Old 09-30-2011, 08:30 PM   #1246
mgib
Oddometer: 124
Hmmm. I may have to try that on my 08, the opened secondaries, and see what happens.
That could be fun if it works.
Mark
500 EXC
500 XC-W
F800GS
mgib is offline   Reply With Quote
Old 10-01-2011, 08:35 AM   #1247
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
It's not a huge difference, but hey, if you're there....
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 10-01-2011, 10:28 AM   #1248
bouboule
Oddometer: 52
I've check my TPS and in cold i'd 0,66. I modify it to have 0,64. With engine warm I've 0,58-0,59.
But no diference on road ! I've impatient to try the futur Powertrip file for our 08' ! All said that the file for 09-11' is perfectly !!
Thanks Powertrip for your help !!
bouboule is offline   Reply With Quote
Old 10-01-2011, 11:06 AM   #1249
Alleycatdad
Oddometer: 1,439
...and don't forget to try the powertirpp maps once you;ve got the process figured out.
Steve
Old 10-03-2011, 01:41 AM   #1250
Autostream
Autostream's Avatar
Oddometer: 5,833
Variation in MAP sensors
Started playing with my new cable and Tune ecu in the weekend and made an observation I would like to see if it is normal.
The barometric sensor and two MAp sensors are the same part, but at rest when all three are at the same atmospheric pressure I got what I considered quite a big difference ion output.
At rest, cold, readings were.
Barometric sensor = 1006
Cylinder one = 1020
Cylinder two = 1012
No change hot.
Idling the lowest one is lowest, but by closer to 25 hpa
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 10-03-2011, 10:03 AM   #1251
mgib
Oddometer: 124
Sorry, clueless about the MAP variation, but I'm interested in the responses.
And def waiting on powertrip's modded 08 map...
Mark
500 EXC
500 XC-W
F800GS
Old 10-03-2011, 10:11 AM   #1252
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,798
Originally Posted by Alleycatdad View Post
Better yet, open the map, go to the second throttle map, open the 2nd throttle at high rpms and large throttle openings (where it closes back down in the uppper right of the map), and et viola! R map.
Then download that puppy.
Steve
I thought of that but decided to start with the stock version - just to see the difference.
Steve
This one is next maybe this week if I can get some free time
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 10-03-2011, 11:46 AM   #1253
sabink
Oddometer: 117
Powertrip, when we do the 15 min idle initialization do we have to enable Lambda sensors?
sabink is offline   Reply With Quote
Old 10-03-2011, 08:22 PM   #1254
DaveA
DirtTrail Dave
Oddometer: 34
Anyone used M-Tech for dyno test adn ECU remap?
Has anyone used M-Tech in Bend Oregon for Dyno testing and ECU remapping on your 990? What was you experience?
http://www.mtechmotorcycles.com/euro-moto.html
Dave
2008 KTM Adventure 990
DaveA is offline   Reply With Quote
Old 10-03-2011, 11:44 PM   #1255
sabink
Oddometer: 117
I'm asking because I'm getting very strange behavior from 2011 akrapovic map (KM601EU1180231). I have disabled the L maps by putting zeroes in the f-L switch and also disabled Lambda sensors. I fix the idle to about 14 AFR using F maps, but after a cold start the bike for about 10-30 seconds begun leaning the rear cylinder when idling until it shuts it off by jumping to AFR 19 Any ideas?
Old 10-06-2011, 05:10 PM   #1256
Kenbike
Oddometer: 698
I picked up my bike from Wayne @ Power Tripp last night. He installed a set of super duke cams and tuned the ECU. Got in a short test ride last night and it was a real improvement. It had much more snap and pulled much better. It picked up around 12 hp with everything. The real kick is I have the bike in Deals gap and have lost the KEY! I will have to wait until Monday when I get home to test ride. MY map is for a 2007 with Motor Hooligan air box, 2 into 1, and super duke cams.
Wayne felt the 2into 1 really limits my top end.
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Old 10-06-2011, 05:51 PM   #1257
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,216
I have the Superduke cams on my '07 Adv 990S and really like the better powerband they gave. I also have the Neduro Adventure tank and the 2-into-1 they were selling with it at the time, feeding into one FMF Q4. I have wondered whether a better 2-into-1 system could bring the bike back to 2-into-2 revability, but haven't done any research there. Probably needs a larger bore 2-into-1 adapter, and bigger can.
I really like the Adventure tank (2.2gal) and would not give that up for a few extra ponies.
cyborg is offline   Reply With Quote
Old 10-06-2011, 06:48 PM   #1258
Unkgd
Oddometer: 345
Which 2 into 1 exhaust pipe?
Sounds like the trip to Wayne was worthwhile - just wish he was closer to the west coast :-(
Did you get a copy of the before and after dyno plots? What I am curious about is how much the SuperDuke cams moved the torque curve up the rpm band.
SNIP.. Wayne felt the 2into 1 really limits my top end.
So which 2 into 1 do you have - the current ADVtank style or the Neduro/Cjdesigns style?
Unkgd screwed with this post 10-06-2011 at 06:51 PM Reason: Typos
Unkgd is offline   Reply With Quote
Old 10-07-2011, 09:22 AM   #1259
Tarzan
King of the Jungle
Tarzan's Avatar
Oddometer: 31
BP sensor readings
Relating back to Autostream's comments on the sensors, I noticed a discrepancy on mine as well. My BP was the same as one of the cylinder's, the other was off by around 12. To try a quick fix I swapped the BP with the errant cylinder to try and equalize them.
After doing this the two cylinder readings (key on) were closer by about half (6 units), but still weren't the same. I'm not sure why they didn't equalize, unless there is a wiring/resistance effect? I had previously done a synchronization with carb stix, can't remember for sure but I thought the difference with engine running was similar. Probably not a big problem but annoying.
Tarzan is offline   Reply With Quote
Old 10-07-2011, 10:27 AM   #1260
bouboule
Oddometer: 52
Powertripp, you've said that you tune maybe an ADV this month but with stock cams?
There is somthing that I don't undestand. If you mount SD cams, you configuration are the same than 09'-11' ADV. Not? So you can use after this modification, Powetripp maps which are share on Tuneecu website..
What do you think about this?
Thanks !!
Times are GMT -7.   It's 08:28 PM.
