Old 04-19-2014, 02:48 PM   #2716
azoto
azoto's Avatar
Oddometer: 9
Originally Posted by Gustavo.Ramos View Post
Me bike must have a fuel leak....
that's what I thought before reading of someone achieving up to 60 mpg...
The problem is the LM-2 not reading RPMs and TPS position correctly
azoto is online now   Reply With Quote
Old 04-19-2014, 02:52 PM   #2717
renogeorge
Oddometer: 1,330
You have my attention. I have similar exhaust and intake and would love to talk with you about your map and the LM-2. I have been looking at similar devices. Are you able to use the single channel/cylinder model and then adjust for the rear cylinder??
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 04-19-2014, 02:59 PM   #2718
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 888
IIRC that ride was mostly downhill tucked behind the screen. I'd be fairly happy with low 40's with CPR filter + akros
690R
Old 04-19-2014, 03:18 PM   #2719
azoto
azoto's Avatar
Oddometer: 9
@renogeorge
Right now I'm running the original R map (2011 even thou mine is a "regular" 2009) leaner by 2% from 0 to 20% TPS and up to 7000 RPM. L map -2% everywhere but last 2 columns.
It's still a little bit on the rich side, but much more closer to what I'm looking for (i.e. around 14.7 when cruising and richer when accelerating).
I'm using a single channel LM2 monitoring its wideband sensor on front cylinder.
All the mod are mirrored on the rear cyl maps, but I'll check its AFR later on.
Next step (map's ready, but weather's not) is to smooth the ignition map in the range around 2500-4000 rpm.
The akro map gave me an afr around 11-12 almost in every occasion...
my 2 cents
PS: please note that I haven't tested the rear cylinder, and, above all, have no idea of what I'm doing: so don't take my words for it
edit: no snorkel and o2, epc and sai(sas) are disabled
azoto screwed with this post 04-19-2014 at 03:26 PM
Old 04-19-2014, 03:44 PM   #2720
renogeorge
Oddometer: 1,330
Thanks Azoto. I appreciate the information!
I was just reading some reviews on the LM-2. Not being able to log RPM seems to be a common complaint.
KTMs--300, 518, 990
renogeorge screwed with this post 04-19-2014 at 09:40 PM
Old 04-20-2014, 02:15 AM   #2721
azoto
azoto's Avatar
Oddometer: 9
but as far as I understand Tahoeacr and Procycle made it
Old 04-20-2014, 02:25 AM   #2722
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,118
Mine has no issue logging rpm. Did you connect the analog 0 pickup?
Verstuurd vanaf mijn LG-D802 met Tapatalk
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 04-20-2014, 02:43 AM   #2723
azoto
azoto's Avatar
Oddometer: 9
Thanks StevenD for the reply. Yes, I connected the dedicated wires (marked as RPM- and RPM+ on the manual). I can see the right numbers while idling, but that's all
Old 04-20-2014, 04:25 AM   #2724
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,118
I only used 1 wire, the analog + and pin it with a needle to the white+color of a coil wire. Just insert it next to the wire, so no splicing required.
Old 04-20-2014, 06:22 AM   #2725
azoto
azoto's Avatar
Oddometer: 9
I used the blue-white wire from the ecu connector for RPM+ and another color I don't remember right now for RPM-... I read somewhere that this configuration has been used on a 990 and it worked.
I'll give a try to your solution. Thanks a lot!
Old 04-20-2014, 03:45 PM   #2726
Rodknee
I wish I was Ghetto
Rodknee's Avatar
Oddometer: 2,338
just finished up flashing a friend's bike. he has just akro slip ons, and i uploaded KM601EU1180232map. he said the bike was much smoother and lifts up easier in third then it did before.
thank you tuneecu for the awesome program!!
Originally Posted by JustRon View Post
my ass was jealous of Rodney's day-long-ass.
Originally Posted by DUCATIJAY View Post
I did not trip and fall. I attacked the floor and I believe I am winning.
NY to Alaska Ride Report Aug 14'
2014 Rides: Katie M Big girl & Berg Hoon'icycle
RIP Buddy 1999-2014
Rodknee is offline   Reply With Quote
Old 04-20-2014, 10:26 PM   #2727
renogeorge
Oddometer: 1,330
The secondary throttle setting for my map are zero up to near idle RPM and then ramp up very slowly--not reaching 20% until 2000 rpm and throttle opening exceeding 10%. I am working on a custom map to clean up a rich condition below 3000 RPM at small throttle openings. I have been leaning out the F map. Should I also look at adjustments to the second throttle? Increase %s to lean? Disable second throttle?
Any help would be greatly appreciated!
KTMs--300, 518, 990
Old 04-23-2014, 01:17 PM   #2728
hutch990r
Oddometer: 11
new guy here,
could anyone point me in the driection of a step by step for adjusting the throttle cables on a 2012 adv R using the TUNE ECU software? I have searched and searched but have been unable to locate a step by step procedure on this. I have a Cable in route to my house from CJ, and would like to take up the slack in the cables when i get home from work.
thanks
hutch990r is offline   Reply With Quote
Old 04-25-2014, 12:02 PM   #2729
Sacal
Sacal's Avatar
Oddometer: 132
Originally Posted by hutch990r View Post
new guy here,
thanks
It's all on the TunECU site http://www.tuneecu.com/TuneECU_En/tasks.html
Adjusting the throttle cable - KTM only
The idle speed control stepper motor will be completely retracted and the throttle valves completely closed.
Switch the ignition switch off, WITHOUT exiting or disconnecting the software, and adjust the throttle cable clearance.
ad astra per alia porci
Sacal is offline   Reply With Quote
Old 04-25-2014, 12:40 PM   #2730
dgjackson40
Oddometer: 247
Sacal has it right Hutch990r, I put a new air kit on mine yesterday and it ran pretty crappy and idling down and stalling at stop signs. I went back to the garage and used TuneECU to retract the steppers with the throttle adjust selection and adjusted. Runs like a scalded cat now! Idles just fine at 1450 at stops now. And it was only a subtle adjustment that did the trick.
The trail is the thing, not the end of the trail. Travel too fast and you miss all you are traveling for. Louis l'Amour
2007 KTM 990 Adv; 2005 VStar 1100 Sold!; 2002 GL1800
dgjackson40 is offline   Reply With Quote
Times are GMT -7.   It's 01:37 AM.
