Old 03-21-2011, 06:39 AM   #16
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,360
a good spot to find info/ask questions
www.yamahaenduro.com
JeffS77 is offline   Reply With Quote
Old 05-15-2011, 08:38 AM   #17
crawler07 OP
Oddometer: 60
thanks for the help Jeff..
Since last post I have rode this bike a ew times and the piston slap was driving me crazy so I decided to remove the top end and replace the piston,but I also decided it needed new crank seals so I decided to remove the engine from the frame.Well I thought if I have the engine out I may as well paint the frame and body panels so thats where im at
and heres the pics..
I have painted the frame, but didnt take a pic yet, but I will so stay tuned!
crawler07 is offline   Reply With Quote
Old 05-15-2011, 08:19 PM   #18
crawler07 OP
Oddometer: 60
and painted!\
Old 05-18-2011, 09:13 AM   #19
crawler07 OP
Oddometer: 60
Well the tank on this bike was a little rusty inside and it had alot of pin holes..The only thing I could come up with for a fix was to cut the bottom of the tank away and repair the tunnel..
decided to do it in 5 sections
and the first
then I flatened out the piece I removed
then made a new one
bent it up and fitted it
welded in
on to the next cut
cut replacement
and then ran out of time
Old 05-19-2011, 11:36 AM   #20
crawler07 OP
Oddometer: 60
Ok I finished the tunnel and checked the welds for any holes by turning off the light and placed a light in the tunnel and checked for light to come through from the other side.
then started to joined the to pieces to make a tank again!
and the hole thats still left to fill
Old 05-23-2011, 07:27 AM   #21
crawler07 OP
Oddometer: 60
worked on the frame a bit
Old 05-23-2011, 01:07 PM   #22
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Looking like it is coming along great!
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 05-23-2011, 05:19 PM   #23
crawler07 OP
Oddometer: 60
Thank you Sir, I have just installed the rear wheel with a new sprocket. I dropped it a tooth due to it being geared a little low for me..
I ordered some fork gaiters from a ttr125, I think they will work well.
also ordered a front sprocket a gold non o-ring chain and some mesh to make a headlight guard from..And I only have a few more parts to strip in the sandblaster and then paint. And last but not least will be painting the motor (can someone suggest a paint in a spraycan for the motor??) and bore the cylinder...Im also looking for a working speedo and a tach if any one has any please PM me,,thanks
Old 05-26-2011, 11:17 AM   #24
crawler07 OP
Oddometer: 60
do you guys have any idea if their is a taper neck bearing available for these bikes??
Old 05-26-2011, 01:44 PM   #25
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
I know this is a tad late, But I asked a local 1 DAY Paint and body how much they would charge for painting a motorcycle frame gloss black with flex agent in it to allow it to be more durable, if I prepped it and they told me $40.00. I will never paint another motorcycle frame as long as I live! Shoot, the automotive paint I would use costs 80 bucks!
Old 05-26-2011, 01:45 PM   #26
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
I think you can get them at a bearing specialist if you have the dimensions of the stockers. OD ID thickness.
Old 06-07-2011, 11:59 AM   #27
crawler07 OP
Oddometer: 60
Wow, that is one hell of a deal.Unfortunately all the paint shop in my area are out of their mind asking 250.00!!
I think my auto zone duplicolor will hold up just fine
Thanks I found some on ebay for around 50.00. I will look into gettin some if I ever decide to take it apart again..
My next big find looks like it will be a upper con rod bearing......Doesnt seem to be any out their???If anyone knows where one is please let me know......
Old 06-07-2011, 08:32 PM   #28
SOS
Ignorance is a gift
SOS's Avatar
Oddometer: 721
Very cool! I'm takin notes on the tank repair
www.motorcyclesolutionsllc.com
SOS is offline   Reply With Quote
Old 07-08-2011, 02:40 PM   #29
crawler07 OP
Oddometer: 60
havent made alot of progress,it seems the little thing consume large amounts of time.
installed some fork boots from a ttr125 and started on a headlight mount with a little twist.
This bike didnt come with a speedo or tach the previous owner said he lost them so I had to come up with something to hold the key switch..
the bolt holding the light bucket to the mount will be replaced by a wing nut and the light will be a quick release..
also going to make this chain guide work, just think it looks cool
added some renthal twin tube bars and clamps.and made the turn signals work by switching the stems from side to side and making a few spacers.
and an over all pic..
Old 07-22-2011, 12:01 PM   #30
crawler07 OP
Oddometer: 60
I cleaned the center cases and had a good friend do a little powdercoating and blamo!!!!
and the light mount is almost finished.
Just a small list remaining.
paint the exhaust
install a bicycle speedo
install chain
build a seat pan ,cut some foam, and cover it
make a tail light mount
paint body work
fix blinkers.......
Times are GMT -7.   It's 05:50 AM.
