Old 05-30-2011, 09:49 AM   #826
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
Originally Posted by Dotbond View Post
What was your reason/aim for installing the Superduke cams?
I think that TahoeACR and Cyborg are the first with SD cams in their 990ADV, Flanny is successfully running SD cams in his 950ADV (with FCR-MX carbs). BillyD did a degree/measure of the 990 ADV cams prior to dropping in a set of 950 ADV cams. They are REALLY mellow. The SuperDuke cams have more lift, duration and I think a little more overlap in comparison to the early 990 ADV cams. If I recall correctly the SD cams are a smidge hotter than the 950 ADV cams. The SD cams are a direct drop in fit in both the 07-08 990 and the 03-06 950. I don't know if the 09+ 990 is different in the head/cam area or if they already have a different/hotter profile.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 05-30-2011, 11:53 AM   #827
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,026
With that said, has anyone thought about laying the 2010 Superduke tune onto a 990 ADV ECU? The reason I ask is there seem to be a few reports of SD tunes being glitch/hitch free. Perhaps a few table copies would be all that is needed? To be quite honest, I'm guessing on what all is involved!
nevermind screwed with this post 05-30-2011 at 12:00 PM
nevermind is offline   Reply With Quote
Old 05-30-2011, 01:19 PM   #828
spsduc
spsduc
spsduc's Avatar
Oddometer: 99
Hey Dotbond, your bike has the Superduke cams!! The 2010 990R you have has new heads & cams from the superduke as far as I understand. Correct me if I'm wrong?
spsduc is offline   Reply With Quote
Old 05-30-2011, 02:11 PM   #829
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
Very true!
You are right Sir. Same #numbers.
Cheers.
Old 05-30-2011, 02:54 PM   #830
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Ok, I feel llike an eedjit.
Read the pdf that comes with the software and thought that was the extent of the docs. Turns out, as often happens, that I wasn't even close.
There's an online user guide:
http://www.tomhamburg.net/TuneECU_En/index.html
That covers a lot of what I was missing....
Duh. Again.
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 05-30-2011, 11:55 PM   #831
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 771
Thanks for the replies everyone.
Hey SPSDUC you're from the same town as me, we should go for a ride sometime.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 05-31-2011, 12:03 AM   #832
spsduc
spsduc
spsduc's Avatar
Oddometer: 99
No way, I heard you're way too fast!!
Old 05-31-2011, 02:44 AM   #833
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 771
Yes, those rumours that i started are true. Now, back to the advertised program.
Interesting idea about trying the SD map? Maybe they are the same?? Or not?
2012 KTM 690 R
Old 05-31-2011, 05:42 AM   #834
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,026
Well, the PN for the heads and cams on the 2010 SM T and SM R are the same as the 990R and 990A. The cams are the same as the 2007 SD across the models mentioned. I don't see a fiche for the later SD models.
I did do a graphical map compare and one thing that stood out for me is the ignition advance settings - I1 and I2. There is a dip then a spike on the 990R stock map. It starts about 4.5% throttle, spikes at 8% and gradually tapers downward. That seems very inappropriate to me, but I'm not a FI mapping guru.
Any expert thoughts on this?
Edit: Are those suckers backing out advance to meet emission standards?
nevermind screwed with this post 05-31-2011 at 06:08 AM
Old 05-31-2011, 06:18 AM   #835
big-t
Oddometer: 487
07,bone stock except for the de-catted mufflers and changing the F-L switch to the numbers Spark01 posted.
It consistently gets 40-42 mpg,all the sensors seem to be reading correctly and runs well except a slightly erratic idle that appears to be originating from cyl 1.Map sensor is fluctuating on cyl 1 and is pretty steady on 2.Also notice the back of the valves on cyl 1 are much cleaner than cyl 2.
Just wondering if there are any "known" issues causing this??
big-t is offline   Reply With Quote
Old 05-31-2011, 09:30 AM   #836
Spark01
V-Twin
Spark01's Avatar
Oddometer: 305
Your wright.. strange
But you also got a spike at 35% TPS at 8500-9500rpm??
But i can tell you this, i rode my friends stock '10 Adv A(with 990R mapping) past weekend and the power output on the ADv is smoother than on my SMT.
Ok mine SMT has akra's and akra mapping but that should not make that big difference??.. or does it.
'10 990SMT
Spark01 screwed with this post 05-31-2011 at 09:46 AM
Spark01 is offline   Reply With Quote
Old 05-31-2011, 09:55 AM   #837
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,026
Yep, saw that too, but it doesn't fall into the throttle position range that's bugging me...
We have a first! A 990 fueling is smoother than another bike!
Old 05-31-2011, 12:00 PM   #838
Spark01
V-Twin
Spark01's Avatar
Oddometer: 305
Oh but i don't want to trade, i like it a bit agressive when i flip the throttle
But what i mean is that i don't know if this power output is useful offroad.
Only thing i want to improve is the mpg and eliminate the last bit of jerky on low rpm's.
95% of the time it runs ok, between 2500-4500rpm during slow traffic but sometimes it doesn't?.
'10 990SMT
Old 05-31-2011, 12:05 PM   #839
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,026
Yes, that would be the very nice to achieve!
We may speak different languages, but motorcyclists around the world can understand each other just fine!
Old 05-31-2011, 12:50 PM   #840
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
You could call it a bad personality trait. I just can't leave engines alone. Wanted more hp. $300 for the cams and 8 WHP. I think the stock Adventure(at least the older ones) has a boring powerband. Needed something to make it more fun to ride on the street. The cams have a nice hit at 6,500rpm. And lets all face it. At 4 or 5k in the dirt your having a hard time getting it to hook up so why not build a bunch more hp at 7k so your friends can't even get close or get roosted by small trees. In 08 the only difference between a SD and Adventure was the cams, exhaust and ECU map. Pretty easy to get SD power out of an Adv.
08 SD had the water passages in the heads cast smaller to slow the coolant down.
SDR has bigger intake valves and a factory ported head.
Also some mention about SD maps. Don't know how they look now but some years back when I put the SD cams in the SD ignition maps had 6-8 degrees less advance than the Adventure.
tahoeacr is offline   Reply With Quote
Times are GMT -7.   It's 06:31 PM.
