Old 01-09-2011, 05:08 PM   #301
shawty950
shawty950's Avatar
Oddometer: 243
Disregard
Disregard my issue....seems to be working great with 1.8.3.
Checked port settings and flow control was wrong. Set to xon/xoff (am sure I had this right when I set up initially, but it was wrong)and bits per sec back to 921600 and all good. Connects quickly even after running and killing via key or kill switch...soon as back on the software talks and connects right away.
On another note to do the diagnostic tests on the "test" tab...one has to double click each test/item...the box will go "green" and "Test Item" will show in the status bar at the bottom of window. At the end of the test, the green box goes off, and "Test Item Done" is in status. I am assumng that if it finds an issue, the error code section will be populated. (O2 sensor test is not supported...but others work ok)
Shawty
Originally Posted by shawty950
Thought it was just my machine...I get the same issue with 1.8 and above...never noticed with 1.7(not that I was experienced with it, as I think I started playing around w/ 1.7.9 only used it once or twice b4 going to 1.8). If I leave it disconnected for a while....close and re-open the program and it seems to connect. Thought it might be a too quick polling of the ECU having a comms contention. I tried slowing the "bits per second" on the port settings for usb serial port from 921600 to about half...jury still out on whether its better. Still a bit of a hit and miss affair.
Shawty
shawty950 is offline   Reply With Quote
Old 01-10-2011, 06:44 AM   #302
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
Hi Shawty,
I am pleased that you succeed.
Thanks for your feedback.
BR, Tom
Shawty
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 01-10-2011, 07:36 AM   #303
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
Originally Posted by Tom-Hamburg View Post
Hi Shawty,
BR, Tom
Hello Tom
I allready reacted on the german KTM forum, that i've tested the v1.8.4 version with succes.
But i didn't start my bike because with v1.8.1 i had no problems with losing contact with a running bike.
4-5minutes of idle and small revs while doing some test, no problem with the connection (i used the same settings that are posted in this topic and on the german ktm forum).
And my bike is currently parked in a small garage and not easy to move it outside, so starting it inside the garage is no option
But the problem i had with V1.8.3 was that i could not get any communication with my bike at all??.
But i allready reported back to Alain with some loggings.
'10 990SMT
Spark01 screwed with this post 01-10-2011 at 07:43 AM
Spark01 is offline   Reply With Quote
Old 01-11-2011, 04:43 AM   #304
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
2009 990 Adventure FI surge
I've had a read of many of the posts, but can't see if the TuneECU is considered a 'fix' for the FI surge.
I have a '07 990 Adventure with Wings exhausts, Akro map and annoying surge. Happy with the performance in all other aspects - just the surge makes it a prick at slow speeds.
Anyone?
Smugmug $5 discount coupon # 2ucrtCWwf7D7A
KTM Pilot is offline   Reply With Quote
Old 01-11-2011, 06:03 AM   #305
aldonc
aldonc's Avatar
Oddometer: 36
I have an '07 with the Akro exhaust. I was running the regular map previous to TuneECU and had the surge (with the Akro). I remapped with the Akro map and the surge is gone completely - different bike.
Sounds like there are other tuning issues with your bike? TPS, throttle body balance?
aldon
2007 KTM 990 Adv
2001 Ducati ST2
aldonc is offline   Reply With Quote
Old 01-11-2011, 10:26 AM   #306
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
Anyone?
No tuneecu is not a fix
But is a great help, because you can read out your sensors en see if there is something wrong.
But the first thing you should do and is already mentioned: is balance the throttle bodies and a TPS adjustment.
This helps a lot.
'10 990SMT
Old 01-12-2011, 04:13 AM   #307
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
Suggestions
OK, thanks for this - I'll give these a go first. Anybody have a link for TPS adjustment?
This helps a lot.
KTM Pilot screwed with this post 01-12-2011 at 04:21 AM
Old 01-12-2011, 04:34 AM   #308
lc8john
lc8john's Avatar
Oddometer: 537
Reverted mine from Akra map to stock.
Disabled the SAS and O2 via tuneecu and the bike now feels great!
Husaberg FS 570
lc8john is offline   Reply With Quote
Old 01-12-2011, 07:21 AM   #309
Killer Whale KTM
Life is the adventure!
Killer Whale KTM's Avatar
Oddometer: 722
Guy's,
I need your help.
I loaded the wrong map to my 07-990 before I knew what I was doing !
I have e-mailed Alain , who is trying to help me.Basically my 07-Adv now thinks it is a 09-R model and it won't let me load any maps for an 07-adv. It will not even try to start.
Alain said I need someone else with an 07-adv to read thier numbers in the upper lefthand corner of the map edit screen.
Serial-
Map-
checksum-
My checksum is 5197 but should be 780 I think.
Do any of you guys have an 07-adv hooked up to your computor ??
Thanks for your help !
Killer Whale KTM
Friend:"That ain't no dirt bike,it's a damn whale!" Me: " It may be a whale, but if it is, it's a KILLER WHALE !! "
Killer Whale KTM is offline   Reply With Quote
Old 01-12-2011, 08:52 AM   #310
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
Enough info i think so
'10 990SMT
Old 01-12-2011, 09:12 AM   #311
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 287
Is SAI the same as SAS? What does the EPC do in FI bike?
Pics and vids
种. is offline   Reply With Quote
Old 01-12-2011, 09:25 AM   #312
lc8john
lc8john's Avatar
Oddometer: 537
Yes it is (Secondary Air Injection System)
The EPC limits the engine RPM in 2nd and 3rd gear.
Husaberg FS 570
Old 01-12-2011, 09:49 AM   #313
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 287
Ok, thanks.
Pics and vids
Old 01-12-2011, 12:55 PM   #314
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,966
Originally Posted by Killer Whale KTM View Post
Guy's,
I need your help.
Serial-
Map-
checksum-
Killer Whale KTM
Does that help?
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 01-12-2011, 01:23 PM   #315
Killer Whale KTM
Oddometer: 722
Thanks, Michhub
I'll let y'all know my outcome eventually.
Thanks,
Killer Whale KTM
Times are GMT -7.   It's 11:04 PM.
