10-30-2010, 08:36 AM
#1 |
Bike-aholic
Oddometer: 2,067
F8 Water Drowning Recovery
Being new to BMW's, but not to bikes or wrenching, I couldn't stand it any longer.....had to strip my F8 naked for good looksee at her!
A few thoughts on the passing scene: 1) I think that must be the ECU under the seat...?? 2) Quite an airbox contraption under there... 4) Where's the fusebox? That sneaky rat is still hiding from me. But I keep looking at that airbox and wondering: What happens if you drown this girl in a creek crossing? Looks like its gonna hold 4 gallons of water in the airbox and drain it into the engine after you stand it back up. So, what is the proper recovery procedure on an F8 after a water drowning? I'm all ears..... HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com |
10-30-2010, 09:02 AM
#2 |
NTXer
Oddometer: 705
You obviously need to read up a bit more. No fuse box. It's called a Canbus system. And ther's drainage for airbox water.
I once was lost but now I'm...no wait, I'm still lost .
10-30-2010, 09:35 AM
#3 |
Bike-aholic
Oddometer: 2,067
Thanks, Toadride. Been reading voraciously for 3 weeks....just not crossed those tracks yet.
I'll locate that drainplug(s) and bone up on CanBus. Bike came with a little Powerlet next to ingition key slot. The outlet is not working. So, what's the secret fix? HF
10-30-2010, 09:55 AM
#4 | |
Even my posing is virtual
Oddometer: 2,513
F800
Dude you got serious reading to do.
The outlet only works with key on and is limited to very low amperage. Remove that cover that it is in and you will notice that there is a spot exactly opposite where you can install another one. Wire that one to the battery directly with a fuse of course. If you flood out the bike be aware that when the airfilter dries it kind of shrinks and can change shape leak. Quote:
04 Toyota Sienna, new wipers for 2011!! Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!! Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway, Website - http://www.apormc.com/ Vids - http://www.youtube.com/user/Motoriley?feature=mhum |
10-30-2010, 10:52 AM
#5 |
Bike-aholic
Oddometer: 2,067
Apparently, I can't read fast enough. A problem that has long plagued me.
So, if you plug in something with too big a load (say 30 watt heated vest into el 5-watt junior plug-o) what happens...nothing? No harm done (on a CanBus)? My little powerlet is dead! As in nada...nuttin...train ain't coming. That's with the key on and even the engine running. Maybe the connector plug is bad...? So, back to the water adventure....I'm liking the sound of this, I think. Stand the bike back upright....let the airbox drain on its own, empty the pipe and your good to go...eh? My bike will face many a deep water crossing in the months to come. Does the F8 stall without some snorkel mods? No...my reading hasn't caught up to that yet either. But I was going to try drinking the 12-pack before pushing that buy button for the D-3 fairing, as Docking Pilot encouraged. See there...I've been reading something. HF ![]() p.s. thanks for the tip on the air filter shrinkage, Motoriley.
10-30-2010, 11:00 AM
#6 | |
Oddometer: 2,513
Deep water in the 800
The 800 will go in water that is really deep. The air intakes air very high. I ride with guys on a 1150GS, an HP2 and a DR650. They fear to tread where my 800 can go water wise.
One thing I've learned is that if you do as much water as I have is that you better get good at changing wheel bearings. All mine were toast in 7000 kms. See some vids here. http://vimeo.com/14825990 Quote:
10-30-2010, 05:31 PM
#7 | |
Big red dog
Oddometer: 1,322
Best bet is to re-wire a direct-to-battery power outlet.
"It's cunnilingus and psychiatry that's led to this" - Tony Soprano 10 F800GS |
10-30-2010, 07:27 PM
#8 |
Bike-aholic
Oddometer: 2,067
Thanks for the info, Raider. That sounds like my problem. I've tried a gps, a little air compressor, and the controller (only) of my heated gear...just to see if the red light will come on. Probably not being recognized, as you said. Man, Canbus is some kind of sophisticated system, I reckon.
I'll do as you and another have said. Except I think I'll wire up a complete auxillary power box (like a centec) and use that spare accessory outlet to simply power a contact relay. Then pull the main juice from the battery. Will that work? Will the CanBus recognize a Relay and give it some go juice? HF
10-30-2010, 07:52 PM
#9 | |
Big red dog
Oddometer: 1,322
That said, the power outlet isn't like Windows USB, it doesn't need to know what's plugged in, just that something is. If you're getting nothing even with the engine running, maybe there is a problem there. Regardless, CANBUS doesn't control the battery, so if you want to wire up your own power box, just take it directly off the battery. What the computer doesn't know won't hurt it!
10-30-2010, 09:06 PM
#10 | |
Oddometer: 998
CANBus has been around for years, is very reliable, and easy to use once you understand how to work with it. LINKY for info run a power relay off the bike system and tap the main battery through said relay for power. Hook it all through a centech or the like and be done with it. It's easy! The above link shows the connector you need. It is under the airbox cover and easy to find. One thing I highly recommend you do is run and SAE pigtail direct from battery to somewhere up near the steering head. With this you can now plug a Battery Tender in and, more importantly, run a cycle pump if you have a flat repair you need to affect. You can plug the pump in to this pigtail and not have to have the bike sourced power on.
Ride Safe, Ride Often, RIDE!!!! |
10-30-2010, 09:55 PM
#11 |
Oddometer: 1,237
Guys, the lack of fuses has nothing to do with CANbus. They can exist independantly of each other. CANbus is a term for a specific type of computer network system. Many vehicles run CANbus systems and also have fuse panels. It just happens to be that BMW decided they'd let a computer control the current flow in many circuits.
10-30-2010, 10:54 PM
#12 |
Broken Roadie
Oddometer: 2,787
10-31-2010, 07:23 AM
#13 | ||||
Bike-aholic
Oddometer: 2,067
Ho-chi-momma.....Motoriley! All I can say about your video is this: Everyone needs to watch this to appreciate what an F800 is capable of, as well as one crazy rider. Your creative editing is superb. Truly, one of the most entertaining video clips I've seen in years. Outstanding job! Quote:
Way to go ChiTown. Thanks for directing this thread back to the "Water" question. Who has taken a submerged dive on their F8 and is willing to admit it? What were the steps that followed to get her going again. I can easily use my imagination, but I'd appreciate hearing the events that followed and how the bike responded. If you'd be so kind... HF
10-31-2010, 07:37 AM
#14 | |
Oddometer: 2,513
Deep
Even though I've seen this clip a few times I always find myself hoping you make it!
That must be a s close to maximum depth as you can get.Quote:
10-31-2010, 07:40 AM
#15 |
Oddometer: 2,513
F800 dewatering
Knowing what I know now I would certainly check the air filter after a dunk. The big pain in the rear would be pulling the plugs. You need to remove all the tank plastic. Unplug a few electrical connectors, pull the entire airbox and have the correct thinwall deep socket to get the plugs out. Which I still haven't bought!! It is enough to make you wish you still had an 1150 where all this takes 5 minutes...
