05-11-2011, 05:50 PM
#766 |
Oddometer: 634
As mentioned earlier I installed the Akra map with the o2 sensor enabled. The bike seems to run a lot better with my 2 into 1 exhaust. Today I finally was able to fill her up with gas. With riding strictly street, which I'm taking it semi easy around town (with no riding over 65 MPH) I'm getting about 37 miles a gallon. Not the greatest, but honestly I'm happy because the bike seems to run a hell of a lot better with this Akra map installed. Unfortunately IMO the original stock map is just way to lean making the bike run real hot.
2011 Victory Cross Country 2006 Suzuki DR 650 CHRIS_D screwed with this post 05-12-2011 at 04:06 AM |
05-11-2011, 06:06 PM
#767 | |
Contrarian
Oddometer: 1,408
What year?
Born 10,000 years too late Scientific Wild Ass Guesser:hmmmm |
05-11-2011, 08:35 PM
#768 |
Plenty of seasoning
Oddometer: 707
Makes sense...
...but I am running a 2-1 (CJ's pipe with Remus Ti) Have only ridden it twice since installing it. First ride the transition range (3500-4000) seemed rougher than usual. Second ride I let it idle 15 min (although I was of the understanding the 15 min idle only works after an ECU reset or remapping, but thought "what the heck, can't hurt"). I had no complaints about the fueling on the second ride at all. Both rides I had more bottom end than with the cats, maybe more top end as well - all very subjective, especially when I hadn't ridden the bike at all for several months! No idea about economy yet as i havent refueled...
2009 KTM Adventure |
05-11-2011, 09:48 PM
#769 |
Oddometer: 308
Did my first whack at the Tuneecu tonight and here is what I see....
08 990 running TI Q4 FMF pipes. First thing I did was download and save my map.... Then I adjusted my thottle cables... KM601AK0704501 Akra map SaI on O2 off 2nd butterfly on EPC off All cold readings TPS 2% no throttle - 97% full throttle (this looks like it needs work....) .75v zero throttle-3.80v at full throttle I just spent 2 hours rereading this thread from the start... I'm tired... looks like I am adjusting my TPS... Voltage to look for cold?? .66??
2008 990 ADV AK map Ti Q4 pipes Woods setup Yz 450F Saplings Adventures http://www.youtube.com/user/saplingthrasher |
05-11-2011, 10:02 PM
#770 | |
Oddometer: 2,170
). Also went real lean with stock map, cams and exhaust. Only time I have ever got a fault code was with sensor unplugged. I ran FMF's on the stock map with no problems. The whole reason why I put a wide-band on my bike was back in 07 there were quite a few threads about Dealer said "you must put the Akra map in with mufflers". Typical dealer mis-information fed by KTM. ECU compensated for the muffler change. A/F ratios didn't change. The ECU will keep the A/F ratio corrected in closed loop with the Lambda sensors with elevation change. However, in open loop it doesn't correct as much and will get appr. .5:1 richer with every 4K elevation change at 100%TPS. Actually, I can't say every 4K cause I haven't been to 12K yet but coming this Summer. |
05-11-2011, 10:04 PM
#771 | |
Oddometer: 2,170
05-11-2011, 10:30 PM
#772 |
Oddometer: 1,022
Yep it will change when warmed up.
Mine will consistently drop .05 when fully warmed to fan cycles, from .65 to .60 so I've just left it there... FWIW The target is between .5 to .6, someone correct me if i am wrong.
Originally Posted by d0gWateR Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider! |
05-11-2011, 11:23 PM
#773 |
Rider of the Lost Empire
Oddometer: 183
You're not wrong.
R100GSPD - R100RS Motorsport - K100RS Motorsport - Ural Gear-Up - Vanagon Westfalia http://www.flickr.com/photos/38874353@N05/ |
05-12-2011, 06:18 AM
#774 | |
Contrarian
Oddometer: 1,408
I did a loop around California last summer and I gained a couple of mpg when I was in the Lassen/Tahoe/Mammoth area's compared to the coastal area's I had been riding a few days before FWIW
05-12-2011, 07:08 AM
#775 |
Oddometer: 308
Best process for this?? Since the bike needs to be stripped to correct it?? ![]() Warm it all the way up then pull it open and check as quick as possible? It seems logical that if it changes .5 lower when warm to just set it .5 high cold reinstall..... warm it up.... then recheck with fingers crossed...
05-12-2011, 08:32 AM
#776 |
Oddometer: 102
I took off the right tank and the right air box cover. I then drilled a hole to access the torx screw. Once I had it adjusted to where I thought it was good I did the 15 minute idle reset.
Before starting it I replaced the airbox side panel and taped over the hole. I then took it for a ride without the right tank on. It ran like crap! I had set it to about .53 and it didn't like it. I did this a few more times and it eneded up at .6 hot. It's happy now. I put a snap in plug from Lowes it the cover and sealed it place when done. |
05-13-2011, 02:25 PM
#777 |
Major Medical
Oddometer: 3,201
LM-2 is here and so I begin to get ready...confirmed, it will not read through the OBD-II interface.
Now to hard wire the inputs...I need TPS & RPM...easy enough, unit has 4 analog inputs. My questions today...what is the second TPS...one for each throttle body? ![]() As for RPM, would it be better to take the Tach signal or the Ignition coil? ![]() ![]() The LM-2 has a direct tach signal input signal. This input can be used to feed a signal from the negative lead of a coil, ECU, negative lead of an injector, or ignition box (i.e. MSD 6AL). This tach signal can be feed to the RPM + (Black/White) wire. The negative wire (Blue) can be connected to ground if a tach signal is not being registered. If you guys could care less about this I'll stop with the techie posts ![]()
Mike Reinheitsgebot '07 990ADV '08 530EXCR '04 XR650L Bonsai Elephant - "Life without a 990 is no life at all!" |
05-13-2011, 02:31 PM
#778 | |
Uses lotsa band-aids
Oddometer: 9,164
I like the techie posts.
Egotism anaesthetises the egotist's stupidity.
05-13-2011, 02:44 PM
#779 | |
Dans le doute...gaz!
Oddometer: 1,723
First TPS is primary and controls both TBs.
The race is long and, in the end, it's only with yourself...
05-13-2011, 05:04 PM
#780 |
Oddometer: 308
This may sound dumb but I have been messing with maps all afternoon and looking at Dusty's process of adding fuel to the stock map to get a happy mix of the stock to akra......
I have been running the FMF Q4's with the Akra map and have been getting super bad MPG. Last weekend out on the dirt roads my fuel light came on at 81 miles. It feels rich. The pipes are showing lots of black residue on the mufflers. On the road only the light is coming on at 117 miles. This is pretty bad! My YZ 450 gets better mileage ![]() I loaded the stock map with 02's on and set out today for a test run. The first thing I noticed was I didn't have the quick decel I was experiencing with the Akra. The overrun was almost like it was still getting a touch of fuel. The second thing I noticed was a hiccup at about 4700 when getting on the throttle (I believe this is a common issue) Third is now I am getting the popping from the SAI that I hear so much about that mine was not doing before.... (guess that is next on the list) Fouth It feels lean and has lost its grunt at the top say 6000 up. I came back and shut off the O2's went back out and the hesitation definetly went away. Then I came back and tried Dusty's concept of adding 1% to the box's he showed and loaded this. This seemed a touch better but it still doesn't have the pop on top. I ran out of time but I am going to load the -2% Akra and give her the seat of the pants test tomorrow... after the 15 min reset of course ![]() I took the Akra map and removed 2% over the F1 and F2 tables then compared them....... Could it be that simple?? I know its not perfect but... I am going to try it. Off to have a beer! ![]() Good times in the garage today.
