09-13-2011, 12:20 PM
#1201 | |
Oddometer: 52
I think that the Power Tripp's job will be perfectly for our 08', even if we must add some adjustment... |
09-13-2011, 05:35 PM
#1202 |
Mike
Oddometer: 458
Good luck, I hope you get it sorted to your liking. Once you have a cable, it cost nothing to experiment. Changing maps is very quick and easy.
09-13-2011, 06:57 PM
#1203 |
Oddometer: 2,169
Copy and paste my friend. Then when done use the compare tool to make sure everything copied over.
09-14-2011, 05:46 AM
#1204 |
Miguez Rally Racing
Oddometer: 477
Hey tahoeacr, sorry but I'm a n00b at this. I thought the maps were incompatible because of changes to the actual motor between say a 2008 and a 2010 bike, but from what you're saying, I'm getting that the ECU maps are not compatible, but that I could copy over the values from a 2010 map using TuneECU's copy/paste fetaure (thanks Tom and Alain, great addition!), paste it onto my base 2008 map, and get pretty much the same benefits?
"Man's reach exceeds his grasp, and man's grasp exceeds his nerve" My 2012 Vegas 2 Reno adventure (on a 990 Adventure) starts here! |
09-14-2011, 07:42 AM
#1205 |
Unbunch yer panties!
Oddometer: 1,106
I don't know the specific answer to your question, I''m sure Tahoe will be by shortly.
But I wanted to let you know that if you're gonna try this, you should go straight to the 2011 map and not bother with the 2010. It's much, much better than the 2010, at least on my bike. Better still for me is the Power-tripp akra map, but if I was gonna try this I'd probably go with one of the stock maps the first time just for peace of mind. You'll need to copy and paste ALL maps, not just the fuel maps, to get a decent result. Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
09-14-2011, 04:17 PM
#1206 |
ADVreader
Oddometer: 121
Any news on compatibly for android phones, this will be great and BIG Thanks for the guys from http://www.tuneecu.com for the great work.
![]() Waiting for Power Tripp 2007 std file. Alain is possible to change the temp for start the fan, this will be nice to lower the temp by 20 or more degrades. far screwed with this post 09-14-2011 at 05:20 PM |
09-14-2011, 06:37 PM
#1207 |
Oddometer: 122
For the 07-08 bikes:
I think gefr's post at the top of pg 80 holds some hope. As soon as I get my hands on my cable, I'm going to see waht map I have, find which of the 2 maps we have available to us work best on my bike and try the "never close below 10% secondaries" and see what happens. On a separate note, does the disable SAS option on tuneecu work without removing the SAS itself? I'm not averse to removing it as I've done it to my 950, just wondering if the ecu mapping saves me the garage time.
Mark 08 WR250R 08 690 E 06 640 ADV |
09-15-2011, 12:30 AM
#1208 |
Life is a trip
Oddometer: 3,108
My setup
Sorry bouboule, I missed your post. My setup is completely stock european bike 990Adv with NonOvalShape Wings, smaller baffles in. When off throttle it is not exactly smooth but doesn't give you heart attack, as before. Really manageable. Maybe I should try minimum secondaries to 14% as suggested here somewhere. Downside is engine bracking is compromised.
Cheers.
There is always a reason!! gefr screwed with this post 09-15-2011 at 01:01 AM |
09-15-2011, 01:13 AM
#1209 | |
Oddometer: 2,136
Since the primary butterflies close all the way like in the carbed bikes, why do the secondary ones compromise engine braking? Unless the primary ones do not close all the way, I wouldn't expect the secondaries to have any implication on engine braking. If I am right, maybe the issue of reduced engine braking has to do with some sort of added fuel that goes implicitly together with the movement of the secondaries? Am I talking crap? |
09-15-2011, 01:32 AM
#1210 | ||
V-Twin
Oddometer: 260
You can change this switch with a lower temp switch . http://www.advmachines.com/category_s/93.htm Quote:
This means 2 things: you have more power instantly, but it can also be the case that the power rushes in to fast and this feels jerky. That is why the people increased the opening at small throttle operations(more smooth). But about the engine braking: I do think that opening the 2nd more and adding more fuel is less engine braking Because air can easier enter the engine so the fuel can easier burn = more energy thus less brake. So if you don't want to decrease the engine brake(to much), then people need or a dyno or datalogger to see what the airfuel ratio is off throttle. And then take the correct actions.
'10 990SMT Spark01 screwed with this post 09-15-2011 at 01:58 AM |
09-15-2011, 02:39 AM
#1211 | |
ADVreader
Oddometer: 121
09-15-2011, 06:33 AM
#1212 | |
Mike
Oddometer: 458
09-15-2011, 08:52 AM
#1213 | |
Oddometer: 2,136
In that case why do the secondaries have any effect? |
09-15-2011, 12:25 PM
#1214 |
Oddometer: 52
I don't know what the engine break when you cut trottle and put on.. I've search about fueling with more of 14.7 or less of 14,7 so poor or richer than stoichoimetric...no result..
I've try to copy the 10 ADV' transition a little better but really I found it's better when you have so more charge on the bike. Example your friend, you, bagage, bag..! Maybe it'll better when more ignition... I've actually a little second butterfly open at low trottle, it's better than 10 or 15%. that's my opinion... So after many reflexion, KTM have try to immitated a depression card with EFI system. The function are the same but so more reactive!! I haven't all the necessary like dyno or other knock diag tool to adjust really the map. I've only a wideband... But I think that it's possible to have a perfect smoother on/off and cut trottle!! So just one more question: why 2 different ignition tab?! On 950 diagram are the same not?even if carbs have different screw... I don't understand that... It's maybe a way! Thank friends!!! |
09-16-2011, 06:24 AM
#1215 | |
Mike
Oddometer: 458
