Old 11-02-2010, 07:53 PM   #1
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
DR650SE Index Topic #1- CONTROLS/INSTRUMENTATION
The topic for this thread is Controls & Instrumentation, and it covers a little ground. I'd like to hear what worked best for you DR650 fans out there. Or, if there's something to avoid. If you have part numbers and supplier info, please share that, too.
If the case has already been made about something in this catagory, please feel free to just put up a link to the relevant post(s). Please link to the posts, NOT THE ENTIRE THREAD, unless that thread is already limited to this topic . No need to limit your links to ADV, either.
OK, please share your success stories regarding:
- HANDLEBARS/RISERS
- FOOTPEGS/FOOTPEG LOWERING
- GRIPS/HEATED GRIPS
- THROTTLE TUBES
- LEVERS/PEDALS
- CABLES
- GAUGES/INSTRUMENTS
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... screwed with this post 12-03-2010 at 10:42 PM
Krusty ... is offline   Reply With Quote
Old 11-02-2010, 08:44 PM   #2
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,617
Nice one Krusty.
Originally Posted by Krusty ...
This is the first in a series of threads I'll be starting. They will each deal with a specific aspect of the '96-current Suzuki DR650SE. The purpose of these threads is to compile information for a listing in The Bike Specific Index Thread, which is stickied at the top of the Thumpers page.
- HANDLEBARS/RISERS
- THROTTLE TUBES
- LEVERS/PEDALS
- CABLES
OK. I'll get the ball rolling. Here is what I have and works.
- HANDLEBARS/RISERS - Procycle risers on Renthal Jimmy Button bend Bars
- FOOTPEGS/FOOTPEG LOWERING - Am happy with my knees around my ears
- GRIPS/HEATED GRIPS - When out temps never get below 26 degrees C in Northern Australia ?
- THROTTLE TUBES - Procycle quick throttle -love it for response with carby setup correctly.
- LEVERS/PEDALS - standard (haven't broken or bent yet) because I also have barkbusters (handguards)
- CABLES - Original so far because I look after them.
- GAUGES/INSTRUMENTS - Trailtech vapor - Awesome bit of gear. temp guage is very handy in hot climate (especially on the trail). Tacho handy to monitor engine speeds and gearing ratios, 12/24 hour time- saves wearing a watch, dual trip meters, great looks and adds a bit of class to the bike.
Without any of these, the DR is already a great bike. These improvements have been party function and partly personalisation of the bike.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 11-02-2010, 09:29 PM   #3
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Here's a link to the DR650 specific Vapor Kit: http://www.trailtech.net/75-302.html
and a write up from DisTech on how to install some of the components: http://www.advrider.com/forums/showp...&postcount=143
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV screwed with this post 11-02-2010 at 09:39 PM
EvanADV is offline   Reply With Quote
Old 11-03-2010, 05:03 AM   #4
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,822
i noticed the trailtech model shown uses a magnetic pickup on the front wheel. so mileage & speed accuracy is dependent on tire type/ size/ wear. is this correct?
plugeye is offline   Reply With Quote
Old 11-03-2010, 10:44 AM   #5
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
- HANDLEBARS/RISERS:
I like my Pro Taper CR High Bend. But handlebar and Riser height is purely the riders choice. Make sure your position/bar height works while standing ... IF you want comfort/control off road. Stock steel bars are good but can bend in a crash. Pro Taper bars (Alu) absorb vibration better than stock. Bar end weights not needed.
A WORD ON ERGONOMICS:
Many riders do not set up their bars and levers for max comfort. Poorly set lever can cause numbness and even Carpal Tunnel syndrome. It is important to adjust levers so that wrists do not bend much ... but stay straight and relatively flat. Most riders have their levers set UP too high. This puts a bend in your wrist, especially when standing up off road. Not good.
- FOOTPEGS/FOOTPEG LOWERING:
Wide pegs are nice off road when standing. I have used the IMS pegs but am using stock on the DR. NOTE: Early DR pegs are narrower than later ones.
No comments on lowering pegs.
I use Symtec heated Grips. About $35 at most vendors. They draw about 24 watts. Very nice!
- THROTTLE TUBES
I use Stock cables. Most know that the old throttle grip will NOT come off. Buy a new throttle tube if changing bars or doing Heated Grips. No other way.
- LEVERS/PEDALS
I always carry a spare set of Suzuki levers on my bike. I also use Bark Busters to help protect the levers, master cylinder and .... most important ... my hands! Without Bark Busters levers are easily broken ... even in a minor tip over.
Brake Pedal and Shifter protection:
I run a thin safety cable lanyard on my shifter and brake cable, from the lever tip to the frame. This is an old Enduro riders' trick. Easy to do, will save your shifter or rear brake lever from being torn off when riding off road. Cheap insurance, easy to rig up your self.
- CABLES
All stock. I only run Suzuki cables.
No comments here.
Old 11-03-2010, 10:52 AM   #6
thealien
Not From Around Here
thealien's Avatar
Oddometer: 444
from memory you enter the diametre to the tyre edge for each different wheel size, its all in the instructions anyway and you just recalibrate for when you use a different sized wheel. its easy.
DR 780Motard
SRV250
CT110
SCARABEO 50
thealien is offline   Reply With Quote
Old 11-03-2010, 06:11 PM   #7
toddiscdn
Take off, EH!
toddiscdn's Avatar
Oddometer: 1,020
- HANDLEBARS/RISERS
ProTaper Contour "Pastrana ATV", a high bend fat bar, with Protaper fat bar adaptors. I did have to slightly enlarge the stock rubber mounts to accommodate the large bolt on the protaper mounts. These bars came off my DRZ and have fallen over many, many time and are still in one piece.
I had made some lowering brackets out of alum. but the did bend over time. So I got a spare set of stock pegs, cut off the peg, milled down the mount and welded them back on getting about 1.5 inch drop and slightly rearward.
These now sport the cheap IMS knock off pegs alailable on ebay for about 15 bucks.
No heat yet. I now use Pro Grip 714 Dual Sport Grips and like them allot, but have used progrip pillow tops an like them as well
- THROTTLE TUBES
Just a motion pro replacement tube, as the stock grips are glued on with some sort of nuclear bomb proof glue and a new tube is easier than trying to get the old one off
- LEVERS/PEDALS
Stock
- CABLES
Stock
Trailtech Vapor here as well, love it. This also spent a couple years on my DRZ before being moved over to the DR and is still holing up well through drops, rain, mud, etc. and still tickin.
Cheers, Todd
"It's all about the beer"
drcool
08DR650 - Jack of all trades, master of none
toddiscdn screwed with this post 11-03-2010 at 08:45 PM
toddiscdn is offline   Reply With Quote
Old 11-03-2010, 08:43 PM   #8
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,050
i have one of these.
http://www.turbocity.com/product_inf...roducts_id=665
puts the light cluster to where i can see it.
i use protaper atv mid bars with stock cables.
much better when standing
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 11-04-2010, 01:59 AM   #9
Snowy
Oddometer: 1,818
- HANDLEBARS/RISERS .................Pro Taper Chad Reed bend oversize bar
- FOOTPEGS/FOOTPEG LOWERING...Lowered and moved rearwards
- GRIPS/HEATED GRIPS.................Pro Taper grips, very grippy
- THROTTLE TUBES......................Standard
- LEVERS/PEDALS.........................Cut and shut shortened to match rear movement of pegs
- CABLES....................................re routed to stop the hook ups behind the headlight
- GAUGES/INSTRUMENTS...............original speedo binned, Garmin GPS only
Barkbusters with the triple clamp mounting kit. You aren't trying hard enough until you crash and bend them, and the bars, and the levers.....
Snowy screwed with this post 11-06-2010 at 01:33 AM
Snowy is offline   Reply With Quote
Old 11-04-2010, 04:43 AM   #10
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,822
snowy,
the GPS doesnt need a magnetic or any pickup, correct?
no calibration either?
Old 11-04-2010, 02:01 PM   #11
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
snowy,
My 60CSx didn't require any of that.
Old 11-04-2010, 09:19 PM   #12
ER70S-2
ER70S-2's Avatar
Oddometer: 6,716
+1 GPS is correct out of the box. The satelites are about 11,000 miles up, and can see me creep forward at a stoplight. Pretty fookin' cool.
2004 DR650: 62,605 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 10-08-2011 at 01:19 PM
ER70S-2 is online now   Reply With Quote
Old 11-04-2010, 10:14 PM   #13
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,384
Revised position instruments you can actually see.
RMZ 450 clutch and master cylinder.
Protaper Contour bars in stock rise.
Garmin Zumo 550 with Starcom Advance bluetooth.
Heads up L E D voltage monitor (LED in the centre of the fairing)
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 11-04-2010, 10:17 PM   #14
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,050
snowy,
no it's not a bicycle wheel computer, but there is an elevation calibration technique.
i also use a 60csx w/ a ram mount & hard wire w/ touratech wiring kit.
Alaska
Old 11-05-2010, 08:48 AM   #15
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
I don't have one of these yet, but I think they're kinda cool, in an old-school way... An oil temperature gauge that replaces the oil cap. Image won't load, sorry.
http://www.getgeared.co.uk/MOTO-DETA...perature_Gauge
Krusty ... screwed with this post 11-05-2010 at 09:18 AM
Times are GMT -7.   It's 04:09 PM.
