Old 04-14-2014, 10:47 AM   #2701
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 281
Originally Posted by Spark01 View Post
Do you have the SAS system still connected?, also it sounds that the map is pumping some extra fuel when closing the throttle during shifting.
What is your F-L switch settings and around which engine rpm are the flames appearing
SAS system is connected but SAI has been unchecked from the map.
F-L setting are from 07-08 akra map. Flame appears usually in low to medium revs and medium throttle. Do you think this could be something to adjust?
Pics and vids
种. is offline   Reply With Quote
Old 04-16-2014, 04:43 PM   #2702
99spike
n99b
Oddometer: 11
Originally Posted by Rodknee View Post
i thought the valve in front of the airbox was part of SAS? it is a different circuit? i was chasing my tail uploading/downloading US maps, disabling SAS but i was still getting p0444 purge valve FI codes.
i finally ended up using an EU R map, which i disabled SAS and the problem is resolved.
how do you disable the purge valve in the US map? can you do this in tuneecu? or if i eliminate the purge valve, i have to use a EU map?
The valve in front of the airbox on US spec is the Purge valve for the canister (blink code 54 if unplugged or p0444), The SAS is behind the airbox above the rear cylinder (blink 53 or p0413). The latter can be turned of in TuneECU, but not the former. Interesting that EU map fixed it. I understand the EU bikes have no purge valve so makes sense. What other changes are there in an EU map, good or bad? Is this the elegant fix for the purge removal that beats the 22K resistor mod?
99spike is offline   Reply With Quote
Old 04-18-2014, 05:08 AM   #2703
GLRRA47
Oddometer: 88
Purge Valve
I recently did the SAS and canister removal - along with Rottweiler intake and exhaust. I left the purge valve connected to electrical to avoid an error. However, now hear a whine when decelerating at about 3K or so. Wonder if it's the purge since no longer hoses connected to it. I just picked up some resistors from Radio Shack and plan to remove the purge valve and jumper the connector with the resistor. (Instructions how - are on the web)
GLRRA47 is offline   Reply With Quote
Old 04-18-2014, 10:32 AM   #2704
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,089
The valve won't make more noise than just a small click. You may have a vacuum leak?
"Son, you can't do both"
Old 04-18-2014, 10:53 AM   #2705
BigTony
Oddometer: 233
So long as the purge is still hooked up when you load a map in tuneecu with sas unchecked, you can then remove the purge and you won't get any error codes and no resistor is needed
BigTony is offline   Reply With Quote
Old 04-18-2014, 04:04 PM   #2706
GLRRA47
Oddometer: 88
Ah - yes - click only - just tested that. And I didn't know SAS unchecked eliminated the purge valve error. Well, there's now a resistor - so double sure now. Guess the whistle / whine I hear must be something associated with the air box removal. Probably it was always there - just never hear it. Maybe butterfly motors I never heard when the air box was in place? In any case she's running great.
Old 04-18-2014, 07:25 PM   #2707
99spike
n99b
Oddometer: 11
Can I ask : What map are you running?
Using KM601US0704501Map & SAI unchecked SAS code goes away after load, but cannot get purge code to stay off without leaving the purge valve connected. I am wondering if anyone knows the difference between US map and KM601EU0704501Map? Just Purge? or something else? Is this a viable plan B? Or am I just doing it all wrong.
Old 04-19-2014, 03:54 AM   #2708
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,707
spike, i had the same problem as you. on my US bike, a 2012, i uploaded/downloaded maps 10x with all of them having SAI unchecked. i had the purge valve error after unplugging it as well. big tony is incorrect regarding this.
once i downloaded KM601EU1102002 from tuneecu and disabled SAI and reuploaded it into the bike, the problem was resolved. i do not have a resistor at all, i just have the connector removed. again, no lights in the last 3 rides, so i think it is good to go.
i compared the above map to my stock map, and it seemed to be identical. i compared each tunable function and they seemed to be the same, so i am content with the map. i did not want to make any changes to the map at this time, other then SAI and purge valve removal.
Originally Posted by DUCATIJAY
Don't quote me in your signature, you make me sound like an a55hole...
2015 Rides: Katie M Big girl, Berg Hoon'icycle, Katoom 3hunny (pic)
Rodknee screwed with this post 04-19-2014 at 04:11 AM
Rodknee is offline   Reply With Quote
Old 04-19-2014, 08:39 AM   #2709
BigTony
Oddometer: 233
I used the same map (KM601US0704501Map) when I first removed the sai. This is a 2007 btw.
I initially removed the purge, then powered up tuneecu and loaded the map with sas unchecked. This resulted in an error code .
Then I plugged the purge in and reset error codes with tuneecu. I went for a ride and confirmed no error code. Then after turning the bike off and on, with purge still hooked up and no pre-existing error code, I reloaded the map with sas unchecked. I then turned the bike off, removed the purge, and the error code hasn't returned since. I figured the key was loading the map without a pre-existing error condition, and removing the purge subsequent to that with power off..
I don't know about newer bikes but it most definitely works on my 07, and lots of folks have reported this working without resistors per my search on trying to fix my issue. Keep at it - it'll work. Just trying to help
Old 04-19-2014, 09:26 AM   #2710
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,089
The key is to load the map first, then pull the SAS. Otherwise, the existing map will set the code before you load the new map.
Old 04-19-2014, 11:41 AM   #2711
99spike
n99b
Oddometer: 11
Thanks for the answers. They're all appreciated as they contribute to an increase in understanding of this problem, and the clarification of a software based resolution.
keep em coming.
Old 04-19-2014, 11:52 AM   #2712
99spike
n99b
Oddometer: 11
Ditto '07 990.
Just to make sure I am clear we are talking about the Purge error (P0444), and not the SAS pump error (P0413?)?
That said, the only difference I see is that you "went for a ride" with the purge hooked up. If that's the case, and considering I've now ridden multiple times with the purge in, and no codes, all that's left is to remove it again. Will try one last time before going to the EU map. Watch this space.
Old 04-19-2014, 12:42 PM   #2713
renogeorge
Oddometer: 1,395
OK. My '07 is running well from 3000 up. I am happy enough with power and mileage. Maybe a small lag cracking throttle from near idle. But my concern now is with the lower RPM and throttle opening area--below 3000 RPM and throttle openings under 10%. At idle and up to 3000, bike is very rich.
Currently F-L switch is at 20% opening in this RPM range. Should I work on leaning the F map or lowering the switch to get to the L map sooner? Are there some basic minimums on running on the F map--like don't set switch below xx%?
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 04-19-2014, 12:52 PM   #2714
azoto
azoto's Avatar
Oddometer: 9
Lm-2
Hi everybody,
I'm trying to use LM-2 to log afr, RPM and TPS and everything is working fine when I try to accelerate while not riding. When riding it all I can log is AFR since the rest seems to be stuck at a certain level.
Anyway, right now I already achieved around 45-48 mpg with 2-1(with baffle) and an open air filter.
Any idea to fix my problem is really welcome
azoto is offline   Reply With Quote
Old 04-19-2014, 12:56 PM   #2715
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
45mpg!?
What problem????
Me bike must have a fuel leak....
Raid de L'Amiti 2011 RR (link)
690R
Times are GMT -7.   It's 05:20 AM.
