Old 10-30-2010, 09:42 PM   #1
macxx1 OP
Oddometer: 103
Home made (cheap!) clutch alignment tool
First, understand you probly don't really need one if you are careful
just sighting the disc in on the center of the clutch assembly.
But - anyway - if you'd like to make one, it's easy and inexpensive.
The first time I changed my clutch I poked around in my stash I call
"miscellaneous hardware" (I save most anything) to see what I could
come up with. I built my own house, do very nearly all my own car
work, fix all my own appliances, etc etc, so over time have accumulated
a lot of "stuff".
I had discovered the clutch release pushrod fits snugly into the socket
in the flywheel, so was looking for something to use with that.
Found a little white plastic block with a hole in the center and it was tapered,
didn't have a clue what it was. The hole was just a tad too small for the clutch
pushrod to go thru it, so carefully measured the OD of the pushrod and drilled
the hole bigger with a bit that was just a very little bit smaller than the OD of
the pushrod. The idea was to get a very snug fit over the pushrod.
Seemed to work pretty well to center the clutch disc.
A few days ago I was looking for something in the plumbing dept at
Lowes and happened to spot a bunch of them. Not sure if this is the
right name for it, but it's the little plastic block that fits over the stem
of a faucet to adapt one type of handle.
So if you don't want to trust your eyeball, here's one nearly free option.
If nothing else, it's an easy way to hold the disc in position while you
assemble the clutch.
http://s719.photobucket.com/albums/ww20 ... nt%20tool/
macxx1 is offline   Reply With Quote
Old 10-30-2010, 10:17 PM   #2
StickyBill
StickyBill's Avatar
Oddometer: 97
A square peg in a round hole...who da thunk it?
Nice tip.
Sticky
2002 BMW R1150GS Adventure
2011 KLR 650
StickyBill is offline   Reply With Quote
Old 10-31-2010, 05:00 AM   #3
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,635
in the flywheel,
You discovered ????? How do you think the clutch operates
www.gsshop.biz
Steptoe is offline   Reply With Quote
Times are GMT -7.   It's 09:09 PM.
