Old 12-21-2004, 12:07 PM   #1
jonb OP
Montana Adventurer
jonb's Avatar
Oddometer: 284
Acc 2- Accessory Pair Amperage Capacity
i am adding my accessory socket using the 5 amp acc 2 pair stored in behind the tach. i see now that my compressor for tire inflation is rated at 10 amps. i looked at the wiring diagram and i think it would be OK for me to put a 10 amp fuse in there instead of the 5. This is an unswitched accessory pair from the battery and on my bike its labeled acc 2. i don't plan on running ten amps off this all the time. I will be blowing up the rear tire trying to set the bead which will require the compressor to work pretty hard for a couple of minutes. The copper(wire) looks like its 16 to 18 gauge.
Can I run the 10 amp fuse?
Thanks for your input.
JB
jonb is offline   Reply With Quote
Old 12-21-2004, 01:14 PM   #2
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
I would say YES because my dealer upped mine to 10AMPS because it ran my 5AMPS heated grips AND my carb heaters from the same ACC plug(the one running through the ignition)
BLUE(UK) is offline   Reply With Quote
Old 12-21-2004, 01:26 PM   #3
dgrs2
Where'd I leave my knee??
dgrs2's Avatar
Oddometer: 1,660
Switched up to the 10 also with no problems. Run my HID off it.
04 BMW R 1150 GSA
Smokin Hole Rally creator
dgrs2 is offline   Reply With Quote
Old 12-21-2004, 02:33 PM   #4
jonb OP
Montana Adventurer
jonb's Avatar
Oddometer: 284
I figured they were playing it safe. I plan on deflating a tire, and pumping it back up with the 10 amp compressor and the 10 am fuse, feeling the wires as I go for heat. We'll see how it goes.
Thanks.
Times are GMT -7.   It's 03:43 AM.
