Old 11-15-2011, 02:50 PM   #1321
catalina38
Contrarian
Oddometer: 1,645
Anyone have the 2011 US "R" map they can send me or post to TuneECU? I keep getting an error message that the EU map is unsupported by my ECU when trying to install it in my US bike. I guess I should be asking is there such a thing as a 2011 "R" map or is the 09/10 map still being used?
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 screwed with this post 11-15-2011 at 03:44 PM
catalina38 is offline   Reply With Quote
Old 11-15-2011, 06:03 PM   #1322
jruh
Oddometer: 63
I've been looking for the same thing but haven't had any luck. What I did was copied all of the maps from the 2011 EU "R" map (KM601EU1102002Map.hex) and pasted them into the "all years" US R map (KM601US0902002Map.hex) then saved it as a new file. I haven't had a chance to try load it yet so can't guarantee it will work. I can send it to you if you like to try it.
John
jruh is offline   Reply With Quote
Old 11-15-2011, 06:31 PM   #1323
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
John
Did you use the compare feature afterwards? It will show you if all the maps swapped over. Took me three tries to get all of the maps switched over.
tahoeacr is offline   Reply With Quote
Old 11-15-2011, 06:49 PM   #1324
jruh
Oddometer: 63
I did compare and verify that all the maps of the finished product were the same as the EU file I copied from. It was a little tedious to keep opening one file then the other to copy and paste maps (unless there is an easier way that i didn't figure out).
When I compared the EU and US maps beforehand they were actually not very different in the first place but I copied them all over anyways.
Cheers, John
Old 11-15-2011, 06:53 PM   #1325
catalina38
Contrarian
Oddometer: 1,645
John
pm sent
KTM 990R 500EXC
Old 11-16-2011, 02:34 PM   #1326
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
11-15-2011 TuneECU 2.0 now Released
Note:
*Support PC-V maps
*Portuguese language
*possibility to disable the ISC on KTM 990/1190
BR, Tom
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 11-16-2011, 03:06 PM   #1327
teti
especie en extincion
teti's Avatar
Oddometer: 143
Note:
*Support PC-V maps
BR, Tom
that is ISC acronym?
que es ISC sigla ?
gracias por la labor
teti is offline   Reply With Quote
Old 11-16-2011, 03:56 PM   #1328
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
que es ISC sigla ?
Idle Speed Control
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 11-16-2011, 04:32 PM   #1329
jruh
Oddometer: 63
Can someone explain why I would want to disable my Idle Speed Control?
Thanks, John
Old 11-16-2011, 04:32 PM   #1330
teti
teti's Avatar
Oddometer: 143
Originally Posted by bikyto View Post
Idle Speed Control
ok ISC, pero que funcion cumple aparte del menu de la foto?
ok ISC, but that function meets in addition to the menu of the photo?
tankyou, gracias
Old 11-17-2011, 04:14 AM   #1331
Tom-Hamburg
Oddometer: 84
Hi teti,
BR, Tom
TuneECU
Old 11-17-2011, 06:33 AM   #1332
catalina38
Contrarian
Oddometer: 1,645
How about a check box to turn off the "immobilizer" on the 2009 and newer bikes?
KTM 990R 500EXC
Old 11-17-2011, 07:14 AM   #1333
mato409
Oddometer: 45
Hello
I have now disassembled the bike, tanks, exhaust, and lambda 02, I was changing the spark plugs and pulling out the SAS, I can connect the bike to tuneecu, only to disable the SAS? with the bike in this state?
thanks
mato409 is offline   Reply With Quote
Old 11-19-2011, 12:13 PM   #1334
Corni
Corni's Avatar
Oddometer: 84
I wish not and I think I'm not alone. This would be one of the features that 1 would be happy and 99 from hundred wouldn't.. Thinking how much this would serve bg's I'd suggest if you'd like to have your bike w/o immobilizer, buy early ecu or bike.
Corni is offline   Reply With Quote
Old 11-19-2011, 02:06 PM   #1335
spsduc
spsduc
spsduc's Avatar
Oddometer: 99
Yes please. I'm paranoid mine's going to fail in the middle of nowhere!!
spsduc is offline   Reply With Quote
Times are GMT -7.   It's 11:14 PM.
