Old 03-09-2011, 06:02 PM   #511
gixxersteph
gixxersteph's Avatar
Oddometer: 626
Originally Posted by cpmodem View Post
The Shorai (I have an 18ah in my Ninefiddy) is about a 1/2 volt higher than a lead acid battery before the engine starts. After the engine is running, the VRR keeps the voltage the same no matter whether LFP or Lead acid battery.
Seemed to good to be true. Oh well.
gixxersteph is offline   Reply With Quote
Old 03-09-2011, 06:15 PM   #512
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
The Shorai should definitely help a fuel injected engine start better, since voltage drops much less while the starter motor is turning than the lead acid battery. This leaves the engine management system with more power on startup. Just that when the engine is running voltage is the same. If the slow self discharge rate of the Shorai turns out to be as they say, that will make a huge difference to m/c folks who have to leave their bikes out of service in the winter months.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 03-10-2011, 02:51 PM   #513
Killer Whale KTM
Life is the adventure!
Killer Whale KTM's Avatar
Oddometer: 721
Hi Guys,
It has been a while since I posted and thought I would respond to those who have inquired.
My plan was to take my bike to the dealer and let him try an ECU from a new bike to see if my ECU was the problem. Unfortunately he was sick but took time out for me but could not get his (new) software to run and re-initiate the new ECU so it would work on my bike. He was coughing and I could tell how bad he felt but neither of us wanted to give up.So.........he got out his (old) software and put a new map on my ECU. I was running the Akro map and he changed it to stock.I still don't know why I could not change it with Tuneecu. I kept getting the not compatible with your ecu warning.
Before I had a flat spot from 3000 to 5500 which made it impossible in the woods. Now I have a smaller spot from 2500 m to 3000 which is a lot easier to work around.
I've got to run now but when I hook it back up how do I save the map in my bike? Not the one that I choose from the menu ?
Also how much effect do you guy's think the exhaust system has on these "flat spots" ?? I have some fairly beat up FMF's on now.I'm sure there are some minor leaks around them somewhere. How big a deal is that ?
Since I had a flat spot with either map does that mean it's not the map ? Could that "spot" be where it switches from open to closed loop ? Have any of you guys "tuned " or "mapped" the spot out ? By adding fuel or dealing with the open, closed switch ? Can that even be done ??
Thanks for your time, I'll try to hook back in to Tuneecu as soon as I have time and report back.
Thanks'
Killer Whale KTM
Friend:"That ain't no dirt bike,it's a damn whale!" Me: " It may be a whale, but if it is, it's a KILLER WHALE !! "
Killer Whale KTM is offline   Reply With Quote
Old 03-10-2011, 08:57 PM   #514
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
Originally Posted by Killer Whale KTM View Post
Hi Guys,
Thanks'
Killer Whale KTM
killer whale, put the lap top down a ride just ride it buddy.
"I don't give it a name, but I always speak with it. I don't know if other riders do the same. This is not only a piece of metal - there is a soul" -Valentino Rossi
twodollardoug screwed with this post 03-10-2011 at 09:08 PM
twodollardoug is offline   Reply With Quote
Old 03-11-2011, 12:22 PM   #515
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
There is a new version of tuneecu v1.8.7
Map support for the 2011 SM/SMT/SMR
'10 990SMT
Spark01 is offline   Reply With Quote
Old 03-11-2011, 01:19 PM   #516
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
3-11-11 TuneECUv1.8.7 now released
* Support 2011 maps for 990 SM/SMT/SMR
* Added a procedure to adjust the throttle cable for KTM's
BR, Tom
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 03-11-2011, 05:28 PM   #517
Dusty
Dusty's Avatar
Oddometer: 1,301
Nice!!
Thanks Tom and Alain..
KTM only Adjusting the throttle cable :
The idle speed control stepper motor will be completely retracted and the throttle valves completely closed.
Switch the ignition switch off, WITHOUT exiting or disconnecting the software, and adjust the throttle cable
clearance.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 03-12-2011 at 07:56 AM
Dusty is online now   Reply With Quote
Old 03-11-2011, 06:13 PM   #518
Rideimal
Oddometer: 83
BR, Tom
Nice! My dealer wants $75 for that five-minute job. Thanks Tom!
Rideimal is offline   Reply With Quote
Old 03-11-2011, 10:43 PM   #519
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,192
BR, Tom
Thank you!!
bikyto is offline   Reply With Quote
Old 03-12-2011, 02:40 AM   #520
Swedemarine
Oddometer: 9
GREAT!!!
Thank you Tom and Alain!
BR, Tom
Swedemarine is offline   Reply With Quote
Old 03-14-2011, 10:35 PM   #521
shawty950
shawty950's Avatar
Oddometer: 243
TuneECU on PDA or portable?
So has anyone set up tuneECU on a small pda/windows compatible device to take with them on extended rides so they can plugin and read fault codes if anything goes pear shape??
Recommendations anyone for a low frequency of use and small machine that can be thrown in a tank bag/pannier ?
I dont know much about pda/small windows technology so hoping for some guidance.
Note: Dont want to spend mega bucks as it will only be for reading fault codes if the need arises on a trip.
Shawty
shawty950 is offline   Reply With Quote
Old 03-18-2011, 06:50 PM   #522
Tom-Hamburg
Oddometer: 84
Hi,
TuneECU is not compatible with Windows Mobile or Windows CE.
BR, Tom
Shawty
TuneECU
Old 03-27-2011, 08:41 AM   #523
Tom-Hamburg
Oddometer: 84
TuneECU1.8.8
!!!New Update Released!!!
TuneECU 1.8.8.
Some bugs fixed
Improved reading of ECU in KTM 990/1190
BR, Tom
TuneECU
Old 03-27-2011, 09:48 AM   #524
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
TuneECU 1.8.8.
Some bugs fixed
BR, Tom
good Job
'10 990SMT
Old 03-27-2011, 09:54 AM   #525
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
Originally Posted by Spark01 View Post
Originally Posted by grinns View Post
The last part is right. It is just a way to talk to the ecu. In fact you are asking the ecu to send you the data. It would be pretty easy to write your own datalogger. I thought about doing it, but works busy this time of the year.
I think the data is fast enough for troubleshooting, but not fast enough for tuning. I think Cyborg and Tahoeacr did it the correct way when they tuned there bikes.
That is same as i'm thinking, the obd2 function isn't very fast so if he wants to log to many channels than the data stream will not be smooth.
But that warning is also in the manuals on the inovate site.
What i want to log trough the obd2, is only the map/tps and rpm.
And this (i hope) will not be any problem.
Today a inovate dealer and i did a small test to find out of the LM2 obd2 function works with the KTM.
And...... it doesn't no contact at all.
I going to collect as much info as possible about the KTM and we will sent it directly to inovate.
Hoping that they can do something to make it work(change firmware).
Because i don't want to hard wire all the sensors on my bike.
'10 990SMT
Times are GMT -7.   It's 09:42 PM.
