Old 12-24-2010, 01:10 AM   #61
yamahaman OP
wannabe bike builder
yamahaman's Avatar
Oddometer: 223
Thumb good point
Originally Posted by laramie LC4 View Post
nice work but that master cylinder looks awfully exposed to me. just saying...
laramie
I know what your saying and I went out to the shed and had a look, the camera angle does no justice to the job though. I have got plans to mill 4mm (just just over 1/8) off the face where the brake pedal mounts and the master cylinder mounts, this will make things a bit better and bring the pedal and master "inboard" so to speak. I was curious to test the crash angle and it layed the bike on the ground with the foot peg folded up to check the angles out and the rear master is a long way away from hitting any thing, I would have to land on a massive odd shaped rock or log to do any real damage. We will see what happens when I have a few shake down runs.
Cheers for the input makes me feel like someone is listening/looking
Build it and you will ride
My crazy bike build
yamahaman is offline   Reply With Quote
Old 12-24-2010, 02:55 AM   #62
JensEskildsen
Oddometer: 1,012
I think we are many looking here daily for updates
JensEskildsen is offline   Reply With Quote
Old 12-24-2010, 06:19 AM   #63
S2P
S2P's Avatar
Oddometer: 691
Originally Posted by yamahaman View Post
A heap of cutting with the grinder and a quick linish. I have now got rear brakes.
I know you mates have some different words,but what's a linish?
I like the looks so far,I wish I could get a XT fairing like that to put on my 426.
"In wine there is Wisdom, in beer there is Freedom, in water there is Bacteria"...Benjamin Franklin
WR 426
TTR 125
S2P is offline   Reply With Quote
Old 12-24-2010, 06:41 AM   #64
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,213
If its a Yamaha Big -Bore WR TT XT we like it!!
BIG ED XT FAN is offline   Reply With Quote
Old 12-24-2010, 04:07 PM   #65
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Cool2 linisher and fairings
This is a linishing attachment for a bench grinder.
I have contacted the dudes that make that fairing and they are going to send me a cover only. I want to make a similar one or buy a second later on to put on my wr 426 Maby with a diferent light so keep you eyes peeled over the next few months
My crazy bike build
yamahaman screwed with this post 12-26-2010 at 03:30 PM Reason: spelling
Old 12-26-2010, 02:39 AM   #66
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Wink machining the brake brackets
Went to a mates place to do the finishing touches on the rear master/footpeg backet. After laramine LC4 had a few questions/surgestions I am going to move the master inboard approx 4mm. Also there was a heap of excess material taken off to reduce some weight
Here we are removing some material to make the back of the bracket flat in preperation for turining it over to machine the other side parrallel
Here we are removing 4mm from the bracket so the master and pedel will not protrude too far out from the bike. Not quite finished tonight so we will finish them tomorrow and have a go at fitting them in the next few days.
My crazy bike build
Old 12-26-2010, 08:31 AM   #67
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,368
wow, i wish i had access to all that machinery. my wife would never see me or the bikes again. well, maybe at dinner and .......
good job!
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 12-26-2010, 09:58 PM   #68
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Cool2 lets get control of the situation!
I have had a pretty positive couple of days
First I got the bolts required to mount the new pro taper bars.
Did a bit of swapping around and fitted a new pro circuit clutch lever to my YZ426F and took the old yz clutch lever off, put it on the monster and gave the 'domino' lever (shown previously) from my old husky the arse!
Next was to start working on the pegs and rear brake a little more trimming, grinding and linishing (sanding) and I now have this.
As Laramine mentioned they look quite vulnerable but they are tucked away quite neatly and I'm very happy with how they turned out.
The master and lever don't protrude too far out from the frame and with a small alloy cover bent up to cover the master all will be good and hopfully quite tuff.
My crazy bike build
Old 12-26-2010, 11:24 PM   #69
Fubars
What would Scoobydo?
Fubars's Avatar
Oddometer: 1,751
I envy all you guys who are able to whip out cool bits for motorbikes on machine tools.
Carry on.
Fubars is offline   Reply With Quote
Old 01-09-2011, 05:54 PM   #70
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,174
What year is the frame?
as the first two models use to snap the foot peg off on the left? side
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 01-09-2011, 06:53 PM   #71
yamahaman OP
yamahaman's Avatar
Oddometer: 223
jeez that sounds bad
Shit
that sounds bad this frame is an 84 or 86 I think. I had a look at the original pegs and there seems to be a lot of leverage because they were mounted so far forward but these seem to be right where they attach to the frame. Any more info would be awsome
My crazy bike build
Old 01-09-2011, 07:49 PM   #72
theMISSIONARY
Oddometer: 2,174
83-84 models had the habit that standard pegs were on the small side....and i was looking at the nice one's you put on will only make a possible problem worse
look at the area of frame they mount too....(trying to remember) do they mount to a flat plate or is it a tubular type of mount i "think" the early ones had a flat plate(a bit like a triangle of steel between the tubes) type of set up and everyone welded a bent up bit of flat to make a brace for it....although lots did this after they let go they ended up looking very messy
Still it was fixed by Yamaha with in those two years....probably not a problem but something to look for
Old 01-10-2011, 02:16 AM   #73
mjoneill82
mjoneill82's Avatar
Oddometer: 66
very nice.. enjoying watching it com n along
mjoneill82 is offline   Reply With Quote
Old 01-17-2011, 01:43 AM   #74
Andrew in Tas
The Great Pretender
Andrew in Tas's Avatar
Oddometer: 9
wicked project
cant wait to see the finished product, looks like the ideal weapon for a trip across tassie...
geez you pumped the parts into the ol YZ.. where did you get all those bits?
www.TAZTRAX.com.au
Professional Tour Network across Tasmania
www.trailriderz.com.au
www.dirtbikestuff.com.au
Andrew in Tas is offline   Reply With Quote
Old 01-17-2011, 03:33 AM   #75
yamahaman OP
yamahaman's Avatar
Oddometer: 223
yz parts
I get all of my bits from Flea bay, a wreckers in melb and this dude in tassie
My crazy bike build
Times are GMT -7.   It's 11:38 AM.
