Old 01-09-2011, 06:23 AM   #16
LCubanaso
Adventure Crasher
Oddometer: 68
Originally Posted by NordieBoy View Post
Brake snake?
Looking for something that prevents the impact to the lever, not that protects the lever from being ripped off or bent severely.
Thanks for the suggesting though.
LCubanaso is offline   Reply With Quote
Old 01-09-2011, 09:33 AM   #17
LukasM
Oddometer: 5,425
This is the only solution I know of, going to cost you about $600:
http://www.advrider.com/forums/showt...2#post14485732
Old 06-06-2011, 08:00 AM   #18
psdr rider
Broken Twice, 3x shy
psdr rider's Avatar
Oddometer: 6
Dr650 Pat Walsh Design Skid Plate
Just installed the PWD skid plate. It mounts to the frame boss's in rear and clamps up front. No clearance issues with clamps.
psdr rider is offline   Reply With Quote
Old 09-15-2011, 08:02 AM   #19
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,968
What is the best hand guard that is bolt-on without modification? Bark Busters, Acerbis, etc? I see Procycle sells a hand guard kit, but the deflectors are separate, so $100-ish for both. Is this kit any better, or easier to install than some of the others?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 10-10-2011, 11:40 PM   #20
southerndreamer
Oddometer: 4
fitting hand guards "bark busters" etc.
I'm about to fit some Zeta protectors to my bars but not sure about the throttle side which is solid with the thread down the centre to screw on the end weight. How does one get this out please.
southerndreamer is offline   Reply With Quote
Old 12-08-2011, 04:19 AM   #21
livin2day
Oddometer: 13
While the B&B plate seems to be the best (should be for $180!), what's the best US alternative?
The Utah Sports, Procycle, and Pat Walsh all seem to be about the same (4mm), but vary quite a bit in price. What makes the Pat Walsh worth the $120 vs the Procycle at $80? Is it a better, stronger mounting system?
livin2day is offline   Reply With Quote
Old 12-08-2011, 08:18 PM   #22
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,140
There's a better bash plate made in Oz but it does cost a bit more...
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 07-01-2013, 02:36 PM   #23
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,994
Skid plates:
http://patwalshdesigns.com/Suzuki-Dr...r650se/26.html
Probably one of the best available in the US. I have an out of production DG skid plate that is built very similar w/ coverage and is thick.
Most everyone sells a rebranded Utah/Ricochet Skid Plate
http://www.ricochetoffroad.com/store/page163.html
Motech makes one that covers well, but for some reason they add way too many holes in their design?
http://www.twistedthrottle.com/sw-mo...uki-dr650se-96
There is also a Suzuki one that does not have good coverage, plus an ultra beefy Rock Hard Rally Gear one.
Whipps, from Australia, makes a beefy one too. I say this one is the beefiest one available world-wide. They ship to the US but it's a bit more $$$ than others. http://whipps.com.au/motorcycle-accessories
Like DG, they use 4mm thick alum.
B&B, also OZ, makes one too. It's built beefy like Whipps but not sure about thickness nor how far back it goes.
http://bboffroad.com.au/shop/online-...uki-dr650.html
Flatland racing does not make one.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 07-01-2013 at 02:43 PM
eakins is online now   Reply With Quote
Old 07-06-2013, 10:16 PM   #24
KilgoreTrout
adventure flyfisher
Oddometer: 372
Thumb Bash Plates
+1 on the Whipps extremely beefy and mounts directly to the frame
96 DR 650,,87 XL600V,89 DR 750 Big,77 Montesa Cota 247,77 TY 250,76 TY175,76 TL 250,75 CT90
KilgoreTrout is offline   Reply With Quote
Old 07-09-2013, 05:19 PM   #25
thump!
thump!'s Avatar
Oddometer: 1,489
Skidplates - If I had not already bought a Ricochet plate I think I would spend the extra bucks for a Pat Walsh plate to avoid the possibility of the rear clamps rotating into the crankcases as.reported by some. But, since I already have the Ricochet and an OEM plate that is now just scrap aluminum, I decided to combine the two. I cut off the rear section of the OEM plate and TIG welded it to the Ricochet. This way I can use the rear mount points on the frame rather than the C clamps.
thump! is offline   Reply With Quote
Old 08-29-2013, 11:54 PM   #26
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,994
Aftermarket alum. oil cooler guard
http://www.jnsengineering.com/produc...-cooler-guard/
http://www.advrider.com/forums/showthread.php?t=908838
Alaska
Times are GMT -7.   It's 10:30 PM.
