making my decision tonight...any reason to go with one over the other(or neither)? I ordered a 2008 R1 shock. All I need to source is my rear wheel. I also ordered an extra oil pan to mod. Still dreaming up my headlight/fairing.
Can't wait to get started on this build. Should be a nice project to get some use out of my JD Tubing bender(crash bars, maybe headers, and maybe a lower frame cradle.
Also, will I have issues running a 21" front wheel. Seems like everyone goes with a 19" but I'm purchasing a complete front end that will have a 21" front wheel.
pjm204 screwed with this post 10-24-2011 at 03:23 PM
pjm204 is online now   Reply With Quote
Old 10-24-2011, 05:56 PM   #333
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,711
Several have used a 21" wheel without issue. You'll definetly want to look at a brake rotor upgrade.
Old 10-24-2011, 08:24 PM   #334
pjm204
Oddometer: 1,256
I'm having a little trouble sourcing a rear wheel for this build....ktm LC4 wheel 18mm axle correct? looks like the dr650 wheel takes a bit more work? any other choices.
Old 10-25-2011, 08:02 AM   #335
pjm204
Oddometer: 1,256
So what have people done to cure the reduced steering from the USD front ends? I think the YZ450 triples I'm using have 25mm of offset...so maybe it won't be so bad.
Old 10-25-2011, 02:55 PM   #336
pjm204
Oddometer: 1,256
http://advrider.com/forums/showthread.php?t=736687
My build thread has begun.
Old 12-28-2011, 05:56 PM   #337
jnorton1
Oddometer: 255
What do these weigh in at after you guys are done with them?
2001 BMW F650GS Dakar
jnorton1 is offline   Reply With Quote
Old 12-29-2011, 01:00 PM   #338
ben2go
Stuck @ Home! >=^(
ben2go's Avatar
Oddometer: 1,166
Most are reporting a dry weight of around, or just under, 400lbs.For a Ptwin adv bike with roughly 80hp,six speed trans,the ability to keep up with or surpass most other dual sport bikes,all while keeping build cost under $3000,it about perfect,IMHO.
Originally Posted by crashmaster
Throw off those comfortable chains that the U.S. consumer society has burdened you with, go and ride solo into places far outside your comfort zone, and learn interesting things about yourself.
Manic Cycles=My Blog
Manic Cycles=My Facebook Page
ben2go is offline   Reply With Quote
Old 01-28-2012, 08:14 AM   #339
ktmklx OP
Oddometer: 572
working on the details
This winter is about refining the bike. Not much work has been done yet, but some. I want to put Pelican cases on the sides of the bike so that is going to require adjusting the rear end a bit. Originally the Ninja rear license plate/directional mount was used on the mutant. By combing the rack rail mounts with the directional mounts, the Ninja mount could be eliminated. A new license plate bracket was also fabricated.
Old design.
New bracket.
New directional mounts and plate bracket.
With Trunk.
ktmklx is offline   Reply With Quote
Old 03-20-2012, 08:40 PM   #340
ktmklx OP
Oddometer: 572
The new fairing mounted very easy but it meant re-designing the wind screen mounts. Spent alot of time looking at how to do this, looked into different windscreens, didn't really want to spend a bunch of money one. Finally came up with this. Three aluminum mounts, 2 above the fairing and 1 below. Also relocated front turn signals so they fit in the fairing cut outs.
Been thinking about how to increase fuel capacity, one idea is to add twin tanks below the ninja tank. Here is one side mocked up. This would require some creative plumbing and a lift pump, but I think I like that challenge.
Old 03-21-2012, 07:44 PM   #341
ben2go
Stuck @ Home! >=^(
ben2go's Avatar
Oddometer: 1,166
You shouldn't need more than 1.5 psi to get fuel from the side tanks to the carbs.You could just pump up into the main tank, when the low light comes on,that way the electric pump doesn't run constantly and drain the battery.Just my thoughts.
Old 03-22-2012, 06:20 AM   #342
Multisurface Rider
Multisurface Rider's Avatar
Oddometer: 383
Has anyone tried a R1100GS stock tank on these bikes? They are wide and might fit over the frame, problem is you would have to fit the seat also/maybe.
Multisurface Rider is offline   Reply With Quote
Old 03-22-2012, 06:57 PM   #343
ktmklx OP
Oddometer: 572
Plan on using an impusle pump from a snowmo engine. No electrical load, high volume low pressure pump.
Old 03-22-2012, 06:59 PM   #344
ktmklx OP
Oddometer: 572
I should just buy a Versys tank and be done with it.
Old 03-22-2012, 08:22 PM   #345
ben2go
Stuck @ Home! >=^(
ben2go's Avatar
Oddometer: 1,166
I am in the south east so I never even considered those.I had one on my racing kart.They needed rebuilding frequently,but that may have been a side effect of running methanol.
Times are GMT -7.   It's 04:45 PM.
