Old 07-26-2011, 06:52 AM   #346
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 3,171
Searching is impossible so please excuse me if this has been answered. How does Schuberth recommend we clean the Pinlock Lens?
Cheers,
Dan
DRTBYK is offline   Reply With Quote
Old 08-02-2011, 09:28 AM   #347
BoochZilla OP
Metal.Moto.Mania.
BoochZilla's Avatar
Oddometer: 761
Waiting from the formal response from Schuberth, but in our experience a damp cloth can get it done, but be sure to take extra care around the silicone bead that runs the perimeter. If you mess the bead up you could be SOL. :-)
Anthony
RevZilla.com - REV'IT! & ADV Gear Thread
'10 Multistrada 1200
'07 R1200GS
'05 Monster S2R
BoochZilla is offline   Reply With Quote
Old 08-02-2011, 11:40 AM   #348
ttpete
Rectum Non Bustibus
Oddometer: 3,514
I take the pinlock out of the visor and clean them separately, then wearing white cotton gloves, I reinstall the pinlock. Gloves are to prevent fingerprints.
09 Kaw Versys
"The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher
ttpete is online now   Reply With Quote
Old 08-11-2011, 05:38 PM   #349
DRTBYK
DRTBYK's Avatar
Oddometer: 3,171
I did finally learn how to remove the Air Scoop for cleaning - thanks to Aaron @ South Sound Motorcycles.
Boy did it need that!
I do have one other question. I purchased a C3W for my wife and we noticed that the Chin Strap "tung's" that overlap under your chin, don't have velcro on them like my C3 does. Is this common to all C3W's?
Cheers,
Cheers,
Dan
Old 08-11-2011, 08:19 PM   #350
Tn. Walrus
Knuckle Dragger
Tn. Walrus's Avatar
Oddometer: 303
My C3 doesn't have any velcro either. I think they changed the design.
Forever West ....Murphy says NO!
Salus Populi Est Suprema Lex.
IBA# 49285
Tn. Walrus is offline   Reply With Quote
Old 08-12-2011, 06:53 AM   #351
niceviewbehindbars
out enjoying the vu
niceviewbehindbars's Avatar
Oddometer: 1,368
Inquiring minds want to know....
Graham
06 BMW R1200GS
"The human spirit needs places where nature has not been rearranged by the hand of man." -Unknown
niceviewbehindbars is offline   Reply With Quote
Old 08-12-2011, 07:54 AM   #352
DRTBYK
DRTBYK's Avatar
Oddometer: 3,171
You do this at your own risk!
Ok, you've been warned. . .
The warning is because you can easily brake the part of the scoop base (black plastic) that is welded to the Helmet. You brake the base you either "glue" the Scoop back on OR buy a new helmet!
Here goes:
  1. Move the Air Vent Closure Slider to the Middle possion.
  2. Now with your finger nail "pop" it off by lifting upward from the back.
  3. This Slidder is now you "tool" for removing the Scoop.
  4. Using the thin end of the Slider gently pry under the Scoop from the back and then pry "up". This will release the Scoop at the rear. DO NOT LIFT UP ANY FURTHER!!!
  5. Now slide the Scoop FORWARD to release it from the grooves at the front of the base. These grooves are fragile!!!
  6. If you made it that far you now have the Scoop in your hand. Grungy - right?!
To install, reverse the above process. If you moved the Slider Closing part of the base make sure it is in the Middle position before replacing the Scoop - by sliding the Scoop into the front grooves and then "snapping" it in place at the rear. Replace the Slider and your done.
Be careful out there. . .
Cheers,
Cheers,
Dan
Old 08-12-2011, 01:03 PM   #353
TallRob
TallRob's Avatar
Oddometer: 1,393
why not just use Q-tips?
TallRob is offline   Reply With Quote
Old 08-12-2011, 02:11 PM   #354
DRTBYK
DRTBYK's Avatar
Oddometer: 3,171
You can't quite get to all of the little critters that get sucked into and past the "grill". I used compressed air to blow out most of the bug's (from the inside out) but eventually you need to clean "inside" the scoop. Only way is to remove it. It was made to be removed - just gently.
Cheers,
Cheers,
Dan
Old 08-12-2011, 02:28 PM   #355
Mifune
Mifune's Avatar
Oddometer: 407
I've owned a Schuberth S1 and J1, both of which I was very happy with except for one thing. The anti-fog coating on the inside of the visor quickly turned milky white when exposed to the least bit of rainwater. Anyone else experience this or has the problem perhaps been solved? My experience is about 3 years old, so maybe it's been addressed.
Mifune is offline   Reply With Quote
Old 11-10-2011, 01:03 PM   #356
mikegc
mikegc's Avatar
Oddometer: 1,001
Schuberth Helmets for ADVRiders
I just purchased a C3 and got the SRC system as well. I have no interest in answering the phone and the obtrusive microphone boom needs to go. I know it isn't removable but has anyone cut it off?
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 11-10-2011, 01:14 PM   #357
niceviewbehindbars
out enjoying the vu
Oddometer: 1,368
Mike
The SRC system is removable. Pretty easy actually.
Graham
06 BMW R1200GS
Old 11-10-2011, 01:41 PM   #358
mikegc
mikegc's Avatar
Oddometer: 1,001
Yes, it's very easy to remove. I installed it in about 10 minutes so I can take it out. What I want to do is get rid of my Integratr IV and the cord and replace those functions with the SRC. I would like to listen to my iPod via Bluetooth and have to option to listen to the Garmin 665 when in an unfamiliar city in heavy traffic. The microphone boom is simply not needed and I find it an uncomfortable distraction.
Mike
IBA 25881
Old 11-10-2011, 02:52 PM   #359
DRTBYK
DRTBYK's Avatar
Oddometer: 3,171
Aside from the Intercom/Bike2Bike and the occasional phone call - while out on the road - I use the mic most often to "control" my iPod app on the iPhone. Hands free!
Cheers,
Cheers,
Dan
Old 11-13-2011, 09:22 PM   #360
dacrazyrn
ED RN Adventurer
Oddometer: 490
Send a message via AIM to dacrazyrn Send a message via MSN to dacrazyrn
Cheers,
DINGding (Siri answers)--Handsfree, texting, music, calling, you name it.
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me?
“When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama
Life is Risk Management
'09 BMW F800GS-Fate Honeyed GSabelle
dacrazyrn is offline   Reply With Quote
Times are GMT -7.   It's 10:04 AM.
