Old 11-04-2013, 08:24 AM   #2461
Bearcat263
Bearcat263's Avatar
Oddometer: 116
Well this may not be the place to ask this question but going to anyway. been reading on this tuning thing, the 15 min. or new tunes with a computer, my question to someone that's smarter than i am is, did the sas and canisrectamy. removed all the smog stuff went to wings exhaust still running the stockish air filter it's a K&N filter did the 15min idle after all was put back together still getting in the 38-42 range on fuel mileage do I need to do new tunes or run it like it is, the thing just runs and runs well.
Thanks Mike
A bad day of hunting, fishing, or riding sure beats a good day of work.
2000 ZRX1100
2008 KLR650 sold
2012 KTM990
Bearcat263 is online now   Reply With Quote
Old 11-04-2013, 08:49 AM   #2462
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 962
Does it pop severely on decel? If not, carry on
38-42 mpg is quite nice
690R
Old 11-04-2013, 12:57 PM   #2463
Bearcat263
Bearcat263's Avatar
Oddometer: 116
no it doesn't pop on decel. so i guess just keep riding it
2000 ZRX1100
2008 KLR650 sold
2012 KTM990
Old 11-04-2013, 02:18 PM   #2464
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
You're probably ok but borderline if not slightly lean. The combination of the higher flowing K&N air filter, SAS and canister removal, and higher flowing exhaust come together to add more air to the mixture. The 15 minute idle can't handle that extreme of a change. I'd recommend getting the Tune ECU cable and installing the Akra map for starters.
Old 11-05-2013, 05:41 AM   #2465
jeffjones
"offroad shit"
jeffjones's Avatar
Oddometer: 158
Thanks Mike
If you don't have ability to check the AFR on a dyno you can always remove the spark plugs and have a good idea of whether its to lean or not.
google spark plug reading for images of what to look for and colors that tell the story.. Better to take the time to find out if its lean or not before melting a piston down.
Decel popping is only and indication that the closed throttle range is to lean, and isn't an indication that say the cruising rpm at 10% throttle is lean and that's where engine damage could happen.
With tunecu you can take a working map that is showing on the plugs to be a little on the lean side and increase the fuel percentage for the entire map and both cylinders just to be on the safer side until you can dyno check it under load runs.
Blah
jeffjones is offline   Reply With Quote
Old 11-13-2013, 12:22 AM   #2466
two trackin fool
two trackin fool's Avatar
Oddometer: 1,324
Android Tablet ?
Is anyone using a Android Tablet to run these programs on their bike ? I have been looking at past pages but no mention that I found .
I thought that I had read some using their phone but I don't even see that post now .
Thanks in advance !
Stay Patient and Trust your Journey
'10 990 in White
two trackin fool is offline   Reply With Quote
Old 11-13-2013, 06:19 PM   #2467
Mleaky
Mleaky's Avatar
Oddometer: 214
Any suggestions for an '07 Adventure with stock intake, FMF Q4ti's? I installed the Akro map via tune ecu, but still have a lot of decel popping, a flat spot around 4600-4700 rpms and low RPM jerkiness.
2007 KTM 990 ADV
Mleaky is offline   Reply With Quote
Old 11-13-2013, 07:10 PM   #2468
BigTony
Oddometer: 237
I've got an '07 myself...leo vince with spark arrestors and stock air box. On the stock map the plugs looked OK, but it would definitely pop a lot on decel (so I believe the O2's kept the AFR in a decent range at cruise)
I tried the akro map in the past with really heavy fuel consumption and the bike would occasionally cut out if I chopped the throttle.
However I just removed SAS and canister, and tried the Akro map again, except with O2's enabled. Surprising to me it's actually running pretty decent (no popping for once!) and my fuel range has varied from 34 in dirt to 40 on road. Low RPM is quite smooth but I do still have a very faint flat spot in the same range you mention.
I'd resisted doing the sas and canister for a long time but it really is running much better. Also, enabling the O2s on the Akro map might be worth a try...
On a side note, I actually left the canister in place and am venting the tanks through it. However I removed the pump and replaced the hoses into the intake with some longer hoses that run up under the glove box and are used for TB synchronization. I think I got a much better TB sync using a simple home made manometer hooked up to my new hoses than by using the MAP sensor readings in TuneECU.
Now that I've got it running nice, I'm planning to screw it back up with a new intake!
BigTony screwed with this post 11-13-2013 at 07:18 PM
BigTony is offline   Reply With Quote
Old 11-13-2013, 07:21 PM   #2469
Mleaky
Mleaky's Avatar
Oddometer: 214
I should have noted that I turned the O2's on, on the Akro map.
2007 KTM 990 ADV
Old 11-14-2013, 06:03 AM   #2470
jeffjones
"offroad shit"
jeffjones's Avatar
Oddometer: 158
Same shit here (except leo's).. I even played around with the maps by hand and I could only get it a little better without going to a dyno to see where the AFR's where..
BUT, after removing the canister and SAS crap (with install of aftermarket intake) it runs great on the akro ktm map..
I'd bet if you just did the canister and SAS removal it would run better..
Blah
Old 11-14-2013, 07:42 AM   #2471
Critic
More or less!
Critic's Avatar
Oddometer: 1,309
I bought a DynoJet Commander III for 07-08 KTM 990 ($4XX); then turned around a bought a Baja. So, I have a Power Commander III for sale @ $180. PM me, if interested. So far, he Baja has been a great experience with no popping, smooth throttle, stronger pull, and 42-43 mpg. Plus, I got a deal that I couldn't pass up.
It is always something! Rosann Rosanadana!
Moto's: 300xcw,500exc,990Baja
Moto's past-BigBear250,T100cs,Savage250s,TS185,DT175,GT550,TY250,XR200/350/250,R75/7,Ft500,RD350,YZ125,KDX175,SP500,K1000rs,DR250,883,S1,ST2,KLX650,KE100,GS1000,Monster,Vstr om1000&650,950adv,625sxc,250SSherpa,530exc,990adv, 690e
Critic screwed with this post 11-16-2013 at 06:08 AM
Critic is offline   Reply With Quote
Old 11-18-2013, 06:51 AM   #2472
ADVill
Oddometer: 611
Can someone recommend a flash for a completely stock '08 990 to help eliminated off idle snatch?
Thanks....
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 11-18-2013, 09:57 AM   #2473
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,176
I had a rare high idle last year.
I am running the ITG air filter with a customized map. Wings are installed with small outlets. Idle used to hang at 2500 or 4000 from time to time, not too often. I checked TPS today and was at 0.78 . I adjusted it at 0.55 and idle would hang at 5500. Adjusted it at 0.67 and was hanging at 4500 for a while, settling later at 1500. When I turned the throttle, it would climb to 4500 again. Finally adjusted it at 0.62 and it settled at 1500, then TPS moved to 0.59. The bike was at fan operating temperature 107C.
Now it seems to idle at 2000 for a short time before settling at 1500. I will keep it this way for a while...
I would like to ask if adjustments should be done on a cold bike? or while fan is running?
Cheers.
gefr screwed with this post 11-21-2013 at 12:56 AM
Old 11-18-2013, 10:03 AM   #2474
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,199
Originally Posted by gefr View Post
I am running the ITG air filter with a customized map. Wings are installed with small outlets. Idle used to hang at 2500 or 4000 from time to time, not too often. I checked TPS today and was at 0.78 . I adjusted it at 0.55 and idle would hang at 5500. Adjusted it at 0.67 and was hanging at 4500 for a while, settling later at 1500. When I turned the throttle, it would climb to 4500 again. Finally adjusted it at 0.62 and it settled at 1500, then TPS moved to 0.59. The bike was at fun operating temperature 107C.
I would like to ask if adjustments should be done on a cold bike? or fan running hot?
Cheers.
TPS is always adjusted with a warm bike (15 min ride or so).
Engine OFF but ignition ON.
The baseline is 0.60v when set properly (warm).
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 11-20-2013, 09:20 AM   #2475
Loui€
Rides With Reindeer
Loui€'s Avatar
Oddometer: 50
yes, this is true, 0,60V warm engine ('working temperature').
anyway, I have a feeling (eg. 2011 fueling copy-pasted to 2008 map), that these adjusted maps we use/make do have tendency to affect to idling speeds somehow (don't know if really, and/or why), rising them to 2000-2500 rpm for while before setling back to 1500...
ITG foam filter -system may alter the ambient temp sensor operation comparing to stock box behavior, too. (don't know for sure, just guessing)
time will show, still testing ITG, leo vinces and mapping... and snow is coming soon - maybe tomorrow...
L
2008 KTM 990 ADV
Loui€ screwed with this post 11-20-2013 at 09:52 AM
Loui€ is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
