Old 04-23-2013, 03:37 AM   #2131
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 922
Not gone far enough to the unknow to change many data fields at once. Only small areas to fix specifica behaviors.
690R
Old 04-23-2013, 10:40 AM   #2132
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,798
Originally Posted by StevenD View Post
C'mon, how do you all do it? You all modify a thousand fields by hand, like I just did??
Well, I have a tuner do it But, if you select a range of cells you can adjust them all by the same percentage.
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 04-23-2013, 01:46 PM   #2133
RoundOz
Plenty of seasoning
Oddometer: 1,022
Non-sexist question...
Which tuner? Is he/she good?
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 04-23-2013, 01:51 PM   #2134
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,798
I used 2wheeldynoworks helped my 990 run better.
Moto-Treks
Old 04-23-2013, 03:26 PM   #2135
RoundOz
Plenty of seasoning
Oddometer: 1,022
Thanks..always looking at the easy way out....of course my 2-1 pipe got rid of the urgent need to use TunEcu, but I would still like to squeeze some more smoothness, power and economy out of it.
2009 KTM Adventure
Old 04-23-2013, 06:26 PM   #2136
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 776
the big three
About 2 weeks ago I loaded the wings 2-1 into my 09 ADV-R. Two tanks of gas have yielded 40 and 41 mpg. Very happy. Previous map was installed by the PO and ran very well well with the CPR intake. It drank more gas than I liked though. It sure ran like heck, bounced off the rev limiter quickly. This is fine. 105 HP or so is plenty. There is something magical to getting out of the thirties on MPG.
The more I ride it the more 'accustomed' I am to the throttle input. It's low RPM transitions are somewhat abrupt but OK. I also went to a 17-42 set up. I like the RPM's at 65-70 better this way and I don't find myself checking the shifter every three miles in search of a higher gear.
Pretty happy for now.
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is offline   Reply With Quote
Old 04-25-2013, 10:34 AM   #2137
bauk
Oddometer: 3
hello
error codes p0444purge valve system open circuit or short circuit to ground
I can not fix
what could it be?
thank you
bauk is offline   Reply With Quote
Old 04-25-2013, 11:09 AM   #2138
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
You need to fill in your profile info.
Originally Posted by bauk View Post
hello
I can not fix
what could it be?
thank you
Year of production, model, milliage, bike setup...
Old 04-25-2013, 11:38 AM   #2139
bauk
Oddometer: 3
ktm 990 2011R remotely SAS 22k ohm resistor.
Exhaust 2 1
* map Power-Trippktm990advings no error codes
Km601s1102002map error codes p0444
sorry for my english
thank you
Old 04-26-2013, 05:42 AM   #2140
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
Exhaust 2 1
thank you
Do you mean KM601US1102002Map? This map is only for U.S. bikes.
The error refers to the purge valve system, so far as I know, this system
does not exist in EU-KTM-bikes.
At Triumph models, the system has the following tasks and functions:
The purge valve controls the return of vapour which has been stored in the carbon canister during the period when the engine is switched off.
The valve is 'pulsed' by the ECM to give control over the rate at which the canister is purged.
At KTM, it will work comparable.
BR, Tom
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg screwed with this post 04-26-2013 at 05:49 AM
Tom-Hamburg is offline   Reply With Quote
Old 04-26-2013, 07:37 AM   #2141
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,042
Xcw 500
TuneECU has been an invaluable tool for maintaining my 990 and 690 KTM's
I've just picked up a '13 KTM 500xcw.
Does or will TuneEcu support this bike ?
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 04-26-2013, 09:47 AM   #2142
Tom-Hamburg
Oddometer: 84
Max
Currently no, and whether it will be possible, you have to ask the programmer (Alain).
Contact Alain: http://www.tuneecu.com/Kontakt_Alain.html
BR, Tom
TuneECU
Old 04-28-2013, 07:16 PM   #2143
tacosupreme
tacosupreme's Avatar
Oddometer: 276
I just went to order the cables from http://www.ktmtwins.com/ktm-690-990-rc8-tuneecu-cables
and noticed it said "NOTE: DOES NOT FIT 2012 AND LATER MODELS"
So....I have a 2012 990, what do I need? Thanks!
tacosupreme is offline   Reply With Quote
Old 04-28-2013, 08:30 PM   #2144
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,056
I don't think that's right. They haven't changed the connector or computer.
"Son, you can't do both"
Old 04-28-2013, 09:04 PM   #2145
tacosupreme
Oddometer: 276
I compared my plug to this pic- Mine is has 5 pins,
Mine are 5 pin.
'12 990 with some orange stuff on it to make it go faster.
Times are GMT -7.   It's 01:56 AM.
