Old 06-03-2014, 06:16 AM   #1
jugglethese OP
jugglethese's Avatar
Oddometer: 10
2003 kl250 exhaust and tires
I've searched for a performance exhaust but I can't find one anywhere. Does anyone know where to get them?
I want 2 new tires for soft sand and mud. How big can I go?
jugglethese is offline   Reply With Quote
Old 06-03-2014, 07:36 AM   #2
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,622
Maybe your classification of the bike as a "KL" instead of a KLR is limiting your search.
http://www.ebay.com/bhp/klr-250-exhaust
At least I'm assuming it's a KLR? I'd also add that installing as big a tire as possible isn't always a good performance move. A beast of a Yamaha WR450F only has an 80/100 X 21 front and a 120/90 X 18 rear. You need a lot of power to pull big tires, and the KLR isn't exactly the horsepower/torque king.
TNC screwed with this post 06-03-2014 at 07:42 AM
TNC is offline   Reply With Quote
Old 06-03-2014, 07:55 AM   #3
prsdrat
Oddometer: 731
Look on the Super Sherpa thread for KL250's.
"Can't never could."-Grandma Belle Marie Bullock-Shuflin
prsdrat is offline   Reply With Quote
Old 06-03-2014, 08:26 AM   #4
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,622
Hmmm...first time I searched under "KL250" I didn't get anything but the ancient SOHC engine KL series from the 80's. Didn't realize they called the SS a KL model. Still an ancient design...but...seems like a good beginner, lady's, or short person bike.
Old 06-03-2014, 12:22 PM   #5
jugglethese OP
Oddometer: 10
The tires that i find that are the right specs for my bike are slim pickings, mostly trials tires and on road off road tires. Im looking for something more aggressive, i just need to know what will fit if i go bigger that wont compromise to much power
Most of the trails i go down are filled with mud all year round and the pits are very soft sand.
Old 06-03-2014, 12:23 PM   #6
jugglethese OP
Oddometer: 10
if anyone knows if the klr250's exhaust will fit the sherpa? or is it completely different?
Old 06-03-2014, 12:51 PM   #7
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,622
Now that I know a KL and a Super Sherpa are the same thing, I'd be curious about that too. They sure like two very different bikes...water-cooled vs. air-cooled, etc.
Old 06-03-2014, 06:24 PM   #8
jugglethese OP
Oddometer: 10
Yeah but the cosmetics are very similar, maybe same frame? If it is then the exhaust should have the same mounting points? i cant find good pictures on google images to compare to see if they have the same set up.
Old 06-03-2014, 07:11 PM   #9
jms78
Oddometer: 255
Kenda Trakmaster II
Kenda 270
Michelin T63 (probably fits)
Tires in the 100 - 110 mm width should fit without issue but 120's may be tight depending on tread height. Otherwise a 4.10" (OE size) tire will work but a jump to 4.60" may be pushing it depending on tread size.
2004 DR650
2011 450 EXC
2011 DL650
jms78 is offline   Reply With Quote
Old 06-03-2014, 07:16 PM   #10
jms78
Oddometer: 255
Good luck with the exhaust. The Sherpa isn't likely to gain much by changing the exhaust and there isn't a large demand for "performance parts" for them to begin with.
Also, when searching for parts, adding the 'G' (ie. KL250G) helps weed out the older KL series bikes.
2004 DR650
2011 450 EXC
2011 DL650
Old 06-04-2014, 10:15 AM   #11
jugglethese OP
Oddometer: 10
Originally Posted by jms78 View Post
Kenda Trakmaster II
Kenda 270
i picked the Maxxis M7305 Maxxcross IT Rear Tire 100/100-18.
Will a 90/90-21 fit the front?
Old 06-04-2014, 12:11 PM   #12
jms78
Oddometer: 255
With the low fender it's likely to be an issue. If you have a high fender then it will probably fit.
2004 DR650
2011 450 EXC
2011 DL650
Times are GMT -7.   It's 09:02 PM.
