Old 08-23-2014, 08:53 AM   #2926
RoundOz
Plenty of seasoning
Oddometer: 1,017
Originally Posted by mjskier View Post
Any pointer to a tutorial on using tuneECU to adjust cable/throttle/TPS?
When I installed a map on my SMT, I played a bit with the monitoring and noticed that when my throttle was wide open tuneecu thought I was at 90% open or so.
Not a big deal since I usually ride my bike (SMT) in mid rpm, but I want to eventually set it right.
Check post 2729 and 2732. Pages 273,274. The adjust procedure is in the workshop manual, but its fairly simple...once the stepper motor has closed the throttle all the way, you want a little slack...turn your bars both ways to make sure slack doesnt disappear.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 08-24-2014, 09:56 PM   #2927
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,148
Don't worry about wide open throttle settings. The idle value is the one you need to set.
"Son, you can't do both"
Old 08-25-2014, 01:13 PM   #2928
sweetlou
small body, big balls
Oddometer: 1,461
Has anyone measured what the cruising Throttle percentage is? Say 70mph, constant throttle. Maybe 10%? 15%? Anyone actually measured?
[2013 KTM 990 SM-T] - Wings, LED aux lights, et al.
[2014 KTM 690 Enduro R] - Wings, Nomadic rack, et al.
[2009 KTM 250 XCW(e)] - NY Street Legal!
sweetlou is offline   Reply With Quote
Old 08-25-2014, 01:17 PM   #2929
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 286
Haven't tested 70 mph but 60 kmh is about 2 % on my bike. 90 kmh was somewhere around 5 % I think. 70 mph could be 10 %.
Pics and vids
种. is offline   Reply With Quote
Old 08-25-2014, 03:17 PM   #2930
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,148
Throttle position at cruse is dependant on load. I'm usually between 8-15% at 55-70 mph. Put some marks on your throttle at 8, 10, 15% and check it out.
Old 08-30-2014, 03:05 PM   #2931
felixblack1
felixblack1's Avatar
Oddometer: 201
connection issues
I'm having issues getting a connection to a 2010 990 R. I know the cable works on my 2008 Adventure fine. The blue led on the OBDII connector lights up when ignition is on but I get the red flashing indicator on the tuneecu program and then a connection error message. I searched the internets and have tried removing headlight fuse, battery charger connected, checked for bent pins in connector, laptop plugged into mains, ran with engine on, tried port settings on tuneecu site. I haven't tried running the cable shield to the earth pin yet. Anything extra I need to do to connect to a 2010 model which works fine on a 2008 model?
felixblack1 is offline   Reply With Quote
Old 08-30-2014, 06:51 PM   #2932
sweetlou
Oddometer: 1,461
TuneECU for 990 - got tunes?
Make sure the computer is recognizing the cable. I like to manually select the cable before connecting to the bike so I know the cable is working properly.
I think it's under "interface" it's the tab to the right of "ECU" on the top menus
Lou
Old 08-31-2014, 12:21 AM   #2933
felixblack1
Oddometer: 201
Thanks Lou, I tried that. The cable definitely works as it connects to my 2008 adventure no problem.
Old 08-31-2014, 02:55 AM   #2934
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 958
Hello, any news for the tuneecu connection on the 1190 Adventure?
Raid de L'Amiti 2011 RR (link)
690R
Old 08-31-2014, 06:09 PM   #2935
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,148
I suspect that won't happen. Traction control, abs, ride by wire, all too complicated.
Old 09-01-2014, 01:45 AM   #2936
Gustavo.Ramos
Oddometer: 958
When we're used to fuss with our bikes electronics it is like an addiction... getting a bike that is "limited" in that way then becomes like not getting the whole package...
lets see if we can convince our tuneecu friends!
690R
Old 09-01-2014, 05:38 AM   #2937
Hugerush
Furbrain
Hugerush's Avatar
Oddometer: 83
Link to Zuber's PDF?
Anyone have a working link to Zuber's consolidated pdf file?
This one seems dead (what am I doing wrong?).
http://www.toxplore.com/advrider/Tun...neECU_WIKI.pdf
Barring that, leaving in a week and wondering in I can get this working;
2010 990 Adv
Rottweiler CPR
FMF Q4 Dual Exhaust
Desmogged and SAS removed
Anyone suggest a good MAP to start with here?
Thanks for any help!
AMA - BRC - COHVCO
2011 530 EXC | 2010 990 ADV | 2006 FLHTXI (figure that out)
If the only tool you have is a hammer, everything looks like a nail
Hugerush is offline   Reply With Quote
Old 09-01-2014, 06:20 AM   #2938
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,193
2010 990 Adv
Rottweiler CPR
FMF Q4 Dual Exhaust
I am hosting the file and I am changing servers hence it's why it's down
send me an email address and I'll email it to you
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-01-2014, 08:20 AM   #2939
folknride
Old Adventurer
folknride's Avatar
Oddometer: 696
2010 990 Adv
Rottweiler CPR
FMF Q4 Dual Exhaust
I have the same set up - 2010 - Wings instead of FMF - and used the one from the CPR site - http://www.rottweilerperformance.com/Downloads.html
It works pretty well. Maybe not prefect - a bit of popping on decal and the occasional stall if you pull the clutch at speed, mileage down a bit - but overall it's fine. I'm referring to the first one on the list of downloads.
folknride is offline   Reply With Quote
Old 09-02-2014, 05:16 PM   #2940
RoundOz
Plenty of seasoning
Oddometer: 1,017
Can anyone compare the Rottweiler map labelled KM601EU1180232 with the Powertripp map for 2-1. I am looking to try the Powertripp one and see what looks to me like pretty big differences between them in all maps, some only in the top 20% of throttle position. Standard the Powertripp map has SAI checked although it was meant for a Wings 2-1... (?).
Also can anyone point me at a US 2011/12 R Akro map. All I see on TuneEcu is EU maps. ...problems using these (from the name I assume the Rotty map is based on an EU map. ...
2009 KTM Adventure
Times are GMT -7.   It's 05:19 AM.
