Old 04-28-2011, 08:52 AM   #661
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,868
A question on CDIs.
My CDI is #60141031200 and was later superceded by 61041031200. does anybody know what are the diiferences? Quicker CPU maybe?
Cheers.
Old 04-28-2011, 12:12 PM   #662
chewbacca2264
Oddometer: 84
Edited post: struggled getting drivers loaded for the cable but finally figured it out........computer moron here!
2008 KTM 990 Adventure (Big Mama) FMF Q4'S, Denali LED lights, Heated Grips, HDB Billet Top Clamp, Wolman Tail Bag, Akra Map...for now.
chewbacca2264 screwed with this post 04-28-2011 at 01:05 PM
chewbacca2264 is offline   Reply With Quote
Old 04-28-2011, 03:07 PM   #663
chewbacca2264
Oddometer: 84
Okay so when I finally got the computer issues cleared up I loaded the akra map onto my 08 that has Q4's on it. Much better throttle response and noticed no hunting between 3500-4000 rpm range. Worried that my mileage is gonna take a hit but rides better so for now I will monitor it and go from there. This program is very nice......just wish I had a better handle on tuning......guessing that this bike could really be cleaned up by someone who has a clue!!!
Old 04-28-2011, 03:10 PM   #664
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,103
Are you running the map with the O2 sensors enabled or disabled? Is it the the '08 map, or a later version?
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 04-28-2011, 03:50 PM   #665
chewbacca2264
Oddometer: 84
Running the 07-08 map and O2 sensors are disabled.......I believe Dusty has had good luck with the Akra map with 02 sensors enabled so that will probably be my next move since I am a novice with programming.
Old 04-28-2011, 04:58 PM   #666
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,835
I installed the '07-08' akra map yesterday...O2's disabled...I'm running a 2into1 & adv aux tank....big trip this weekend will give me a good idea of how the mileage is affected. My first experience with this map and dual wings gave me dismal mpg's (30-35). I will say throttle response is smoother........
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 04-28-2011, 05:59 PM   #667
chewbacca2264
Oddometer: 84
This is what I am worried about, stock map was around 46mpg with the 17t front, dropped to 40-42 when I went to the 16t front. I can live with the 40 range but do not want to see 30-35.....gas is way to expensive right now to drop that low considering that I plan to use the bike A LOT MORE this summer as a dd. Of course hate the stock map for rideability as the hunting and jerkiness of the throttle is very annoying. Really need to get a quality tune built for the 07-08 models that has better driveabiliy that the stock map, with better mileage than the akra map. Problem is that will mean large scale modifications and I for one am not comfortable with that as my experience with tuning is nil.
Tim
Old 04-28-2011, 07:04 PM   #668
Sapling
Sapling's Avatar
Oddometer: 413
Tim
I have an 08 Akra map Ti Q4's with the O2's disabled and I'm lucky to get 28MPG!!!!
How in the heck were you getting 40+++++
2008 990 ADV AK map Ti Q4 pipes
Woods setup Yz 450F
http://www.youtube.com/user/saplingthrasher
Sapling screwed with this post 05-11-2011 at 10:00 PM
Sapling is offline   Reply With Quote
Old 04-28-2011, 07:28 PM   #669
shootis
shootis's Avatar
Oddometer: 114
Drivers help
Scroll down until you see the version of Windows you have, most likely 32 bit, 2.08.14.
Click that bad boy and that should bring up a open or save box. Save and then open and install.
http://www.ftdichip.com/Drivers/D2XX.htm
If that doesn't work PM me and I can email the drivers to you.
Hang in there, it's worth it!!!!!
shootis screwed with this post 04-28-2011 at 07:34 PM
shootis is offline   Reply With Quote
Old 04-28-2011, 11:57 PM   #670
Dusty
Dusty's Avatar
Oddometer: 1,269
Question Question
for the those in the know... How do the to maps work together
Which map does the bike run on if just cruising along using very little throttle at say, 4000 rpm. Is this the F1 and F2 map as we see it in the software. Then does it switch to the L1 & L2 map when the throttle is whacked open?
When the o2's are disabled does the bike run on just the F1 & F2 map only?
Also the F Trim table in the software... I see that this adjusts the F1 & F2 fuel tales a percentage.
So if a person wanted to add a bit of fuel to the base map would they do it on the F Trim table so the base map values are left to the original numbers and could easily see what changes that were made on the F Trim table?
Or just make the changes to the F maps?
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 04-29-2011 at 01:15 AM
Dusty is offline   Reply With Quote
Old 04-29-2011, 12:02 AM   #671
ÖÖ.
Ajaa kuin mummo
ÖÖ.'s Avatar
Oddometer: 280
So far I have had good luck with two bikes but now came the first problem. We tried to read map from my friends bike and got this message:
Any suggestions?
Pics and vids
ÖÖ. is offline   Reply With Quote
Old 04-29-2011, 01:19 AM   #672
Dusty
Dusty's Avatar
Oddometer: 1,269
What bike?
Has it been remaped with another software.
The volts on the bikes battery look low as do the batteries on your laptop, is what is see from the screenshot.
I always have both hooked up to external power.
You always want to open Tune ECU with a map open also.
Dusty screwed with this post 04-29-2011 at 01:42 AM
Old 04-29-2011, 01:57 AM   #673
ÖÖ.
Ajaa kuin mummo
ÖÖ.'s Avatar
Oddometer: 280
Bike is 2007 990A and dealer has put some sort of ackra map to it last year.
Actually that icon tels that laptop is connected to charger. And yes I agree that bike should also be connected to external power.
Why should you open a map file first? Works faster?
Pics and vids
Old 04-29-2011, 02:17 AM   #674
924sas
924sas's Avatar
Oddometer: 205
never had that problem, but same showed up last time...
did a reading on a friends bike (same as mine) and than wanted to do it on mine... but no luck: unknown map type
will try again
924sas is offline   Reply With Quote
Old 04-29-2011, 03:28 AM   #675
chewbacca2264
Oddometer: 84
How in the heck where you getting 40+++++
The 40 ratings were all on the stock map with stock exhaust....going to the Q4's on the stock map knocked mileage down to high 30's (though early in the season with more idle time to warm up). Worried the Akra tune is gonna be way low.......time will tell.
Times are GMT -7.   It's 03:51 AM.
