Old 11-02-2010, 11:14 PM   #1
The Jinx OP
I'm an angel... :p
The Jinx's Avatar
Oddometer: 242
Tubeless spoke wheels for F800GS
Hi
Is there any inmates using tubeless spoke wheels on F800GS?
What make is the wheels?
Any significant advantage tube vs tubeless vice versa?
Do U have pics of it?
Thanks & regards
sbw
MY wish came true.....
'10 R 1200 Gelände/Straße
My other 2-wheels....
2008 Pinarello Prince Carbon (road bike)
2004 Ellsworth Truth (MTB)
The Jinx is offline   Reply With Quote
Old 11-03-2010, 03:21 PM   #2
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,938
Hi.
I personally have not gone down that road. But here is a thread which talks about it somewhat.
I'd much prefer a 1200GS-like design rather than just sealed nipples. But it's a start.
Ride safe...
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 11-03-2010, 08:21 PM   #3
tmex
tmex's Avatar
Oddometer: 2,039
You could sent your wheels to Woody and have him lace a set of HP2 rims to them.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 11-04-2010, 12:47 PM   #4
markymcd
markymcd's Avatar
Oddometer: 882
Woody has laced a Exel Takasago rim to an 800 hub for me and made it tubeless.
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 11-04-2010, 01:56 PM   #5
Law Dawg (ret)
Law Dawg (ret)'s Avatar
Oddometer: 820
Is there a Paul Harvey moment here T...does Woody do this for the F8?
Firefly; the way it will actually be...rednecks in space, dealing with the mess made by urban progressives while being hounded by them and all without any goofy alien stuff. Shiney!
Law Dawg (ret) is offline   Reply With Quote
Old 11-04-2010, 02:01 PM   #6
tmex
tmex's Avatar
Oddometer: 2,039
He can do anything when it comes to wheels. The HP2 rims are the only 21"/17" combo I know of that that are cross spoked which is the best way to go tubeless with a spoked wheel.
Old 11-04-2010, 03:23 PM   #7
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,223
The question though is, will they work with the 800 hubs. I've been wanting to go to the cross spoke wheels too for the tublessnessbessmess I hadn't considered the HP2 rims. I figured perhaps a rim from an older airhead GS for the front 21" and a newer oil/hexhead rear 17" rim might work, but the big question on getting the spokes and hubs to match is the uncertainty.
MCMXCIVRS is offline   Reply With Quote
Old 11-04-2010, 05:54 PM   #8
tmex
tmex's Avatar
Oddometer: 2,039
I don't see any reason whatever why the HP2 rims would not lace right up. What are you worried about - the spokes clearing the rotors or perhaps the rear sprocket?
Old 11-04-2010, 06:56 PM   #9
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,223
More like the number of spokes, the angle of the holes in the hub, the correct style and length of spoke being available and the issues you mentioned.
Deffinitly a bit of research needed, plus someone who is skilled at such work, which I am deffinitly not.
Old 11-04-2010, 08:27 PM   #10
tmex
tmex's Avatar
Oddometer: 2,039
Few people have the skill to work with cross spoked wheels - me included. I believe all the wheels in question have 40 spokes. I will double check this weekend since I have both bikes in the same place where I am headed. I would be less concerned about the other issues since they can be overcome. Hey, I did not say it would be cheap, just an option which should be checked out. Personally, I prefer the tubed tires off road for a number of reasons. The biggest one being the ability to air down to lower pressures than tubeless.
Old 11-05-2010, 03:18 PM   #11
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,223
Old 11-05-2010, 05:33 PM   #12
raider
Big red dog
raider's Avatar
Oddometer: 1,582
Really? What, 5psi? At pressures low enough to worry about tubed tyres unseating, you have to worry instead about tubes getting pinched (for exactly the same reasons).
This is neutral ground for the two types of tyre, IMHO. In 2010, the advantage of tubes over tubeless is one, and one only - lower manufacturing costs.
14 R1200GS Adventure
raider is offline   Reply With Quote
Old 11-05-2010, 06:00 PM   #13
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,972
I can plug a tubeless tire and be back on the road in minutes. I think that's a huge advantage over tube tires.
Support the AMA.
Waco is offline   Reply With Quote
Old 11-05-2010, 06:38 PM   #14
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,763
Plugs rarely hold and are not a good permanent fix... A new tube can be done quickly too and is a good permanent fix.
EnderTheX is offline   Reply With Quote
Old 11-05-2010, 06:42 PM   #15
Waco
Waco's Avatar
Oddometer: 14,972
They have held for thousands of miles, in my experience.
Support the AMA.
Times are GMT -7.   It's 12:17 PM.
