Old 05-10-2011, 05:03 PM   #751
teti
especie en extincion
teti's Avatar
Oddometer: 143
990R, LeoVine 2-1, map Akra, who is this?
a cylinder more rich q another?
Best regards
Uploaded with ImageShack.us
teti is offline   Reply With Quote
Old 05-10-2011, 05:11 PM   #752
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,407
It's important to note that the 990 cannot be tuned using a tail sniffer setup and the stock exhaust. The crossover in the mid-pipe will cause cylinder 1 (left side) to scavenge cylinder 2 (right side), and you will get a false reading of F1 rich and F2 lean. If you attempt to use TuneECU to tune your bike with the stock mid-pipe and a tail sniffer you will end up with the condition seen below...
Best regards
~ Ken
www.powercellperformance.com
PowerCell is online now   Reply With Quote
Old 05-10-2011, 05:34 PM   #753
teti
teti's Avatar
Oddometer: 143
I leave everything like this?
Old 05-10-2011, 07:34 PM   #754
RoundOz
Plenty of seasoning
Oddometer: 1,014
So Ken...
...What is the best answer - fitting secondary O2 sensors in each pipe?
Second best answer? Making slight mods to the stock map and seat of the pants testing? Pull out the mid pipe after testing each tune to check the pipe coloration. They used to call it a plug chop back in the day when you could get to sparkplugs easier.
2009 KTM Adventure
RoundOz screwed with this post 05-10-2011 at 08:21 PM Reason: clarify, like butter
RoundOz is offline   Reply With Quote
Old 05-10-2011, 09:06 PM   #755
af300e
Oddometer: 283
What is the pipe sniffer situation when the crossover is removed and a 2 into 1 collector with single muffler used?
Edit: the crossover remains with the 2-1 merge? Also, would having the wide band sensor before the crossover prevent having to swap the sensor from pipe to pipe? Or are the pipe dynamics so different that each cylinder has to be tuned separately?
af300e is offline   Reply With Quote
Old 05-11-2011, 09:13 AM   #756
Sapling
Sapling's Avatar
Oddometer: 413
Bingo!
2008 990 ADV AK map Ti Q4 pipes
Woods setup Yz 450F
http://www.youtube.com/user/saplingthrasher
Sapling is offline   Reply With Quote
Old 05-11-2011, 10:01 AM   #757
RoundOz
Plenty of seasoning
Oddometer: 1,014
So, a follow up...
Originally Posted by Sapling View Post
Bingo!
If this is the only good option, are there any tuning shops in the Denver/Cheyenne area that could check tuning using a datalogger, maybe have the expertise to get up to speed on TuneECE? Alternatively, any inmates out there within a few hundred miles with those capabilities. I could fit the ports required and purchase wideband Bosch sensors for $150-200 but cannot see the value in purchasing a datalogger and investing time in learning how to run it for a possible one time use - I can't imagine switching bikes for many years, or wanting to change my tune once I get it smooth and 40+ mpg
2009 KTM Adventure
Old 05-11-2011, 10:10 AM   #758
Spark01
V-Twin
Spark01's Avatar
Oddometer: 305
Originally Posted by Michhub View Post
So, a new Innovate LM-2 is on the way...I know motorcycle guys do use this kit...couple of questions.
1 - Will I be able to use the TuneECU cable to LM-2 and pull the data off OBD-II style or will I have to hard wire?
I did a test with the LM2 at a dealer.... and the obd2 function didn't work.
No communication so you need to hard wire.
'10 990SMT
Spark01 is offline   Reply With Quote
Old 05-11-2011, 11:04 AM   #759
catalina38
Contrarian
Oddometer: 1,643
Which maps have you tried? My R mapped bike is smooth and 40+ most of the time. I have the stock 2010 R map not the AKRA map
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 05-11-2011, 02:02 PM   #760
Suncruiser
and Adventurer
Suncruiser's Avatar
Oddometer: 233
Stock Map
Catalina38, do you run stock pipes or am ones?
I've got the same bike/year with FMF Q4's and Akra mapping and get around 30 mpg cruising at 80 mph. a little more at slower speeds but i got around 40 mpg with stock map. mechanic said it'll burn the valves with stock map and FMFs. what's your take?
Good to be out there riding.
Peru to San Francisco 2011/2012 http://allthoseroads.wordpress.com/
Oz 2010 http://helmutgottschalk.wordpress.com/
2010 Adventure 990 R
Suncruiser is offline   Reply With Quote
Old 05-11-2011, 02:13 PM   #761
RoundOz
Plenty of seasoning
Oddometer: 1,014
Been too busy...
...to get my butt organized to try anything else - that is a good point though I should try it - sounds like several people have put the R map on a standard adventure - my first worry was whether the ABS addition would cause it to brick the ECU, but I guess not...
I could give a crap for the extra horses, but the smoothness would be great!
2009 KTM Adventure
Old 05-11-2011, 02:26 PM   #762
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,407
I prefer to avoid disrupting the exhaust flow as much as possible, so I personally have not installed bungs. Removing the crossover is the option I use. With a 1.5" crossover I believe it's there to prevent a clogged cat converter from over heating...
~ Ken
Old 05-11-2011, 02:59 PM   #763
catalina38
Contrarian
Oddometer: 1,643
This bike is able to adjust for altitude so it runs clean and maintains the A/F ratio via the O2 sensors. I ride from -200' to +12000' and it never runs rich but maybe a marginally better flowing muffler will overwhelm the FI? Not likely.
If the ECU could not maintain the A/F ratio it would throw a fault code.
Also FMF states no remap required for their mufflers. I don't have a dyno with A/F ratios to post here but some one else may.
The couple of bikes that I ride with work great with this combo and I'm sure were not the only ones. I'm very comfortable being the test pilot on this one.
Warning this all IMHO, FWIW
KTM 990R 500EXC
Old 05-11-2011, 04:13 PM   #764
unkle_george
unkle_george's Avatar
Oddometer: 106
25k miles on stock map + FMF's w/ no valve problems. The throttle response is much cleaner with the Akra map and that's what I'm running now.
unkle_george is offline   Reply With Quote
Old 05-11-2011, 04:32 PM   #765
Suncruiser
and Adventurer
Suncruiser's Avatar
Oddometer: 233
Thumb
thanks guys.
Times are GMT -7.   It's 10:02 PM.
