Old 03-12-2012, 01:49 PM   #1501
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,178
Originally Posted by Alleycatdad View Post
Idle speed control? Got docs on how the reset works? Is this different than doing the throtle cable adjustment?
Is the reset independent of TuneEcu? That'd explain why I'm clueless...
You're talking to the fella with the high idle, not viola-tor with the poor mpg, right? We've got two issues running together here...
S
You're editing your post too fast for me!
I was talking to Viola-tor to cover all angles as he made a comment on if the procedure was like his bmw. I realize that he is hunting mpg at this point. I still think that he is running into a SAS removal problem.
But it does apply to the foolish fellow's problem as well.
Yes the reset is independent from TuneEcu. But you're not clueless, it's exactly what you said...throttle adjustment (cable free play) which as a consequence could affect the tps.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-12-2012, 02:07 PM   #1502
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Sorry 'bout that. I was trying to make a little more sense....and learn something in the process.
I agree completely that the mpg problem is probably mechanical and that that side of things needs to be nailed down and perfect before dealing with mapping issues.
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 03-12-2012, 03:25 PM   #1503
DirtJack
DirtJack's Avatar
Oddometer: 1,576
According to the TuneEcu guys, there is no "throttle calibration" for the 990 ECU, only the 15 min reset.
Steve
Thanks Steve, having both bikes (and being old), I am often confused by their differences and similarities.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 03-12-2012, 10:43 PM   #1504
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
You guys rock.
I'm moving the conversation on my bike problems HERE as I feel it's strayed too far from the subject of TuneECU.
Please click and continue with me! I'm trying to find some explanation for the erratic bike behaviors...
viola-tor is offline   Reply With Quote
Old 03-13-2012, 12:25 AM   #1505
MotorOlly
Sand basher
MotorOlly's Avatar
Oddometer: 32
Originally Posted by the foolish fellow View Post
Done the whole lot again and took the bike out ror a run. She starts off fine idling at 1750 but once the revs get up they won't come down sitting at 6,000 in all of the gears. Pulling in the clutch makes no difference. I had to ride with the front brake.
How do I get this sorted ?
Hey fellow
Every time my bike has done this it was because the throttle position sensor was reading too low, the ecu brings up the throttle stop unttil it reads. Nb the voltage will drop when the bike warms up so check its not out of range then. A cut down torques bit in a 1/8th spanner can get the adjustment bolt loose without taking the throttle bodies off but there can be other reasons for the voltage being pulled out of range. try reading and posting ur voltage. Good luck!
Ps pull the clutch not the brake ;)
Pps 15 trick does nothing if the o2s are off imho and experience, how could it if it has no feed back to adjust according to :S
MotorOlly is offline   Reply With Quote
Old 03-13-2012, 11:36 PM   #1506
the foolish fellow
UP FOR IT
the foolish fellow's Avatar
Oddometer: 140
mad throttle
map
the foolish fellow is offline   Reply With Quote
Old 03-15-2012, 04:09 PM   #1507
the foolish fellow
UP FOR IT
Oddometer: 140
any ideas on how to screw down the throttle ?
Old 03-15-2012, 05:47 PM   #1508
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
Yep, but I am going to the bar now. I will post later.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 03-15-2012, 06:55 PM   #1509
chrish4ku
chrish4ku's Avatar
Oddometer: 836
2:1 Tests?
Anyone done alt maps with the 2:1 yet? I am in the process adding the aux tank and 2 into 1 and was super curious. I have been running the Akro with O2 sensors, with Remus dual titanium, and that seems to be a good combo.
35 highway - 30 city.
You guys and your claims of 40mpg are full of it.....
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 03-15-2012, 07:20 PM   #1510
mattc
mattc's Avatar
Oddometer: 447
There is a powertripp map on the tuneecu sit that I just loaded this week. I have a stock can on my 2-1, it runs MUCH better than the 2-2 powertripp map I had in before.
mattc is online now   Reply With Quote
Old 03-16-2012, 01:31 AM   #1511
bikyto
bikyto's Avatar
Oddometer: 2,178
This is for a 2009 though, right?
Old 03-16-2012, 05:21 AM   #1512
mattc
mattc's Avatar
Oddometer: 447
Yes, it says it is for 2009-2010
Old 03-16-2012, 12:01 PM   #1513
Spark01
V-Twin
Spark01's Avatar
Oddometer: 304
http://www.ktm950.info/how/wotf/wotf...PositionSensor
'10 990SMT
Spark01 is offline   Reply With Quote
Old 03-16-2012, 01:22 PM   #1514
the foolish fellow
UP FOR IT
Oddometer: 140
Is the 0.67 tps voltage as read from the photos I took of the tune ecu screen too high . Should I adjust it back to 0.5 ?
990 adv
850 Le mans
Gl 1000
X5 3.0d
FE 450 BERG
Old 03-16-2012, 01:25 PM   #1515
bikyto
bikyto's Avatar
Oddometer: 2,178
0.60v on a warm engine
Times are GMT -7.   It's 05:45 AM.
