Old 07-09-2011, 10:26 PM   #121
yamahaman OP
wannabe bike builder
yamahaman's Avatar
Oddometer: 223
First time fiber
So I had a crack at firberglassing
I will admit I dont particulary like it but I think with a bit of time I will get a bit better at it.
I Think I am strugling with temperature very cold here in melbourne at the moment 12 - 13 deg c at the moment.
its much easier working with metals
Build it and you will ride
My crazy bike build
yamahaman is offline   Reply With Quote
Old 07-09-2011, 11:45 PM   #122
tileman
tileman's Avatar
Oddometer: 870
Can vouch for the temp in melb at the mo, bloody cold, but in regards to the fairing I reckon i looks pretty bloody good.
If ignorance is bliss, why arenīt more people happy?????
tileman is offline   Reply With Quote
Old 07-17-2011, 03:56 AM   #123
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Puke Fiberglassing is a mugs game
Well guys I have been persisting with fiberglassing and learning as I go. I have made a copy of original and started to modify it to make a mold for the one that will go on my bike. First I layed some woven glass fibre over the blue wr shroud but it moved off the center line and I had to grind it off and start again. I have now glued it in place with an epoxy glue and will glass over it so I can gel coat it and make it super smooth to make the mold.
Let us know what you think
My crazy bike build
Old 07-17-2011, 08:41 AM   #124
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 729
freakin brilliant
Nice, very nice !
pennswoodsed is offline   Reply With Quote
Old 07-17-2011, 04:31 PM   #125
tileman
tileman's Avatar
Oddometer: 870
Great Job!!!!!
If your going to make more than one I might have to be inline for one. My project is nearly go with a WR light already installed,
Old 07-21-2011, 07:28 AM   #126
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Thumb getting closer to a fairing
I have done a bit of sanding and added some layers of Glass matting to get closer to the shape I have been looking for so here we are. The lens is just sitting in on the back of the plug and will sit a little further out on the finished product therefore filling the gaps around the light.
As it turns out I was looking through some pictures from when I was in the design stage and found this picture of helder rodriges 2011 bike ant my faring will end up looking similar to this when its done. (although mine will be a little rounder on the sides)
My crazy bike build
Old 07-21-2011, 04:32 PM   #127
tileman
tileman's Avatar
Oddometer: 870
Thumb
Looks Great !!!!!!!
Are you going to make a couple ?
Old 07-23-2011, 09:55 PM   #128
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Bluhduh yeah mabey
There is so much work involved so I might make a few. Going to make a good mold so I can reproduce some if I crash and smash it so there may be a few floating around but dont hold your breath because it will not be a quick job
My crazy bike build
Old 07-23-2011, 11:41 PM   #129
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Mock up on the bike
Made a temporary light fixture and have temporarily put the fairing into place. I dont want the fairing to be too far forward or to high so this is where I have ended up.
I think I may move forward by 25mm mabey to give a bit more room for instruments.
What do you guys think?
My crazy bike build
Old 07-24-2011, 12:25 AM   #130
tileman
tileman's Avatar
Oddometer: 870
Has the proposed carbon tax taken your engine?????
Looks great !!!!!!! mighty impressed, when are you going to make another hehehe
Old 07-24-2011, 05:51 AM   #131
yamahaman OP
yamahaman's Avatar
Oddometer: 223
This is the plug to make the mold
This piece I am working on is the plug which the mold will then be made from so it could be a while before and actual fairings come out for fitting onto the bike
My crazy bike build
Old 07-27-2011, 05:50 AM   #132
yamahaman OP
yamahaman's Avatar
Oddometer: 223
Cool2 A few changes to the fairing
I have made some sheets of fiberglass and then added them to the fairing to make the side extensions to meet up with the tank.
Every thing clears just have to make it look neat and match the lines of the tank. I have made some marks on the fairing to indicate the final cut lines but I am going to sit on it for a few days and look at it a few more times to get the final cutting lines right in my mind and then do the final cuts and make some more brackets to hold the fairing in place
My crazy bike build
Old 07-27-2011, 08:26 AM   #133
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,368
thats the way i am too. the more you look at it before you work, the better the final project. hard not to rush in though.....
bikes looking good! i've seen a couple "front fairing projects" recently that looked like crap. you have done a great job.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 07-28-2011, 01:21 AM   #134
yamahaman OP
yamahaman's Avatar
Oddometer: 223
laramie
Thanks I like to do a good job where ever possible
My crazy bike build
Old 10-07-2011, 04:39 AM   #135
yamahaman OP
yamahaman's Avatar
Oddometer: 223
still at it boys
Still at it guys I have a heap on so dont forget about me
My crazy bike build
Times are GMT -7.   It's 10:17 AM.
