Old 07-31-2013, 09:02 PM   #2281
Reese
Oddometer: 30
Originally Posted by Dagwood_55 View Post
So, I've done everything I can think of to connect to the bike.
Bear in mind, when I first got the cable a few weeks ago, connected right up, green light and ser no read.
Bike is a 07 S Adventure, CJ's cable, Win 7 notebook.
I've re installed TuneECU, uninstalled and reinstalled the drivers, tried several diff drivers. Downloaded something that read my USB device and recognized it. Tried serial port, USB port, Com1 thru 4, VCR (?) on and off, tried connecting every conciveable variation of key on, hook up, etc that I can think of.
Got power to 1 connection of the bikes plug, still power to the next connection.
Checked and read every thread that is out there.
But I still must be missing one little thing and its fustrating as can be, especially since I've already connected once before.
Any ideas??
The second or third time I connected I ended up bending one of the pins on the cable. It looked and felt like it was plugged in but I wasn't getting a connection. Bending the pin back with a screwdriver and being very careful to not force the plug has kept things working.
Hopefully it's something as easy as that.
Reese is offline   Reply With Quote
Old 08-01-2013, 10:53 AM   #2282
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,336
I think I've narrowed it down to the ODB cable or box. The ODB LED light will not come on when connected to the bike with the ign switch on. I've taken the cover off the ODB, and when I touch the grounded test light to one side of the LED, it will power up, tho I'm not sure what that is telling me.....
I have power into it the ODB, on the #16 pin, but have no power at any of the 4 wires coming out of the ODB.
So, should one of these 4 exit wires from the ODB have power, or light up a test light??
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 08-02-2013, 02:12 AM   #2283
RoundOz
Plenty of seasoning
Oddometer: 1,004
Not sure if I understand where you are saying your problem is but here is a fault finding routine for an OBD2 connector. If some of this doesn't apply just google similar search terms.
http://youtu.be/0e-9_FuMWzI
Note the different voltages and partial grounds he finds on these pins...a multimeter will tell you a lot more than a test light.
Note that ODB and OBD are often confused, it stands for on board diagnostics. Wikipedia is a good source for standard pinouts.
AFAIK 990s are not fully OBD2 compliant, so taking all you read with a grain of salt and comparing with another 990 might be advised. Perhaps Powercell or other adaptor cable makers could tell you what to expect on the pins.
2009 KTM Adventure
RoundOz screwed with this post 08-02-2013 at 02:22 AM
RoundOz is offline   Reply With Quote
Old 08-03-2013, 07:05 AM   #2284
JayRider83
JayRider83's Avatar
Oddometer: 42
On the Tune ECU fuel and ignition maps. Shat do the numbers actually represent. Are they fuel percentage, injector pulse with?
Sent from my DROID RAZR
Semper Fi
JayRider83 is offline   Reply With Quote
Old 08-04-2013, 07:37 PM   #2285
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Milligrams of air.
tahoeacr is offline   Reply With Quote
Old 08-04-2013, 08:23 PM   #2286
renogeorge
Oddometer: 1,364
Dumb Questions
OK. I have been following along trying to understand what the Tune ECU will allow me to do. Sorry if these questions have been asked and answered:
1. When the bike connected with the Tune ECU cable to a computer running their program, am I able to get an engine running analysis--in different RPM ranges, as measured by milligrams of air??? or what is it that is measured and what info is passed on to me for analysis?
2. I think I get the fact that I can download and install a program that someone else has created. Do these programs alter FI timing, ignition, both or???
3. Am I able to get meaningful AF data or ? other data in various RPM ranges with just the stock KTM probes and FI monitors? Or do I need another device, probe, something else to get the data I need for tuning?
4. If I am going anywhere near the right direction with my questions, can I expect to get measured data that is useful for tuning without load on the engine via a dyno or on the bike setup?
5. If I want to try developing my own map, can I adjust various RPM ranges, making them richer or leaner based on my seat of the pants feel for how the bike is performing? Basically can I "jet" the bike with the Tune ECU setup?
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 08-04-2013, 09:44 PM   #2287
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
1) No. No measurement is taken. The mga is just so the ECU knows how much fuel to add. Raise the # and the ECU adds fuel in that cell etc. Probably calculated by some KTM engineer. No engine running info from TuneEcu is useful. You need a wideband to tell what is really going on.
2) Not FI timing. That is a different beast. Just pulse width and ignition timing.
3) No. See #1 answer
4) No. Need to load the bike. Kingsbury grade does this real well. Your going the right direction but I'm sure the answers aren't what you want to hear
5) That depends on how "in tune" you are with your bike. 80-100% TPS needs a wide-band.
Old 08-04-2013, 10:02 PM   #2288
renogeorge
Oddometer: 1,364
Thanks Jeff,
So the Tune ECU doesn't tell me anything about the AF ratio? Does it just tell me what is programmed for that cel?
Is a "cell" an RPM range?
So I can add or take away fuel in each cell with the Tune ECU?
I don't claim to have the most accurate butt dyno around but I do a pretty decent job of jetting. If I am willing to put the time into the trial and error, logging results etc., what are my chances of coming up with a custom map which is a meaningful improvement over stock.
I am going to read up on wide bands and not hit you with more dumb questions on that.
Thanks very much!!
KTMs--300, 518, 990
Old 08-05-2013, 09:00 AM   #2289
renogeorge
Oddometer: 1,364
And......how large are the cells--500 RPM, 1000 RPM???? And how many are there to work with?
KTMs--300, 518, 990
Old 08-05-2013, 09:03 AM   #2290
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Thanks Jeff,
Thanks very much!!
The best way to see how the program works is to download it. It's free. You can mess with stuff without connecting it to your bike just to see how it works.
That said, I spent a lot of time when I first got it "jetting" my bike just as you describe, and I got a significant improvement over the stock map pretty easily. It's a LOT easier than real jetting since you don't need to do anything except pull the seat and plug in a cable. The biggest issue for a carb tuner to get his or her head around is that this makes specific changes at specific points. There's no "ranges" to deal with, no real overlap, etc.
I'm currently running a powertripp map that's a really good premade solution, but keep thinking about returning to that map I was working on before....
Unfortunately my "tuneecu" laptop is currently dead. Never had THAT problem with a carb.
Anyway, yes, you can "jet" to your heart's content. Wit lots of interval saves you can also return to any prior point with a mouse click.
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 08-05-2013, 09:47 AM   #2291
renogeorge
Oddometer: 1,364
Duh! Thanks Alleycat. I downloaded the program and see the cells. Didn't think about throttle position as an additional cell definition. Obviously need that input.
Is it possible to leave a small netbook hooked up and on the bike while trying various settings? Leave off top/glove box plastic and right side tank maybe.....
I am thinking that adjusting settings after stopping would be the best...
KTMs--300, 518, 990
renogeorge screwed with this post 08-05-2013 at 10:34 AM
Old 08-05-2013, 01:04 PM   #2292
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
You could do that. TuneECU will show you some values while the bike is running. BUT, there is no huge advantage to doing that. You need to shut the engine off to write a map to the ECU. When you write a map on the ECU, it will also erase some of the ECU settings it learned about the bike and sensor ranges (read about Initialization). It will take some time for each map to 'settle in', sometimes several hundred miles and several heat cycles to show problems and/or changes.
Better tuning tools would be: mark your throttle positions on the throttle tube and housing from TuneECU readouts, hook up a vacuum gauge, install a wideband O2 sensor, hook up an electronic vacuum balance gauge, carry a note book and write down the problem areas (as in RPM/Throttle position/mixture). Make changes and Initialize from a cold engine. Ride those settings for a while and note improvements.
"Son, you can't do both"
Old 08-05-2013, 01:37 PM   #2293
renogeorge
Oddometer: 1,364
Thanks Zoob. I was overlooking the need for the ECU to re initialize after changes are made. I get most of your suggestions. I have the tool for syncronizing and the ability to measure throttle position. What is the vacuum guage for? I am resisting the purchase of a wideband at this point. May be kidding myself but I'd like to try richening/leaning cells based on my seat of the pants observations as to rich/lean running in the various RPM ranges and at different TP. Like most, my concerns are with the lower RPM ranges--say 2500-5000 and in the lower TP areas--say 10-40%. Still a lot of cells and a lot of trial and error......
Not looking for peak dyno numbers or race bike performance, just rideability and fuel mileage
KTMs--300, 518, 990
Old 08-05-2013, 07:24 PM   #2294
Alleycatdad
Oddometer: 1,439
To measure throttle position, use tuneecu. That way the values will be closest to what the program uses. Easy enuf to mark the grip and switch housing.
SA
Old 08-05-2013, 07:30 PM   #2295
renogeorge
Oddometer: 1,364
Gotcha, I think. So Tune ECU will give me usable TP info on a running engine--% open or voltage to determine?? I have used the throttle tube marking for jetting many, many times. But I like the accuracy of matching my markings to the TUNE ECU measurements.
Thanks!!
KTMs--300, 518, 990
Times are GMT -7.   It's 05:21 AM.
