Old 06-14-2013, 12:58 AM   #2221
amanatios
amanatios's Avatar
Oddometer: 5
Originally Posted by Vicks View Post
I can't do the Rest Adaption on my '07 (EU) 990. Neithewr single nor double clicking it works.
Hi, i have the same model and it works for me.
Try downloading the latest tuneecu 2.5.3 , click on the tests at the upper right corner and then double click Reset Adaption at the left lower corner.
Hope that helps.
amanatios is offline   Reply With Quote
Old 06-14-2013, 01:25 AM   #2222
RoundOz
Plenty of seasoning
Oddometer: 1,004
Does work for me too...
...although I was going to leave the TPS at the 0.73 cold / 0.68 hot as I just didn't think I had time to strip the bike down that far to be able to drill the airbox hole to access the screw. But it kept bugging me, so I made time, adjusted it to 0.65 cold and will check it hot next time I play with a map. I want to run the 2012R map just to see how we'll the factory did with addressing the fueling issues after 2010.
Anyway, long story short, although the Reset Adaptation does appear grayed out, the double click worked. Remind me to do the 15 min idle later will you, when its not 2am in my downtown neighborhood, with my pipe you could lose a tennis ball in...
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 06-14-2013, 11:25 AM   #2223
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Hope that helps.
thanks
will try that.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 06-14-2013, 12:46 PM   #2224
Pistolero
W. F. O.
Pistolero's Avatar
Oddometer: 710
Ran across this just now.
http://www.rbracing-rsr.com/rsrgauge.htm
Pistolero is offline   Reply With Quote
Old 06-15-2013, 05:19 PM   #2225
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,984
I like the idea of the dual read outs, but not the HD bs. Here's the guys>
http://www.innovatemotorsports.com/products/MTS.php
"Son, you can't do both"
Old 06-15-2013, 10:00 PM   #2226
Pistolero
W. F. O.
Pistolero's Avatar
Oddometer: 710
I'm about to go the Bazzaz way and a gauge would be handy for sure.
Old 06-18-2013, 03:11 PM   #2227
OZbeemer
OZbeemer's Avatar
Oddometer: 437
Computer question
So I am a Mac guy, so am fairly ignorant about the windows systems. Will the tunecu work on a machine running windows ME ( millenium edition)? A friend offered one for free if I want it. Not sure if the OS will work with the tuneecu software.
OZbeemer
500cc two-strokes are effective as laxatives too.
-Spikehead
OZbeemer is offline   Reply With Quote
Old 06-18-2013, 04:40 PM   #2228
tacosupreme
tacosupreme's Avatar
Oddometer: 270
Agreed. I have the LC-1 with an MTX gauge. Solid gear for sure, and worth it's weight in gold for tuning.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 06-19-2013, 04:47 AM   #2229
RoundOz
Plenty of seasoning
Oddometer: 1,004
Have you thought about running a Windows emulator on your Mac?Whether this will work or not might be a question for Tom or Alain...
OZbeemer
2009 KTM Adventure
Old 06-19-2013, 07:48 AM   #2230
John_L
Oddometer: 527
No idea on Windows ME but I am running Parallels and Windows XP SP2 and it works great. Give it a shot and let us know.
OZbeemer
John_L is offline   Reply With Quote
Old 06-19-2013, 07:50 AM   #2231
BMacW650
BMacW650's Avatar
Oddometer: 747
OZbeemer
Windows ME will not suppor the required .Net Framework for the software.
Mac running bootcamp or virtualbox/parallel and windows will run perfectly fine.
BUT I borrowed a laptop from a friend just to reduced the amount of things that can go wrong.
BMacW650 is offline   Reply With Quote
Old 06-19-2013, 04:21 PM   #2232
Rally_West
Central Scrutinizer
Oddometer: 142
Originally Posted by Dagwood_55 View Post
07 with 2 to 1 Remus exhaust
CPR Rottweiler
SAS blocked off
Smog/canister/etc removed
Hologan football butterflies
Anyone with similar setup got a map that works well??
Or suggest one...
Not all that interested in extra HP, except on the
low end. I need more grunt there, and I want better
fuel economy.
Thanks,
You get a map or a suggestion...I am running the same setup 'cept I got no butterflies at all (bike came that way). I was thinking the Acro map and tweak it a tad. CPR is near me so I am gonna work with him for maps for our older ECUed bikes...but still need a good starting point.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Old 06-19-2013, 07:19 PM   #2233
OZbeemer
OZbeemer's Avatar
Oddometer: 437
Solved the computer issue. Found a toshiba laptop at best buy for 279.00.
Loaded that with tuneecu ( will also use for my Garmin stuff and the repair manuals). Loaded the Akra map with the o2 sensors on and butterflies installed. Has wings exhaust. Hope its right.
Gonna trail ride this weekend.
-Spikehead
Old 06-23-2013, 05:21 AM   #2234
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 971
Just installed the 06 Akra map. Much better fueling. No poping on decel. Only done 20k`s so no idea of mpg. Didnt get time to even check TPS or TB ballance. Another day.
Great software.
rossguzzi is offline   Reply With Quote
Old 06-23-2013, 06:06 AM   #2235
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 896
Great software.
Most likely the mpg will drop a bit. Don't touch the TPS unless utterly necessary. It's a sensitive thing
690R
Times are GMT -7.   It's 05:17 AM.
